Splitter is finally built
Discussion in 'The Wood Pile' started by Firewood Bandit, Mar 14, 2021.
  1. Firewood Bandit
    Firewood Bandit
  2. JRHAWK9
    JRHAWK9
    Wisconsin
    Man, let that thing eat! Should be illegal to tie it's hands behind it's back like that. :D
  3. Firewood Bandit
    Firewood Bandit
    Two things to note:
    When you use a splitter with "auto cycle" valves you keep your HANDS OUT OF THE WAY once the levers are actuated.
    You handle rounds by the middle not the ends. Since I have the ram on running 21" of the 30" stroke right now your fingers are close to the push plate and wedge. If a round shift slightly you will pinch a finger and you only have to do that a few times to learn not to do that again. Real important on a 200# round.
    Horkn, WeldrDave, Need2Saw and 6 others like this.
  4. TurboDiesel
    After using one quite similar this weekend, i like how the 4way wedge drops below the bed.
    Very nice!
    Hmmm.
    Wonder where Firewood Bandit was this weekend. Would have loved to try that new splitter!
    Horkn, jtstromsburg, Need2Saw and 7 others like this.
  5. TurboDiesel
    Wow what a big machine!
    I've noticed (not that it matters much) that the 4way wedge makes a LOT of splitter trash. I only mention it because i work in the neighbor's field/log yard and i try to clean up the chunks so he doesn't hit it with the mower.
  6. Firewood Bandit
    Firewood Bandit
    I was playing golf like I do every day. Don't get a day off like the working folks.:headbang::hair::whistle::zip::p:picard:
    Horkn, WeldrDave, TurboDiesel and 6 others like this.
  7. JRHAWK9
    JRHAWK9
    Wisconsin
    What I meant was to run that throttle full to let that pump eat. :) Judging by the 11sec cycle time on that shortened stroke you are not running it full throttle.
  8. Firewood Bandit
    Firewood Bandit
    You are correct, the amount of trash is more. The knives are so sharp too and that contributes to the problem.
    Horkn, WeldrDave, TurboDiesel and 5 others like this.
  9. Firewood Bandit
    Firewood Bandit
    You are correct, it was running at 2660RPM. You have a good ear. I always split by myself and most of the time the machine is running doing nothing as I stack as it is split so this isn't much of reason to run it faster.
    The hour meter doubles as a tach when it is running.
  10. Haftacut
    Haftacut
    Rives Junction, MI
    Perfect working height...fine pice of craftsmanship! No upgrading from there:yes:
  11. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Nice machine sir!!!! I want to see some Gnarly old twisted stuff get destroyed on there!!!
  12. Firewood Bandit
    Firewood Bandit
    No matter how a splitter is made, wood will still only split in the manner dictated by the grain. Running crotches through a 4 way is just hard on equipment. For that reason I feel a 4 way MUST be adjustable so that it can be used as a conventional splitter. The knives on this one are made of AR400 and are real sharp and will cut wood if needed. This does create a little more splitter trash though.
    WeldrDave, TurboDiesel, Eckie and 2 others like this.
  13. Firewood Bandit
    Firewood Bandit
    I figure this will be the last splitter I buy. I've been retired 11 years now, figure I only have one more decade of serious wood cutting in me. Maybe have to have some wood delivered then, or maybe not.:zip:
    Haftacut, Horkn, WeldrDave and 6 others like this.
  14. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    A neat trick I saw on one was a foot pedal that could be pushed off or on connected to the throttle.
    Like a sideways treadle on the ground. Step on one side dropped the motor down to idle as he walked away carrying, stacking, loading, getting a drink etc.
    step the other side (like a seesaw) revved it back up to the preset setting. Hands could be carrying or handling firewood on the beam.
    Pretty neat I thought.
  15. shaggy wood dump hoarder
    menomonie
    Did you take a look at Wolfe ridge at all?
    Firewood Bandit likes this.
  16. Firewood Bandit
    Firewood Bandit
    Sure, Wolf Ridge is made 90 miles away from where I am. The build quality is no where even close to this one.
    I would not consider WR because the 4 way wedge cannot be adjusted all the way so it can operate as a conventional splitter. I process log cut offs that have a lot of crotches and big limbs in them.
    Horkn, Chvymn99, Chud and 1 other person like this.
  17. yooperdave
    Very nice splitter you had built for yourself there. Is it your birthday gift (a little early) or do you get another one today???
    Horkn, Chvymn99, WeldrDave and 3 others like this.
  18. Firewood Bandit
    Firewood Bandit
    Nah, everyday is Christmas for me.:cool:
  19. JRHAWK9
    JRHAWK9
    Wisconsin
    congrats! Must have done something right during those 53 years! :handshake: :D
  20. WeldrDave
    Hey Ron, I think ya need some more wood to split! :D:whistle::rofl: :lol: ;)
