So I bought a 660
Discussion in 'Chainsaws and Power Equipment' started by JoshC, Nov 17, 2014.
  1. mdavlee
    mdavlee
    Yeah it was all over AS. I don't know if any of the 66s had 288 pistons in them.
    DexterDay likes this.
  2. Freakingstang
    Freakingstang
    I actually wasn't talking about a 288 piston.....
  3. mdavlee
    mdavlee
    The others require a bit more work.
  4. Freakingstang
    Freakingstang
    I know... That's why I don't have a piston for my 385 jug that's sitting here...:D
  5. komatsuvarna
    komatsuvarna
    No, Actually i dont, Kennis. Sometimes I wish I did.:(.
  6. komatsuvarna
    komatsuvarna
    All 18 pages of it? :popcorn:
    Seriously, no pizzing contest here, just some friendly poking.:pete:
    cgraham1 likes this.
  7. JoshC
    JoshC
    Culloden, WV
    Dang. Well you all enjoy. I've got the info i needed.
  8. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Hang around. Some nice saws you have there and lots of good info here :thumbs:
    Kg461, cgraham1 and JoshC like this.
  9. bigbarf48
    bigbarf48
    Stone Mountain, GA
    The 660 looks to be cutting about what I'm used to in that sized wood
    Kg461 and JoshC like this.
  10. the GOAT
    the GOAT Banned
    Maine
    Yeah but if any of those saws were snellerized there is a chance they are slower then stock.
  11. komatsuvarna
    komatsuvarna
    Yours look about right to me. Ususlly 70cc is as fast as 90cc or sometimes faster in that size wood. They just have different powerbands. Strap a bigger bar on them and put them and bigger wood and the 66 will pull away.
  12. JoshC
    JoshC
    Culloden, WV
    I clicked Unwatch thread, but i'm still getting alerts. I guess i have to. LOL
  13. komatsuvarna
    komatsuvarna
    Brads personal 66 was about 10th place or so. A lot of saws cut in the low 30s and thats where Brads was IIRC. They was also a box stock 66 there. I think all the saws but maybe 2 were faster than stock and those 2 had running problems.
    Randys winning 066 cut was 24.xx seconds.
    Then out came a TM390xp and wiped all the field out.:)
    Ron660 and mdavlee like this.
  14. DexterDay
    DexterDay Administrator
    Northeast Oh
    I would invest in a tach. That 660 is eating well, but still sounds fat. That 372 is turning more RPM in the cut..
    Even when you are not applying a lot of pressure (pushing with finger) , you are still locked in the dawgs and pulling on it. So there is a significant amount of leverage. The best way to make a cut to test speed or tune, is to keep the bar as level as possible and apply pressure, but keep the RPM up in the upper range. Rocking the saw and using leverage will slow the times, and apply more pressure to the cutters.
    As Staff, I apologize for the derail. But just about every thread gets derailed. Unless it's only a page long. To have one of the longer threads here, it is a compliment to your saw :)
    Honestly, I apologize. I will start a thread later to take the banter out of yours.
    mdavlee, bigbarf48 and JoshC like this.
  15. cgraham1
    cgraham1
    Nor Cal
    It happens on every forum. This derail is pretty harmless. I've seen some on AS that were...
  16. komatsuvarna
    komatsuvarna
    Josh, Those 660s are severely plugged up compared to the older 066s. If your muffler hasn't been modded, the factory outlet is not much bigger than a #2 pencil! Those saws need to breath.
    Cut the baffle contraption out of the muffler and Putting a dual port muffler cover on them make a big difference.
    The spark timing is a bit lower on the poly flywheel 660s than the early model metal flywheel redlight 066 saws. Advancing the timing a bit will help it some too.
    The muffler mod helps more than the spark advance, but both do make a difference.
  17. JRSDWS
    JRSDWS
    Central Illinois
  18. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Must be a sign huh :rofl: :lol:
  19. Freakingstang
    Freakingstang
    we told him that 18 pages ago....
    the GOAT and Moparmyway like this.
  20. the GOAT
    the GOAT Banned
    Maine
    Dual port, 8 pin... You can lead a horse to water but the ms362 is awesome!!!!
    Freakingstang likes this.
