Solar Kiln Firewood Drying
Discussion in 'The Wood Pile' started by Uncle Augie, Sep 2, 2014.
  1. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    Don't we have results that prove the concept already? 30+% to 21% in 60 days in the fall is pretty much all the results you need, or am I wrong?
    bigbarf48 likes this.
  2. firecracker_77
    firecracker_77
    IL
    I think you have a great idea here. No reason to take a defensive stance when the results prove you know what you are talking about.
    cnice_37, splitoak and Stinny like this.
  3. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    I'm honestly asking, not getting defensive at all. You said "we will know the truth soon". Is that indicating you don't believe the data presented already, or that you need additional evidence before you will believe I am "telling the truth "?
  4. firecracker_77
    firecracker_77
    IL
    I read some results posted a few weeks back and was sold on the idea then. It's a good idea, and if you scan this thread, there is a bit of hostility which is out of place when the results are there now and will be conclusive by thanksgiving. I'm not disagreeing with your method or the proof.
  5. Hunker down
    Hunker down
    Long Island
    Does the wood have to be newly split to check the moisture with a mm. Not sure if this question belongs here? And pretty novice. I know.
    firecracker_77 likes this.
  6. bigbarf48
    bigbarf48
    Stone Mountain, GA
    To get an accurate reading, yes you'll want to check on a fresh split face. The outside of a split dries quickly, the interior is what you're really concerned with
    wildwest, HDRock and splitoak like this.
  7. Hunker down
    Hunker down
    Long Island
    Thanks. Hope I didn't disrupt the conversation.
  8. bigbarf48
    bigbarf48
    Stone Mountain, GA
    No problem, welcome to FHC :thumbs:
    wildwest and splitoak like this.
  9. firecracker_77
    firecracker_77
    IL
    That's a good question....
  10. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    Fear not, this thread has taken many detours along the way. We seem to find our way back to the path eventually. And yes as mentioned above a fresh split face is best. A MM is actually just a meter checking the electrical resistance of the wood. Because it is the water trapped in the wood that decreases the measure of resistance, and because that wood escapes from the outside in, testing the exterior give you a lower measurement than the true moisture content of the split.
    Or the above may be overly complicated, and all you need to know is to test in the middle of a freshly split chunk. Look for under 20% for best burning, under 25% will burn but will need more air and you should check your flu more often, over 25% is considered a NO-GO by most here but if the choice is that or freeze...you will struggle but it should burn, above 30% is pretty much all smoke and no heat. Remember, the higher the MC the more often you need to check and clean your chimney / flue.
  11. ailanthus
    ailanthus
    Shenandoah Valley, VA
    I don't think that's a concern:confused:.
    Cool topic & very enlightening...
    wildwest likes this.
  12. chris
    chris
    SE WI
    Getting down to 20% is the pinch area for a stove like the NC30. These become a ballistic heat machine when down to the 15% range. Likely similar for a lot of the newer non cat stoves.
  13. Hunker down
    Hunker down
    Long Island
    How often should I check chimney/flue? It is a week and a half old
  14. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    You are a brand new burner? My first season I checked ever two weeks until I felt confident, then every 4, now I check every other month if the roof is free of snow. If I know snow is coming ill check it just incase I can't get up there for a couple of months.
    Learn how to sweep your flu your self and you will save Texas $$$$$$$
    milleo, HDRock, fox9988 and 1 other person like this.
  15. milleo
    milleo
    Maine
    Yup...What Ungle Augie said, Check often till You feel comfortable....
  16. firecracker_77
    firecracker_77
    IL
    If you have a Class A chimney, you would be able to sustain a chimney fire for at least 10 minutes. No one would ever like to say that, but that's what it was designed for.
  17. Hunker down
    Hunker down
    Long Island
    I'm glad I asked. I was not aware it was so often. Especially in the beginning. Makes sense
  18. dutch
    dutch
    Central NY
    Augie I've been following the thread and it got me thinking, can you get larger rounds down to the teens in the kiln too? Rounds that normally would be too big to completely dry out just with air drying.
  19. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    The larger the split, the longer it will take, but given enough time/heat I am sure that you can get any size down to the teens.
    splitoak and dutch like this.
  20. dutch
    dutch
    Central NY
    That's what I was thinking, may try it with some big ones for overnight burning
    milleo likes this.
