Splitter pump upgrade.
Discussion in 'Chainsaws and Power Equipment' started by bobdog2o02, May 18, 2016.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Thanks for the clarification. With your help it's now clear as mud, bud. :startled:
    papadave, Barcroftb and Eric VW like this.
  2. Eric VW
    Knew you'd dig the Captain Obvious effect....:rofl: :lol::thumbs:
  3. Horkn
    No Inglés
    Eric VW, papadave and MasterMech like this.
  4. MasterMech
    Yep. That kit is at Hazard Fraught tools for about $40 IIRC. Very handy.
    Horkn, Eric VW and bobdog2o02 like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Lol, hazard fraught couldnt be closer to the truth. Ive often wondered what was trying to kill me more, the truck or the junk tools.
    Horkn, Eric VW and MasterMech like this.
  6. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Parts are ordered. Next stop Hazard Fraught.
    Horkn, Eric VW and papadave like this.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Got the new pump on today. I did go with the ruggemade kit... kit sucked. No hardware included. Oh well. So I went from about a 32 second no load cycle time with the 8 gpm. to a 18 second no load cycle time with the 13gpm. I did notice that it takes a second to do work on the second stage... and that the sheer liquid movement is lugging the motor a bit while traveling.... is it possible/wise to bump the motor rpm up a bit? Change the pressure output on the pump?
    fox9988, Barcroftb and Eric VW like this.
  8. RCBS
    RCBS
    Over here
    Governor adjustments can be tricky. Any adjustments in the throttle linkage?
    Barcroftb, Eric VW and Horkn like this.
  9. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    ? Clueless....
    Eric VW likes this.
  10. RCBS
    RCBS
    Over here
    Sometimes there is a screw that will dictate how far the linkage will/can move. May be able to turn such a screw and gain a few rpms. Apologies, I'm not familiar with your particular animal there. The Vanguard vtwins have such a screw, as do the Hondas. Pull that gas tank and the throttle lever shroud off and have a look see. There will be a throttle "arm" somewhere under there connecting the carb to the governor. A stem out top of carb is hooked to throttle butterfly on carb. Look for an adjuster screw somewhere around the stem...it acts as a "stop" for the butterfly. If it has, back off 1-2 turns and see how it does.
    I have never had much luck with governors...maybe it's just me.
  11. Horkn
    It's good you didn't get the 16 GPM kit.
    Sounds like you need moooaaar poweeeeerrr!
    Barcroftb, Eric VW and bobdog2o02 like this.
  12. MasterMech
    Well, to truly understand what's happening in the system, you're gonna need a few items that will prob cost more than you'd like to spend. A couple fittings and a pressure gauge would go a long ways tho. You need to know if there is something restricting fluid flow, which could cause excessive heat in the system. Or if the engine just ain't got it. If you have a tach, and yes, a chainsaw tach will work fine, check the rip 'ems at wide open throttle. You should be able to turn that little Briggs up to 3600 rpm as long as the pump can handle it too.
    I can't see a 6.5hp engine having too much trouble with a 13 gpm pump. Any chance your valve had a flow rating on it?
    RCBS, Horkn, Barcroftb and 1 other person like this.
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    took the tank off, the adjustment on the governor was a series of holes in the control arm where a spring fits.... i had to make a new hole. Now running about 3650 rpm no load, then falls to 3450 under load. Much better.
    My last question on this project. What is the hottest i want the hydraulic system to work at. Its getting toasty, hot enough i dont want to leave my hand on the cylinder for more than about3 seconds..... I have an IR temp gun i plan to use later today.
    Eric VW, Horkn, RCBS and 1 other person like this.
  14. MasterMech
    South of 160 is great, 180 is the limit of my comfort zone and more than that should be corrected.
  15. RCBS
    RCBS
    Over here
    I'm seeing 212-260* looking at a Parker hose selection chart. My splitter's fluid will get pretty warm sometimes, but never enough for me to become concerned. Last thing you need is a nice shower of high pressure boiling oil though. Interested to see what temps its making.
    Eric VW, Horkn and Barcroftb like this.
  16. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Tank and cyliner are 1bout 150, valve is 160, and the pump is a chilly 110.
  17. RCBS
    RCBS
    Over here
    No worries there! :yes:
    Eric VW, Horkn and bobdog2o02 like this.
  18. MasterMech
    I suppose we know where the restriction is don't we?
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Yup
  20. Horkn
    I've never taken temps of the old didier when it's warmer outside and in splitting but the cap on the tank whistles at times. It's like a tea pot. Lol. It's got a small tank, and the splitter has been doing this for years. So I never bother caring.
