  1. wildwest
    impressed!
    IHATEPROPANE likes this.
  2. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    2014
    Your total use: 3,857kWh / approx. cost $572.06
    ETA: The biggest user is the electric dryer been thinking of a clothesline. But never seem to get around to it.
    IHATEPROPANE and wildwest like this.
  3. 343amc
    343amc
    Northeast Lower Michigan
    Curious, how do the solar panels hold up to hail storms? Is the top layer glass or some type of composite?
    Looks like it'll work out good for you. Saving a few bucks is always a plus.
    Smokey - I figured with all your computers, wireless doodads and DLNA streaming apparatus that you'd have an electric bill that would make people cringe. And here I've been happy with my highest electric bill this summer being $109. :)
    IHATEPROPANE, schoondog and wildwest like this.
  4. wildwest
    Good news is we used alot less since the new pellet stove last fall. Bad news is your yearly bill is a couple months for me in the winter.....
    IHATEPROPANE and SmokeyTheBear like this.
  5. schoondog
    schoondog
    Dutchess County N.Y.
    I have a bud that I spoke to at the AdirondackNationals and he said the same thing. He and his wife lead a much different life now that we do. It seems the further north you go or perhaps the more rural you go the cheaper electric gets. I guess I'm livin in the fast lane. !!
    Doggy
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Nope most of my doodads are low power devices, router handles the DNLA and one of its radio is on a schedule and the other is off. I'm thinking about swaping it and the cable modem out for a combined unit which should cut the power usage in half over what I have now. My computer auto throttles when the need for compute power drops, my printer spends most of its time either off or in deep sleep mode. The 47" smart tv uses very little juice and its screen can be shut off when I'm playing music.
    IHATEPROPANE, wildwest and 343amc like this.
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Maine isn't noted for cheap power rates.
  8. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I replaced the motors on mine with lower power consumption ones.
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Your Use Last Month 367 kWh
    Similar Households 870 kWh
  10. schoondog
    schoondog
    They are some kind of composite and there is an aluminum frame around them so they can be put together on the stands. I asked how strong they were and the lead tech told one of the installers to show me how strong they were. He stepped up on one. Slight bending and no breaking. Pretty impressive.
  11. wildwest
    Its either papadave or imacman , one of them here has similar low electricity usage.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Impact resistance is different than what is needed with some weight is placed on the material. Keep us in the loop on how it performs.
  13. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Micro or edge inverters?
    wildwest likes this.
  14. schoondog
    schoondog
    hmm not sure its a Frontius Primo 10 k watt. I wouldn't call it a micro. Its got wi fi and works with a transmitter / router to give Solar City and me data.
    jtakeman, IHATEPROPANE and wildwest like this.
  15. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It is a whole system unit. The micro ones are per panel, then there a group of panels ones sometimes called edge. The micro units allow the array to function through certain kinds of faults including shading issues at a minimally reduced output. The edge ones handle a small number of panels are between the micro and whole system units. Another advantage of the micro units is it is easy to add to the array. I don't know what your average sun hours per day are, the often quoted figure for my location is 3.5 hours. So to cover last year's usage I'd need a 3KW array or 12 of those panels. I've looked at this backwards and forwards and a twenty year simple payout doesn't work for us, if I was going to be around until about 95 it would have already been done. The tech needs maintenance, the panels degrade over time, and failure rates of the parts is not zero, did you get the tax credit or does the company you had do the work own the equipment until end of term? That is another thing I try to run a zero income tax scenario this is known as don't empower the idiots in those funny places called legislatures.
  16. imacman
    imacman
    Denver, NC
    My average elect. bill from Central Hudson when I was at the previous house w/ the pellet stove was approx. $140/2 months. Dryer was propane. Stove was Jenn-Air electric.
  17. wildwest
    I've been paying $150 every month this summer to soften the bills for the winter. Also, I moved my main sitting spot to a warmer location, I am hoping that will help since we can keep the house temp lower.
  18. imacman
    imacman
    Denver, NC
    Hopefully that means a spot in front of the pellet stove......such cozy heat!! :)
    SKEETER McCLUSKEY and wildwest like this.
  19. IHATEPROPANE
    IHATEPROPANE
    My electric bill is $160 a month or so, and last winter they jacked the rates for the winter and it was over $200.
    jtakeman likes this.
  20. IHATEPROPANE
    IHATEPROPANE
    Just checked my bill. My daily usage is 32.1 kWh for a daily cost of $5.78:faint:
    will711 and jtakeman like this.
