Solo 665 to 681 Conversion
Discussion in 'Chainsaws and Power Equipment' started by KilliansRedLeo, Oct 13, 2014.
  1. Cut4fun
    Cut4fun
    OHIO Redneck
    Corn farmers aren't worried. Free supply for their cost of planting and taking in. Unlimited supply on hand. Fed from outside straight to their heat source. Remember reading about it when I thought about doing it.
    I aint eating no field corn either. Been there tried that. :zip:
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    My Pellet furnace will burn anything.
    But price was always the factor for me.
    Hijacked... My bad KRL ;)
    Cut4fun likes this.
  3. SquareFile
    SquareFile
    somewhere
    You eat field corn in many different ways
    Cut4fun likes this.
  4. mdavlee
    mdavlee
    Trying to quit all that.
    Dex hurry up and get this swap done. Are there going to be before after videos with timed cuts, weather condition, and barometric pressure that day:whistle:
    the GOAT, DexterDay, bryanr2 and 3 others like this.
  5. Cut4fun
    Cut4fun
    OHIO Redneck
    Yep you did it and I ran with it. ;):whistle:
  6. DexterDay
    Northeast Oh
    Yeah Mike, I was gonna do just that.. Don't know about the pressure ;)
    But, it was gonna be as follows.
    Run 3 passes as is (65 cc) with 18" bar and chain.
    Then swap the tops and install 681 slug and jug
    Documenting and taking pics of all the steps. Then we will run a tank through it with a different bar and chain/20"/to help seat the rings and break it in a little.. And then make 3 passes with 18" bar and chain.
    Same Cant and try to make it the same day if at all possible.
  7. lukem
    My phone has a barometer...yours might too. Just sayin.
    concretegrazer, Chvymn99 and mdavlee like this.
  8. DexterDay
    Northeast Oh
    It does everything else.. Literally.
    mdavlee likes this.
  9. mdavlee
    mdavlee
    I was just picking about the temperature and pressure. If you do it in a day or two it shouldn't change the wood much unless it's frozen.I
    DexterDay likes this.
  10. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    OK guys, time for some advice. Dolmar changed the piston configuration for the 7900 from windowed to slab sided. Most think that the change made for better performance out of the 7900.
    Dexter and I were discussing using the new Dolmar 7900 piston in this project instead of the Solo windowed piston that comes in the Mahle OEM Solo 681 P/C kit.
    I read somewhere that a couple of builders favored this route but I have no specific knowledge or opinion on how the piston would perform in a stock 681 saw. Any thoughts?
  11. the GOAT
    the GOAT Banned
    Maine
    For the tests to be considered valid you need to make some cuts with a control saw before each run with the solo. ;)
  12. DexterDay
    Northeast Oh
    You pick... ;)
  13. Aclarke
    Aclarke
    Santa Barbara, Ca
    Slab sided is much lighter. 15+ grams.
    Don't think the flow is compromised vs. The windowed piston. Also, less reciprocating mass will be a net gain, however small.
    DexterDay and mdavlee like this.
  14. the GOAT
    the GOAT Banned
    Maine
    441
  15. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    OK, Adam, I agree the reduction in reciprocating mass I believe would lead to higher RPMs, but also a corresponding loss in torque, do you think not?
  16. w8ye
    w8ye
    Mansfield, Ohio
    The torque factor because of weight would come more into play from the external rim of the flywheel rather from the reciprocating piston weight.
    Then of course the counter balances on the crank will effect torque?
  17. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Both good points! w8ye, OBTW what does w8ye stand for? Been thinking about that since I was on another site, still have not yet figured it out!
  18. mdavlee
    mdavlee
    I know Randy prefers the slab sided. I've not done one with that piston. I hope to experiment with one sometime this winter.
  19. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Mike good point about Randy's preferences. I'm thinking that the slab sided piston may very well work much better when used in conjunction with porting the engine. However I'm not sure what it alone would do when used in a non-ported stock Solo 681. We do know that the stock timing numbers of the 7900/681 jugs are very close if not identical. So it stands to reason if Dolmar went to the slab sided piston, for a benefit known only to them; we could assume that benefit would also apply to the Solo. Could we not?
  20. mdavlee
    mdavlee
    I would think it would benefit a stock saw as well.
