Square filing chains
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Aug 17, 2014.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    My 044 with Dual port, HD2 and RLSK off the loop is the best combo ever. :thumbs:
    Sorry... Had to do it again.
    Seriously though, I listen and look at every pic you guys post. I would love to learn to do what you square filers do :) So every pic and post help us to better understand :yes: Keep it up..
    And good call @Pallet Pete
    The sticky was a good idea. Lots of good info here! :dancer:
  2. mdavlee
    mdavlee
    Mike doesn't bother me. He will listen and admits it can be faster. It's the ones that try to say but this says that and my dad can beat up your dad that makes me quit sharing. I've spent probably 150 hours in the past 1.5 year grinding and filing chain.
    Skippy, Chvymn99, cnice_37 and 6 others like this.
  3. Hedgerow
    Hedgerow
    SW Missouri
    If Dennis says eat a banana....
    Just eat the banana...
    Dudes forgot more about chain than I know...
  4. mdavlee
    mdavlee
    If DC or Tom Fales Jr is telling me I don't know anything then I'm listening. When it's some new guy that has just bought his first file and is an expert then I'm done. That kind is unteachable
  5. trx250r180
    trx250r180
    This is a good bananna,carry on......
    Skippy, Hedgerow and mdavlee like this.
  6. trx250r180
    trx250r180
    couple depth guage / raker pics with a cheap guage the saw shop sells ,this is .025 ,just file till the tip of the raker is in line with the tool ,not sure if this was shown at beginning yet ,but will show again if it was
    square chain 9-17-14 013.JPG square chain 9-17-14 015.JPG square chain 9-17-14 016.JPG square chain 9-17-14 017.JPG
    Skippy, Chvymn99 and cnice_37 like this.
  7. trx250r180
    trx250r180
    square chain 9-17-14 009 small.jpg after you file get a step in the gullet that should be removed for better chip removal ,the cutter on the left was removed already ,i use a round chainsaw file for this ,you can also use a round grinder if you have one ,after about 3 sharpening's i do the gullets myself ,this is 3rd sharpening and due ,some guys do it every time ,it is up to you
    couple more cutters
    Chaz, Toad22t, Skippy and 8 others like this.
  8. Hedgerow
    Hedgerow
    SW Missouri
    Got some unusual chain in the mail from Mweba yesterday. This is a 60dl Oregon 76 chain he wanted to see if I could make him a play chain out of it.. Odd stuff. Slim chassis, but short teeth too... Not sure how it will go, but here's step 1... Gullets clean and front 60% of the raker removed...
    Tonight I should have step 2 done. There will be another pic to follow tomorrow hopefully.
    Skippy, Chvymn99, DexterDay and 3 others like this.
  9. trx250r180
    trx250r180
    When you look down from the top ,you want the left and right to look pretty close in size also ,and top plate angles all the same angle ,this helps keeping the saw from cutting crooked ,if you are off a little,that is ok , it will still cut ,just get as close as you can by eyeball square chain 9-17-14 018.JPG square chain 9-17-14 019.JPG
    Toad22t, Skippy, Chvymn99 and 7 others like this.
  10. mdavlee
    mdavlee
    What's with the top beak on that one chain?:cool:
    I clean the gullets out before filing. If I'm grinding I did it after and let the grinder take out as much as possible. I got all the way to the top of the straps when I do also. More room for chips.
    DexterDay and trx250r180 like this.
  11. trx250r180
    trx250r180
    Last post for a bit ,My saw shop has these bigger files for the rakers ,i really like these square chain 9-17-14 020.JPG square chain 9-17-14 022.JPG
    Skippy, DexterDay and mdavlee like this.
  12. trx250r180
    trx250r180
    I just noticed the round wheel on the silvey makes the top plate round also ,i do not inspect every cutter as i grind ,i just check the first couple and set the stops and grind away after that ,i may get some that are off some doing that ,but they still cut ok for a work chain
  13. mdavlee
    mdavlee
    I was just picking. I do better filing than I do grinding about top beaks.
    Skippy, DexterDay and trx250r180 like this.
  14. trx250r180
    trx250r180
    That hooked corner is actually pretty pokey on the finger tip ,my secret weapon in sharpening ,lol
    Skippy, DexterDay, Oliver1655 and 2 others like this.
  15. Oliver1655
    Oliver1655
    Central Missouri
    To add to trx's comments, on the raker depth gauge: Most folks after looking at the amount to be removed will remove the gauge before filing then use the gauge to check the new height. This protects the gauge and allows you to round the raker as you file. After determining the number of strokes need, most will then just apply the same number of strokes to each raker rather than use the gauge on each one for work chains. For race chains, there are lots of option on the shape and as you have noted in previous posts LOTS of time spent filing!!!
    I am really enjoying this thread! :like: :binoculars::popcorn:
    Skippy, DexterDay, Hedgerow and 4 others like this.
  16. DexterDay
    Northeast Oh
    I'm no pro and am a complete NEWB at fast chains. So I have some honest questions.
    When you guys do the rakers? Are you using a Dremel or some sort of grinder?
    Also, do you have a before and after pic of the rakers and gullets?
    I am enjoying this thread more and more every day.. Good stuff guys. Keep it coming. :dex:
    With an upcoming GTG, I would like to possibly have a nice chain.. I need to get some files first.. :(
    Toad22t, Skippy, Chvymn99 and 2 others like this.
  17. trx250r180
    trx250r180
    2-3 swipes with a flat file works for me ,i have a raker wheel for my usg grinder ,but have never tried it ,it is new in the box still ,rounding the raker tip like factory is recommended also ,instead of flat tips like my images
    Skippy, Oliver1655 and mdavlee like this.
  18. cutforfun
    cutforfun
    Just get on eBay and buy some of the "race chain" from piltz or what every his name is. Its has to be fast. No hours filling chain and getting pizzed off.
  19. Hedgerow
    Hedgerow
    SW Missouri
    I will try to get a "before" pic tonight of that 76 I'm working on..
    Skippy, Oliver1655, mdavlee and 3 others like this.
  20. DexterDay
    Northeast Oh
    I guess I should have been more specific. I normally do as you said with my depth garage and flat file. Trying to keep the raker as close to factory as possible.
    I meant when the rakers are made smaller (lots of material is removed and they take on a much smaller form/race chain), but yet keep the required depth/clearance. Some of the chain Hedge has posted, had some mighty small rakers. I'd like to see what the before and after of the same Raker looks like. Do you remove more from the back, front, or a little of both, and then keep the nice little Raker with a small radius at the top?
    I am intrigued by the skills shown in this thread and of I could learn a small percentage of them? I would be utterly satisfied. :thumbs:
    Going to look for files on the Bay now.. I know some were suggested earlier in the thread? But do you guys have a "favorite" or what you consider the Best? I know that is just a single persons opinion. But I respect all of your opinions.
