Sooteater rods
Discussion in 'Modern EPA Stoves and Fireplaces' started by Eckie, Nov 15, 2025.
  1. Lawn Chaney III
    Lawn Chaney III
    Pembroke, MA
    has anyone found a poly brush with button lock? I have a Sooteater, rods are white and button lock. I'd love to just button in a poly brush to those rods and sweep it that way instead of using the drill and whipping it. I've only found a threaded poly brush. Being cheap and don't want to buy another set of rods.
    Horkn, wildwest and brenndatomu like this.
  2. Highbeam
    Highbeam
    Kinda surprised they put a 90 at the bottom of your liner instead of a tee with a capped section of liner dropping down to the old cleanout below. I suppose it might be a special situation, would be hard to drop the liner with the 90 installed. I hope to never have to use a liner again! Class A pipe is nice.
    The way you describe it make it a top down cleaning chore. I would just use a tight fitting poly brush and the regular fiberglass rods.
  3. cezar
    cezar
    KY
    I always struggle disconnecting the sooteater rods as they come out the chimney. There is just enough tension on the assembly that its hard to push the pin in.
    Anyone found a way to lube them?
  4. brenndatomu
    I usually just give it a little wiggle while pushing the pin in...usually doesn't fight too much...the worst part is trying to not drop anything down the chimney during the whole ordeal! :rofl: :lol:
    I'd think some WD-40 would lube them fine...
    Chvymn99, Horkn and Burnin Since 1991 like this.
