So I bought a 660
Discussion in 'Chainsaws and Power Equipment' started by JoshC, Nov 17, 2014.
  1. JoshC
    JoshC
    Culloden, WV
    You not an eco boost fan Stang? My buddy has one, it's a pullin machine.
  2. mdavlee
    mdavlee
    Yep. If I had a 660 here to test against the 372 I'd do it. It wouldn't be real fair with the 372 being ported though.
    DexterDay, cgraham1 and Moparmyway like this.
  3. Moparmyway
    Moparmyway
    New York
    Same type of bar ................
    I will cut to the chase ...........
    Setting a saw with the tach is what the factory recommends, and they are in business to sell saws - kind of a conflict of interests for us isn't it ?
    Setting your saw with a tach does not account for the type/length of B&C nor does it account for the wood you are cutting
    When a saw does more work, it needs more fuel.
    IMHO, you can use a saw set to factory specks with a tach and it will cut, but will it cut at top performance ?
    We are allways trying to squeeze out more power from our saws, and I am allways seeing reccomendations for people to set their saws with a tach.
    Setting a saw to operate under the load it will see requires tuning in the wood ............
    this tach thing is so overrated - especially for someone who knows how to tune a saw.
    If we are going to teach someone how to adjust their saw, why not do it the best way ............... OK who judges the best way ?
    Let the saw(s) speak for themselves ............... when they scream, shut 'em up with more fuel until they sing a good tune of 4 stroking and clean running under load, then look at cut times. This thread is a perfect example of how not enough fuel will make any saw roll over and puke
    Lastly, just grab an IR temp gun and point it at your favorite spot on the cylinder ............... I will wager that you will see lower temps (which means longer life) with the saw tuned in the wood compared to a saw tuned with a tach, especially with an increasing load !!
    There will be times that tuning with the tach and tuning in the wood will be the exact same adjustment, but if you load up your saw (like we all do with longer B&C and dogging in) and you tuned with a tach, it probably could use more fuel and you probably will have a cooler running saw with better power by tuning in the wood you are cutting
    JoshC and mdavlee like this.
  4. Freakingstang
    Freakingstang
    and not to be a nerd, but to put into perspective I 'll add a few bits.
    Hp is a calcuation derived from Tq.
    Torque is a measurement of work done, usually in a rotational aspect. (think of torquing a bolt to spec). Horsepower is the measurement of the rate the work is done. example, It took 4 hp to torque the bolt to 40 ft/lbs.
    Torque is what does the work, such as moving a car or truck from a standing stop to accelerating, cutting wood, building pressure in a hydraulic system, etc. Horsepower is what keeps the car, saw, etc moving. The more torque an engine makes, the higher the HP will be. there are many variables, but that is the gist of it. That is why when you look at the 660 dyno graph, the rpms at which they all peak is different, because the engine flow characteristics have changed with porting, muffler mods, etc, so the time at that rpm has changed. . In the cut rpm is the torque and that's what we all care about at the end of the day. as you increase airflow and fuel in porting or muffler, it changes the rate of change in time of torque and thats why the rpm differ between the three saws for the horsepower measurement.
    cgraham1 and mdavlee like this.
  5. mdavlee
    mdavlee
    When I tune by ear I always end up 500-1k rpms under spec.
    Moparmyway likes this.
  6. Moparmyway
    Moparmyway
    New York
    :drunk:
    Hopefully on the fat side !
    :saw: :saw: :saw: :saw: :saw:
  7. mdavlee
    mdavlee
    Yeah big time. Once they get to 12k plus I can't tell that much difference until they get to quit 4 stroking. The 372 the other day hit 15.2-15.4k. I tuned it down by ear and was at 12.4k. I used the tach to get back up to around 13.7k. It runs better around there. It will 4 stroke way on up there.
    cgraham1 and SquareFile like this.
  8. SquareFile
    SquareFile
    somewhere
    I was amazed how fat I tuned my saw once I bought a tach.
    DexterDay, Moparmyway and mdavlee like this.
  9. mdavlee
    mdavlee
    That was me. 13k sounds like 15k
  10. Kg461
    Kg461
    Provencal, La.
    Mike u sayin the ported 372 would rough it up? How bout if the 660 was ported in wood under 25? I mean 21cc more has to mean something??
    mdavlee likes this.
  11. Freakingstang
    Freakingstang
    Good post. I rarely ever use my tach since getting rid of my 7900. I hated that rev limiter for ear tuning. A saw that is pig rich is no good either. but I always found if I checked my saws set by ear with a tach, they were lower rpm than spec
    I'm not. Two buddies have them. both with tuners. They get v8 gas milage and won't hold their own towing like everyone states. one guy hauls an enclosed race car trailer, the other hauls skis and quads on hunting trips. both 8-10K loaded. they won't hold 70mph, they get 6-8mph. I'm not a fan and I'm a ford guy. I love turbos, just not a fan of the eco-pukes. not for someone that has a truck they use. now for a soccer mom that hauls kids and the occasional load of firewood, sure they are ok, i guess. i'm don't like the raptor either, another posser truck. all that awesome stuff to do cool things and they are never off road or haul anything. they are trophies driven around that say, hey, look at my status.
  12. 94BULLITT
    94BULLITT
    Frederick County, VA
    There was a thread on AS last week and the guy tested a 660 against a 461 with various bars, chains, and wood. The 660 outperformed the 461 everytime.
    Ron660 and the GOAT like this.
  13. 94BULLITT
    94BULLITT
    A new 5.0 F-150 will outperform an old big block even with a load. A 6.2 would definately run away expect a raptor would be way overloaded with 12k, it can only tow 8k.
  14. lukem
    Whatever....try doing this in a Silverado:
    ;):picard::rofl: :lol:
  15. cgraham1
    cgraham1
    Nor Cal
    For heavy loads, a Diesel engine is the clear choice. For dropping the kids off at school and running to the grocery store, I'm sure the ecoboost is wonderful. :eek:
    Oh, and that raptor costs dang near as much as a fully loaded f-350 diesel!
    Drvn4wood likes this.
  16. JoshC
    JoshC
    Culloden, WV
    That's weird. His gets 10-11 towing 10k. He took it from WV to FL to pick up a tractor he bought along with a bunch of attachments. Never dropped below 4th gear the whole trip, even crossing the WV mountains from VA, and still got 10MPG. The empty mileage isn't anywhere near what they claim though.
  17. Freakingstang
    Freakingstang
    ding ding ding...
  18. Freakingstang
    Freakingstang
    I like the idea of the truck. I hate that they are 3x the price that normal working people can afford. I hate that people that have them are a bunch of posers in general, and 99% of them won't tow a thing, ever see off road or drags strip. I didn't say they weren't 100% kick azz. i'd love to have the motor, or the suspension on anything but the reality is its a status symbol for people.
  19. lukem
    Not sure if you watched the whole video, but I agree with you. Some people got more $ than brains/need for a true off road machine.
  20. DexterDay
    DexterDay Administrator
    Northeast Oh
    The 660 only shines in wood above the cut off of the other saw.
    That's why a 461/460/372/7300 wins most every time. Once the demand for higher torque comes in? The smaller saw suffers.
    But a 70 cc saw that runs more RPM (more chain speed), in wood that doesn't push it past it's max torque/HP, will win over the 660..
    How big of wood were they cutting? Both stock or modded?
    Was it Redbull660? Maybe that's why he sold me that 461 ;)
    Drvn4wood, mdavlee and Kg461 like this.
