Spark plugs?
Discussion in 'Chainsaws and Power Equipment' started by Easy Livin' 3000, Nov 11, 2019.
  1. Horkn
    Probably correct on that. I'm sure there's a fix for that. Guys race these predator engines in racing carts.
    Edit.. disconnect the low oil cutoff switch. Just remember to check oil level.
    saewoody and metalcuttr like this.
  2. saewoody
    saewoody
    Central CT
    I figured there was a way to deal with. There’s quite an aftermarket for these engines due to all the racing that gets done with them.
    metalcuttr and Horkn like this.
  3. brenndatomu
    My experience is that people seldom actually wear spark plugs out in small engines, in cars/trucks, sure.
    More likely that a small engine fouls a plug than wears it out.
    And I agree, Champion plugs suck.
    MAF143 and Horkn like this.
  4. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    Update:
    Spent $3 on a new NGK plug, and the old girl started right up. It was high time, the plug that was in it when I bought it, wasn't even the correct one.
    Good thing, cause I just spent $26 on two new PTO belts.
    Can't be sure the coil isn't going bad, because it was hot when it wouldn't start. But after fretting about correct torque, etc., I'm just gonna enjoy my success getting it running again!
    saewoody and Horkn like this.
  5. saewoody
    saewoody
    Central CT
    Glad that worked out for you. Years ago I put an incorrect spark plug into a one cylinder engine in an old garden tractor just to see if it would turn over. The plug exploded in the cylinder immediately and the porcelain shattered all over the place. Not one of my smartest experiments.
    eatonpcat and Easy Livin' 3000 like this.
  6. Nitrodave
    Nitrodave
    Grayling Mi.
    I used to change spark plugs after every 1/4 mile... there wasn’t much left of them.... lol
    eatonpcat and Horkn like this.
  7. Horkn
    That's an extreme situation, you know. Were you running nitromethane?
    eatonpcat likes this.
  8. Easy Livin' 3000
    Easy Livin' 3000
    That sounds like a good experiment to share. Hopefully there were no injuries to you or the engine.
    I once put a stick into a one cylinder block on a 700 Yamaha Enduro through the spark plug hole, to check something, I don't remember what (travel, maybe). I then turned the engine over, and promptly broke the stick off in the head. Had to disassemble it to get it out.
    Generally speaking, curiosity is a great thing. But, we all remember what it did to the cat.
    Horkn likes this.
  9. Nitrodave
    Nitrodave
    Grayling Mi.
    Yes... lots of it ... lol
    Horkn likes this.
