Splitter pump question?
Discussion in 'Chainsaws and Power Equipment' started by StickBender, Oct 23, 2014.
  1. lukem
    Some RTV silicon might work better than locktite.
  2. Oliver1655
    Oliver1655
    Central Missouri
    The suction port of a lot of the 2 stage pumps are just pressed in. Common cause for failures are it too stiff of a suction hose & not enough of a distance/length of hose for the hose to act as a vibration dampener.
    As Gary recommended, clean it well then sleeve retainer.
  3. redneckdan
    redneckdan
    Northern Minnesota
    Yes it is a pressed in hose barb.
    Get both surfaces totally oil free. Go git ya some acetone.
    Use Loctite 680. Apply then insert the barb. Put a piece of 1x across the barb then give it a light smack with a mallet to set it in the hole.
    Oliver1655, clemsonfor and MasterMech like this.
  4. MasterMech
    Like others before me have said, it's a press fit fitting.
    Totally degrease both surfaces, use green loctite sold for locking down engine rod/main bearings, and put it back together.
    clemsonfor likes this.
  5. nate
    nate Banned
    Palmer, AK
    Nope
    , lictite is the correct product.
  6. StickBender
    StickBender
    Appreciate the comments guys, I guess it isnt a big deal! I will get it fixed next week. That's why I ask questions around here, because someone always has the answer I'm looking for!
  7. redneckdan
    redneckdan
    Northern Minnesota
    Someone else had mentioned SAE ORB fittings. I will toss in a comment that these are what I prefer for hydraulic systems requiring leak free performance. JIC is second. I avoid NPT if at all possible unless it's permanent and the fitting is brazed.
  8. prell 73
    prell 73
    ia
    The inlet is suction barb hose slips on u need to hose clamp it .
