Snowy bike ride, 30°
Discussion in 'Everything Else (off topic)' started by bogydave, Nov 20, 2015.
  1. bogydave
    Studs worked well, no slip & slide & went up & down hills OK.
    Rode 14 miles. Some spots had a few inches of snow, pretty hard hard pedaling thru it.
    Good workout, feels like I did 30 miles
    Slow riding, rear derailleur iced up. Disc brakes were no problem
    It'll be better after they plow the paved paths.
    Eric VW, milleo, Chvymn99 and 5 others like this.
  2. Well Seasoned
    Thats pretty cool Dave!
    Eric VW likes this.
  3. papadave
    I remember when I was about 13-14 and still had my paper route.
    Delivering a saddle bag full of Sunday papers in several inches of snow and slush riding my bike was not fun.
    That looks like it might be fun.
    Eric VW, milleo, Stinny and 3 others like this.
  4. HDRock
    Did you just get those studded tires this year?
    papadave likes this.
  5. bogydave
    Yes
    Low tire pressure so the studs make good contact
    This was my first ride in snow
    A lot slower, different kind of workout.
    14 miles was more like 30 miles, feels like you are pedaling up hill all the time. (Snow & low tire pressure)
    Not much downhill coasting either .
    Probably be better after the snow sets up. Sometimes they plow the paths, that would help
    Was dressed just right in the beginning, then overdressed - removed layers, the it cooled down - layers back on.
    Need to try to avoid slush, it ices up the derailleurs.
    Don't turn when you hit a 3" snow drift, it's like like sand.
    2 hour - 14 mile ride , avg was way slower than what I'm used to
  6. papadave
    Yep, hardcore.
  7. HDRock
    Maybe you should try just a little more air, might work better might not
    Eric VW and NH mountain man like this.
  8. bogydave
    Yea
    toying with the right pressure
    38 psi good in shop at 65°, get softer in the 25° snow
    Had 38 psi, not sure what they were when I got home.
    Hands got cold, ended up with heavy ski gloves
    Hands in one position not moving much,
    Now looking at pogies
    Eric VW, NH mountain man and HDRock like this.
  9. bogydave
    Pogies
    Can ride bare handed or when real cold wear gloves
    Work on snow machines too
    Eric VW, papadave, milleo and 3 others like this.
  10. HDRock
    Those are real nice man :thumbs:wish I had some of those when, Riding on the motorcycle on the freeway one time 45 degrees and raining slightly, I had to pray my fingers off the throttle, I had gloves on but they were not cold weather gloves
  11. bogydave
    Might be nice for the ATV as well
  12. HDRock
    What kind of shift levers do you have will those work OK with shifting?
  13. NYCountry
    NYCountry
    Mohegan Lake NY
    Good for you. That looks like a real good work out...
  14. bogydave
    Local bike store had a high dollar set on one of their fat bikes
    They slide over the brake & shift levers then zip/tie/velcro down snug to the handle bar.
    Hands slip inside protected for the wind with plenty of room to operate the brake shift levers.
    Like anything, they make hard core well insulated ones (-20°) high dollar ones down to neoprene ones for $30.
    Mid range pair:
    http://www.amazon.com/Bar-Mitts-Mou...UTF8&qid=1448130495&sr=1-4&keywords=bar+mitts
    HDRock and papadave like this.
  15. Backwoods Savage
    Dave I may have to check on those for the atv. I had some similar but they did not work all that well. One other problem is when plowing snow, the left hand needs to be outside the cuffs to operate the winch.
  16. bogydave
    Local bike forum guy just gave me a good idea
    1st pogies were winter coat hoods
    Says the Carhart snap on hoods fit well over the handle bars, I have a couple from my working days.
    May give them a try.
    Yea
    be great for plowing snow on the ATV !
    For Snow machines too
    HDRock likes this.
  17. Backwoods Savage
    I have a couple of them so might give it a try.
  18. bogydave
    When will you get cold weather ?
    dropped to 29°. Blizzard here right now
  19. HDRock
    8 inches of snow on the ground at my place, 31 out right now, overnight low of 25
  20. bogydave
    Oh
    Wasn't watching the forecast. Saw a pic of an inch or so,
    looked like pretty wet snow.
    8" & 25° definitely qualifies as cold weather .
    "WINTER" has arrived
    We got about 4 more inches.
    Forecast is for 12° tonight, maybe another inch or 2 of snow.
    Looks lie your back up to 50° on Thanksgiving.
    That goods or bad ? :yes:/:( ?
