Solo 665 vs Mastermind MS 362C-M
Discussion in 'Chainsaws and Power Equipment' started by DexterDay, Aug 16, 2014.
Thread Status:
Not open for further replies.
  1. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    The use of the 881 C/O saw with oil injection would probably be problematic, but it could be done if you nixed the oil injection.
    I would have done the Dolmar to 681 Solo conversion using a 6400/6401 but could not find a 'Dexter Clean' one to experiment on. AFAIK the three P/C kits ($300 ea + ship + import duty) left Germany sometime last week, but travel time and US Customs are usually time consuming so who knows when they will arrive. In the meantime if anyone has a 6400/6401 (Dexter Clean) running or not they want to part with let me know. I can get a new 6410 for around $500 but that would be stupid!
    clemsonfor and DexterDay like this.
  2. MasterMech
    I wanna know how many ways that crank is held together. :zip: Building another saw like it would probably be expensive today!
    We all know that there are varying degrees of porting/modification to a saw. My 441 is no race saw, but I know what it will do and have a pretty good idea how long it will do it for. ;)
    I still wouldn't mind owning one of these Solos.....:saw:
  3. Cut4fun
    Cut4fun
    OHIO Redneck
    Just cant believe guys overlooked solo for so long with your goggles on. We tested them back in 08 stock etc and had 3 guys do a build off with them back in08 or 09 with 3 681.
    They are a pig in the hands with weight for 65cc and to soft av but power wise top dawgs 65cc 75cc 81cc. ;) But if you are running it as 81cc throw the weight out the door. Lighter then most in class. ;)
    08 stock 681
    clemsonfor, mdavlee, Chvymn99 and 5 others like this.
  4. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    And IINM the stiff Dolmar AV parts will interchange with the Solo parts.
    clemsonfor, mdavlee and DexterDay like this.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    The stock Solo 681 would probably tear a 441 a new a!! hole :) 10 cc more displacement is lot to overcome with a woods port. No replacement for displacement :dex:
    Ported 362C-M vs Stock Solo 665
    Would probably be about the same as a
    Ported 441C-M vs Stock Solo 681
    Just my opinion. The 441 is a good saw, but that 681 is a running saw.
    KilliansRedLeo- I had that Dolmar 6400. I would have let you have it for pretty cheap. I sold it for $425, but would have done better for you. But that was right before you got these Solo's. Hindsight :)
    clemsonfor likes this.
  6. Cut4fun
    Cut4fun
    OHIO Redneck
    Look at the front of the muffler on that solo and you can tell not a typical work saw. Even though we used to call them work saws. ;) Some guys started pulling the solo cranks and welding them up to stop them from failing. ;)
    mdavlee and MasterMech like this.
  7. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Dexter, is the 6401 still giving you problems?
  8. Cut4fun
    Cut4fun
    OHIO Redneck
    Lot of those hotter ported 7900 681 saws have a husky 272 piston in them with a shim under the cylinders. There is even a wide skirt wiseco piston going in them for the the saws that is being used for the gtg and racesaws.
    mdavlee likes this.
  9. Cut4fun
    Cut4fun
    OHIO Redneck
    concretegrazer likes this.
  10. Cut4fun
    Cut4fun
    OHIO Redneck
    By the way all of this stuff is already posted on my site in threads if you are wanting to learn.
    clemsonfor and mdavlee like this.
  11. MasterMech
    I don't think I have an account there yet....:emb:
    The pics don't show up here unless you are logged in on your site I think.
  12. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    IIRC the Weisco pistons are custom castings made available to and available from EHP?
    Cut4fun likes this.
  13. Cut4fun
    Cut4fun
    OHIO Redneck
    Yep Ed had them made up.
    KilliansRedLeo likes this.
  14. DexterDay
    Northeast Oh
    Yes.... :(
    It runs great from 4,000- and up. But let it drop below 4k and it just dies. Doesn't matter where the L screw is set. :(
  15. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    All the Solos (665, 675, 681) have the exact same crank, same part number even. They are a conventional 5 part setup, crank pin, 2 counter weights and 2 half shafts. I have a new OEM one here and will post a few pics later.
  16. mdavlee
    mdavlee
    Zama carbs are very finicky. I wouldn't doubt the 665 comes close to the 441 in cutting cants. The 460 should beat it by a little more I would think.
    Chvymn99, Cut4fun and DexterDay like this.
  17. clemsonfor
    Dang what a saw! Beats your ported $362 and at about half the all in cost of the Stihl!!! That thing was worth the price , had no idea it was that kind of saw when they were for sale!! Basically the factory made the saw run right from the get go. Cylinder from factory must look closer to what a ported saw looks after its been worked on!
    Cut4fun likes this.
  18. clemsonfor
    There hand ground? I would assume there is a machine or robot to do that!!
  19. DexterDay
    Northeast Oh
    There is a machine, but someone had to "set it up".
    Ground chain = machine
    Filed chain = by hand/man
    mdavlee likes this.
  20. mdavlee
    mdavlee
    Exactly. Those wheels have to be dressed and I've seen some stihl come with top beaks on the square that cut like semi chisel ripping chain.
Thread Status:
