Some New Portable Generators
Discussion in 'Everything Else (off topic)' started by thewoodlands, Dec 16, 2015.
  1. thewoodlands
    thewoodlands
    Why don't they have an oil filter?
    XXL likes this.
  2. Backwoods Savage
    Beats me. I haven't seen any of those yet but would be tempted to not buy one.
  3. bushpilot
    bushpilot
    Eastern Washington
    Not really a problem, if not run under heavy duty situations. Lawn mowers and many other small engines don't have then either. Running it a few times a year, I will take the cheaper price and change the oil regularly.
    Greg
  4. XXL
    XXL
    Ontario, Canada
    Maybe for the same reason they now recommend going farther between automotive oil changes. Better engines and better oils?
    thewoodlands and bobdog2o02 like this.
  5. cnice_37
    cnice_37
    Mine doesn't, most of the home units don't that I have come across.
    It runs <30 hours a year max, not really necessary.
  6. thewoodlands
    thewoodlands
    Backwoods Savage , bushpilot , XXL , cnice_37 , I just had my question answered from Electric Generators Direct.
    My question was, Why doesn't the Briggs and Stratton 8000 watt electric start generator have any type of oil filter on it?
    Their answer,
    The engine on this unit is a splash lubricated engine and they do not have oil filters.
    What is Splash Lubrication? (with pictures)
    Backwoods Savage and XXL like this.
  7. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Hopefully you don't have to turn the unit upside down to dran the oil like you do on some lawnmowers.
    Gary
    thewoodlands likes this.
  8. thewoodlands
    thewoodlands
    MasterMech, XXL and Gary_602z like this.
  9. Will C
    Will C
    New York
    I have a 2000 watt Honda. I change the oil yearly, using Mobil 1. It probably gets around 25 hours use. It only holds 13 oz. I have to tilt it on its side, but bought a funnel that screws into the dipstick hole for drainage. It's so small I don't know where a filter would fit.
  10. Locust Post
    Thank you for this thread Zap, just reminded me that I need to change the oil in the generator. I have been meaning to grab a filter and oil for the splitter so I'll just get a little more. Heck maybe I'll have an oil change party and do the snowblower too.
  11. MasterMech
    Most small engines have a relatively short oil change interval because of the lack of an oil filter among other things. Crude fuel systems, loose manufacturing tolerances and (gasp) cheap materials all contribute. But.... For most... It's cheaper to change the oil on the short interval rather than pay upfront for all the tech.
    And yes, many single cylinder engines are simply "splash" lubricated and lack any sort of oil pump to push oil through a filter.
    If it's a tool that you will run infrequently, I don't think you would ever realize the difference between a pressure lube and splash engine. But given a choice, I'd always go for a pressurized and filtered engine over a splash.
  12. ranger bob
    ranger bob
    Leeburn Ontario
    Maybe its because they do not have pressurized oil system with an oil pump to make a filter feasible. The only small engines we have that have oil filters are the CubCadet lawn tractor with 22hp Briggs and Straton commercial use rated engine and a Merc 4 stroke outboard. All the rest are just splash lubricated from the crankcase. Our generator doesn't have one and it just needs good quality synthetic changed ever 50 - 150 hours run time depending on how much its used. Once every year for sure.
