Snow blower advice
Discussion in 'The DIY Room' started by Pallet Pete, Oct 24, 2019.
  1. chris
    chris
    SE WI
    last old simplicity I reworked I ended up having to torch the wheels off the axles, I even made a puller out of 1/4" plate all it did was make nice "U" bolts out that and the hubs were red hot. Carb has now succumbed to the ethanol death- have a replacement carb ( briggs motor) if as the tecumseh mill I would not bother, but no time to dink with it.
    Horkn and Pallet Pete like this.
  2. Pallet Pete
    Pallet Pete Moderator
    Ovid
    It should do nicely in the snow.
    It has been done!:D
    I took a fluid film bath...
    There is a bend in the sheet metal just below the rubber it hits nicely the rest of the way around and was defining for about 2 minutes of burn in time.
    After I added the plastic shoot back on it got loud again and may break the clip inside but I don’t much care it doesn’t do anything at all the bolts hold everything right.
    343amc, Thor, Horkn and 4 others like this.
  3. Pallet Pete
    Ovid
    Here’s the video after it’s broke in.
    Stinny, Thor and eatonpcat like this.
  4. Pallet Pete
    Ovid
    Also in the tear down I discovered to my dismay that the auger belt on it from the factory was a vbelt with drive teeth. The blower has no drive teeth and is simply a v belt. The assumption here is that they used what they had at the moment to get it out the door.
    After I stuck a regular v belt in the impeller got MUCH faster.... it is noticeable how much more power it has now vs before.
    Thor, Horkn and eatonpcat like this.
  5. Pallet Pete
    Ovid
    After two wet snow blows today I can say it throws about 10’ when wet and heavy compared to just falling out of the shoot before that. It appears to work great!
    343amc, Thor, Horkn and 3 others like this.
  6. Need2Saw
    Need2Saw
    Central Michigan
    I have a toro snowblower. The 8HP tecumseh started 1-2 pulls after every summer. It did run a little rough for the first couple of uses but settled out.
    I’ve heard stories of people that love and hate them.
    Glad you got your working better. Might need it a lot this winter, never know!
    Pallet Pete, Thor and Horkn like this.
  7. MikeInMa
    Just fired up my Troy bilt. Started right up for me, thankfully. Hoping to change the oil before needing to use.
  8. Thor
    Thor
    Genoa City,Wi
    I used mine for the second time yesterday. Wait till the snow is powder. Put a big smile on face when the wind took the snow into my neighbors driveway. :D
  9. Need2Saw
    Need2Saw
    Central Michigan
    SnowMaster | Toro
    this new toro snowmaster has me intrigued. It’s supposed to be faster than a 2 stage and more capable than a conventional single stage. For the snow storms in central Michigan, I think it would be more than capable.
    Thor, Horkn and Pallet Pete like this.
  10. chris
    chris
    SE WI
    been out a couple years already, MY only gripe is the personal pace stuff- seems there is something going on there because I see so many personal pace mowers up for sale + I have a friend that had one and was not happy with it. I consider it about akin to the adaptive steering system and Four wheel drive on my little suv. Had it a couple years now still do not know who it has adapted to. particularly the 4wd
    When it comes to Winter weather in WI, I prefer the KISS principal.
    Pallet Pete likes this.
  11. Need2Saw
    Need2Saw
    Central Michigan
    The personal pace is a main reason I’m interested in this new snowblower. The old school friction disc drive system is slow for my average amount of snowfall.
    Pallet Pete and Horkn like this.
  12. chainsawsoldier
    chainsawsoldier
    NE Kansas
    On a different subject, those mud flaps make good top cover on stacks- the ones from semi trailers don’t usually blow away.
    Pallet Pete, Need2Saw and Thor like this.
