Solo 665 to 681 Conversion
Discussion in 'Chainsaws and Power Equipment' started by KilliansRedLeo, Oct 13, 2014.
  1. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Spoke to Dexter briefly last night. If time permits, we are going to test the 665 conversion to 681 with the stock windowed Solo piston and with the slab sided Dolmar 7900 piston. So we may be able to have a report on how the Dolmar works in a stock 681 compared to the Solo windowed piston.
    Waiting for the 681 plaques, then the kits, gaskets, plaques and the 7900 piston are off to Dexter and Dewey on Monday perhaps Tuesday. Dexter's OCD REQUIRED that if the saw was going to end up a 681 it needed the appropiate plaque stating that it is a 681! Good for him, I would have blown that detail off, LOL!
    Kevin Smith, bryanr2, FredRed and 2 others like this.
  2. Aclarke
    Aclarke
    Santa Barbara, Ca
    Interesting feature on the original 7900 piston is that it has asymmetric windows on the piston which was likely to stagger flow on the transfers and improve exhaust scavenging/ lessen charge/air losses out the exhaust. Some engineering/thought went into its design so hard to understand why the change to the slab side. Thought I read a while back that the 7900 crank design was changed? Perhaps this had something to do with the piston. Lightened??
    Hedgerow likes this.
  3. Hedgerow
    Hedgerow
    SW Missouri
    I always wondered about the staggered transfers...
    Never even occured to me the engineers would try it via piston window size...
    :confused:
    Learn something new every day...
    :drunk:
  4. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Good stuff, Adam. I have a windowed Dolmar 7900 piston round here, I'll compare it to the Solo. Better yet I'll get a picture of the Solo piston and put it up here. I also read that the case volume is so 'on the edge' in the 7900 that putting a BBK on them provided less than satisfactory results.
  5. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Solo piston out of the kit on the left, Dolmar slab side on the right.
    Oh and the plaques came this afternoon.
  6. Hedgerow
    Hedgerow
    SW Missouri
    They are a step down in performance IMO... But will pull a big bar decent..
    Aclarke and mdavlee like this.
  7. MasterMech
    Has anybody tried running the BBK on a Solo crank?
  8. DexterDay
    DexterDay Administrator
    Northeast Oh
    I do know that the parts will be in route soon. KRL has them all boxed up and ready. He was even able to track down a 681 plaque for the saw. So it's legit now!! :dex:
  9. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    MM, great idea, unfortunately, I have the crank but no saw to try it out on. I'd do it, but don't have a dolnar saw to try it on, thats why I'm looking for a very clean 6400.
    MasterMech likes this.
  10. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Dex, packed, ready to go! UPS will pick up Monday!
    Cheers
    KRL
    DexterDay likes this.
  11. Aclarke
    Aclarke
    Santa Barbara, Ca
    Tried the BBK on a stroked 7900 and it worked ok. Wasn't worth the $$$/effort
  12. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    OK, Adam, I guess it was a nice idea but no more!
    Thanks
    TJ.H
  13. mdavlee
    mdavlee
    What I would be more interested in is a 675 to experiment with. I have some ideas that may or may not work. I'll find out eventually though.
  14. Aclarke
    Aclarke
    Santa Barbara, Ca
    What are you thinking Mike?
  15. mdavlee
    mdavlee
    50mm bore gives a ton more piston options in solid side and windowed. Pick one to match the intake timing with no windows and then make a spacer. 372 piston is going to be close. It's just a good bit taller so it will take a spacer and maybe a little machine work. Thinking it might be like building a stroked 372 but not having to pay for the stroker crank. I haven't had time to put it together and see where the timing will end up.
    concretegrazer and Cut4fun like this.
  16. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Mike, I have a 665/675/681 NOS crank here, 675 P/C kits are actually harder to find than the 681! Why, who knows! If I could find one I would try it. What if you used a Dolmar 7300 as a donar? Don't know about timing differences or porting between the 7300 and 675 but it is a thought.
  17. mdavlee
    mdavlee
    I have the 7300 top end. I just couldn't bring myself to start swapping parts onto that 665.
  18. DexterDay
    Northeast Oh
    Put the Solo crank in a Dolkita? Find one on the cheap? Just need a donor 6400/6401, the crank, and your 7300 top end (with the appropriate spacer). I have heard parts can be swapped, but I wonder about the port timing with the spacer? 1 mm can be a lot if it's in the wrong place.
  19. mdavlee
    mdavlee
    It would be an extra 1mm on top of the other 3mm to get the piston to have squish.
  20. DexterDay
    Northeast Oh
    What 3 mm?
    I thought if you put a Solo stroked crank in a Dolmar, you would just have to add the 1 mm spacer?
    I am no builder. So please excuse my ignorance ;) This is an honest question. I've heard a lot about this 1 mm spacer.
    If I used a Dolmar jug on my Solo, I would just need the 1 mm spacer? No? So if you turned a Dolmar, into a Solo (with a stroked crank). Wouldn't it be the same?
