So begins the trailer rebuild.
Discussion in 'The DIY Room' started by Pallet Pete, Mar 4, 2018.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I’d agree!
    :jaw:
    eatonpcat, Horkn and raybonz like this.
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    BTW my company supplied me with 11 pair of FR jeans plus 11 FR shirts.. Most of the jeans are Carhartt and a couple pairs of Wrangler FR jeans..
    Horkn, brenndatomu and Pallet Pete like this.
  3. raybonz
    raybonz Moderator
    Carver, Mass.
    Lots more reviews here.. For the money it's a great deal!
  4. Pallet Pete
    Ovid
    Yeeaaaa:whistle::whistle: I don’t have anything other than a FR $10 bib :rofl: :lol:
    Horkn, brenndatomu and raybonz like this.
  5. raybonz
    raybonz Moderator
    Carver, Mass.
    Because I am exposed to possible arc flash hazards I am required to wear FR clothing.. The fab guys get them as well..
  6. Pallet Pete
    Ovid
    Was just eyeballing it looks pretty cool indeed! I am blown away buy all the china boxes available now:jaw: That welder looks like it will do you well.
    Something I learned on the old cheapo jobsmart was the ground clamp SUCKED. When I put a better on on it the welder was like a new machine..
    That might be part of your problem if you haven’t already changed it.
    leoht and brenndatomu like this.
  7. Pallet Pete
    Ovid
    Well that’s awesome! :thumbs:
  8. raybonz
    raybonz Moderator
    Carver, Mass.
    The ground clamp seems OK.. I attach it to a vicegrip type work clamp but if I have to replace it HF has a good looking clamp for short money..
    400 Amp Welding Ground Clamp
  9. Pallet Pete
    Ovid
    Yup that would work great!
    Something else you can do is weld a bolt or piece of scrap to your project to clamp to then when your done cut it off and grind the area flush.
    I do that on some projects. The trailer I welded a bolt to the frame so no matter where I am welding I have a really stable ground without the need to grind an area clean every time the welder needs to be moved.
    milleo, Chvymn99, leoht and 2 others like this.
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    Good idea Pete! I have been clamping my work down tight and attaching the ground to this clamp.. Keeps the clamp like new this way too.. Like the welding helmet so far.. Reacts really fast and has 4 sensors.. Not a bad price..
  11. Pallet Pete
    Ovid
    4 sensors all the way! My old HF helmet is identical to that one and has 4 sensors hmmm can’t go wrong with that!
  12. Horkn
    Yep. Arc flash. All cotton.
    I like using FR beer
    Chvymn99, Beetle-Kill and Pallet Pete like this.
  13. brenndatomu
    I'm sure you have insulation in your garage already...I use rubber hose or fuel line...whatever I have around.
    I just take a piece of line, cut a short piece off, say a 1/2" or 3/4" long piece, thread the wire(s) through it, then work the rubber into the hole in the frame. I like the hole to be just a smidge smaller than the OD of the hose...stays in place real well that way. You can also slice the hose lengthwise to put it over an existing wire so you don't have to cut the wire, or unhook it...but I prefer to not slice the hose...stays in place better I think.
    papadave, Chvymn99, Chaz and 3 others like this.
  14. Pallet Pete
    Ovid
    That’s what our welders have at work but I only weld in emergency situations on call. At home I probably should get a jacket but i am too cheap.
    Actually along those lines I had an idea of still using OSI but shoving 1/4” fuel line through the center to hold the wires. :whistle:That wouldn’t go anywhere but would be easy to pull wires out if needed later. Completely redneck...:rofl: :lol:
  15. raybonz
    raybonz Moderator
    Carver, Mass.
    Have to look at the tags but thought it was Nomex material.. Very hot and heavy jeans and shirts!
    Horkn and Pallet Pete like this.
  16. Horkn
    Nomex? Yeah, that's hard core.
  17. brenndatomu
    OSI?
  18. Pallet Pete
    Ovid
    Rediculassly awesome hard core caulk and foam. Developed for a window company then went public because it’s so tuff. I’ll never use anything else again this stuff is just about bullet proof...
    Product Categories | OSI
    huskihl, milleo, Horkn and 4 others like this.
  19. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    FR beer , that's how I roll....:smoke:
  20. brenndatomu
    Duly noted...:handshake:
    Horkn, raybonz, Chvymn99 and 2 others like this.
