Wanted! square files
Discussion in 'FHC Classifieds' started by Skippy, Feb 7, 2015.
  1. trx250r180
    trx250r180
    That is witchcraft
  2. Moparmyway
    Moparmyway
    New York
    Burn him at the stake or throw him in the lake ................ (I have to do something to beat his chains) :picard:
  3. Skippy
    Skippy
    Pics
    mdavlee likes this.
  4. mdavlee
    mdavlee
    Looking better.
    trx250r180, Hedgerow and Skippy like this.
  5. mdavlee
    mdavlee
    :banana: Haha.
  6. Hedgerow
    Hedgerow
    SW Missouri
    Is that a hint of a hard line I'm seeing there? Just a bit low?
    mdavlee likes this.
  7. Skippy
    Skippy
    Is it too low?
  8. Skippy
    Skippy
    Yeah it might be
  9. Hedgerow
    Hedgerow
    SW Missouri
    Always shoot for the corner of the file to line up perfectly and make a nice hard line right through the center of the working point.
    If you're off one way, you'll get top beak.
    If you're off the other way, you'll get side beak.
    Side beak is what you have now, and cuts better than top beak, but always shoot for perfect bullseye right through the center of the point..
    Nobody is perfect, but it's what we all strive for.
    "Aim small.. Hit big.."
    Skippy likes this.
  10. Skippy
    Skippy
    Thanks buddy
  11. Hedgerow
    Hedgerow
    SW Missouri
    LOL...
    Mike's the one ya gotta worry about!!
    Most everything I've learned came from studying stuff he had filed..
    mdavlee, Moparmyway and Skippy like this.
  12. Skippy
    Skippy
    I'm practicing fingers bleed and are sore
    Lol
    mdavlee likes this.
  13. trx250r180
    trx250r180
    In the second vid i posted ,with the white stihl bar in it ,look where my lh thumb is ,may help getting your corner ,i hold the chain down with the rag so no cuts ,and press on the chain driver with my thumb to keep chatter down
    Skippy likes this.
  14. Skippy
    Skippy
    I will try that
  15. Moparmyway
    Moparmyway
    New York
    The pot calls the kettle black ........... again :picard: :p :D
    In all seriousness, both you and Mike helped me tremendously .............. thank you to both of you :thumbs: :saw:
    Now ............ when are you havin another chain "event" ?
    I got a few work chains (that I found in a wheelbarrow full of water, then I let them sit in some WD-40 and after their bath I used an old worn out file to put a dull edge on) that need a workout.
  16. DexterDay
    DexterDay Administrator
    Northeast Oh
    I am a rookie at best, but you are not getting the whole top plate. Your missing the very edge, which means your filing back from the corner and that will make you lose top plate angle.
    Also, I still see several angles on your side plate?
    Can you snap a pic of the file in the tooth (not the angle, just the file in the working corner )?
    Arrow shows where file is missing. And then the other blue line shows the various angles
  17. Skippy
    Skippy
    Dex
    What do you think is cause this seriously ?
    Any ideas what to do to correct this ? Anybody can jump in and assist me .
    The diagrams help a lot
  18. DexterDay
    Northeast Oh
    I think you are still using the wrong working corner on the file? Or you haven't filed back far enough to fix the damage you did earlier
    Matt's pic (drawing) was a good one.
    Also, I was told a mistake I was making. I was working hard trying to keep my corner, but I was losing top plate angle. I concentrate on the angle first (working from the outside in, and then lining up the corner of the file to the corner on the cutter.
    Again. I am a rookie as well. But I have had a good teacher, that gave me several good lessons, and he gives me constructive criticism on the cutters he looks at. In all honesty, it has helped me because of the mistakes I made. Those mistakes make him better describe what I am doing wrong and ways to correct it.
    Skippy likes this.
  19. Skippy
    Skippy
    I am only a beginner too as you see lol
  20. Skippy
    Skippy
    Can you find or create a pic of the proper angles with the files , from a few different views . anyone could do this hint hint . lol
    I think I'm using the right part of the file but maybe not .
    Ty
    Chr
