Small engines, fuel with ethanol.
Discussion in 'Chainsaws and Power Equipment' started by My IS heats my home, Dec 31, 2014.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
  2. rookie1
    rookie1
    The stabil will keep the gas fresh but still won't help with the alchohol. There is an additive that is supposed to keep the alchohol mixed but I can't think of the name.
  3. raybonz
    raybonz Moderator
    Carver, Mass.
    MTBE?
    Butcher likes this.
  4. Butcher
    Butcher
    Well no matter what any one thinks about the fuel they buy it is a fact that once lead was taken outta the fuel and then MTBE was also taken out you got what you got. Use a fuel stabilizer as needed and just use a little common sense when storing fuel and running it in a machine. Even diesel and kerosene have a shelf life. Think off it this way, if you was thirsty and found a gallon jug of water that you had lost in the back 40 maybe 6 months ago, would you pop the top and expect it to be good?
    Horkn and My IS heats my home like this.
  5. Ryan R
    Ryan R
    Halstead, Kansas
    The lead in 100LL causes its own problems, as does the bromine they add to it. I personally wouldn't run itbin anything but an aircraft engine, and I have my own personal issues with it there as well.
  6. rookie1
    rookie1
  7. Cut4fun
    Cut4fun
    OHIO Redneck
  8. yooperdave
    Just like Butcher, I also was not concerned about the "new 10% corn additive" in gas and everything was always just fine. Until the lawn mower and snowblower figured out that they don't have to put up with that damm corn additive! Since that time, I use "corn free" in any engines that may sit for awhile-splitter, chain saw, mowers, atv's, snow blower, and also add sta-bil to them before the storage season. Life is good again.
  9. raybonz
    raybonz Moderator
    Carver, Mass.
  10. Butcher
    Butcher
    All STIHL gasoline-powered engines can be used with up to a 10% (E10) blend of ethanol in the gasoline/engine oil mix. We also recommend that if a unit will be left unused for more than 30 days that it be stored "dry." This means emptying the fuel tank and then restarting and letting the unit run until all the fuel is consumed and the engine stops. For maximum performance and engine life expectancy we also recommend using STIHL Ultra 2-cycle engine oil with built-in stabilizer.
    Note: STIHL recommends use of fuel with no more than 10% ethanol content. Using fuel with greater than 10% ethanol content may cause damage to your equipment and may void your STIHL warranty. Learn More…
    I copied this from the stihl web site. Now, just cuz it was printed on the interweb don't make it so but neither does the hoopla about all the demons of ethanol that get bantied around. I have a 4 year old walk behind snow blower in the shed that the owners manual and on the gas cap recommends the use of E10 fuel since that is how they built the engine to run on. Ethanol based fuels are a fact of life any more like it or not. You just need to know how to store it, use it or go back to cutting farwood like a caveman. That is just my 2 cents worth. I don't want to break the rules of this forum but iffn a person don't like the fact that the gas they purchase has ethanol in it then you should contact your senator or congressman since the ethanol industry is so highly subsidized by your tax dollar.
    Me, I just live with it cuz I buried a dinosaur awhile back and it aint turned into oil yet. Go figure huh?
    Horkn, mike bayerl, 343amc and 2 others like this.
  11. dgeesaman
    dgeesaman
    Elizabethtown, PA
    While I agree that getting the ethanol out of all fuel would be a political matter, you can still buy non-eth fuel. Patronize the places that sell it and they will keep selling it. Politics is one unstoppable force, but so is supply/demand.
    David
  12. yooperdave
    Thanks Butcher-I have never done that with my chainsaw. Never knew you should run her dry before storing.
    As far as the waiting for the dino to turn into oil, maybe if you spread some compost with it, it'll speed up the process!
    raybonz likes this.
  13. MasterMech
    The ethanol issue is complicated and wrought with half-truths and misinformation.
    Many of us do not have E-free gas within a reasonable distance and either have to pay out the azz for canned fuel or just run the E-10. It's not the end of the world but if given the choice, I will pick E-free every time.
    ALL modern automotive fuel has a lousy shelf life compared to the days of MTBE and prior. I don't care if it has ethanol or not, if it's going to sit more than 60 days, burn it. You can treat with additives like Sta-bil, Startron and the like and I highly reccomend that you do. Ethanol sure doesn't help the storage issues any but if you have poor storage habits anyways, you will have problems regardless of your fuel blend.
    Storing fuel in a can, plastic or metal, under the oak tree in the backyard is not a good start. Fuel should be stored in a sealed container, so don't leave the vents open. At the very least, the most volatile parts of the fuel will evaporate over time, reducing the fuel's octane rating and power output. If you store in a high-humidity area, then you are likely to get condensation in the container and over time, it does add up. Temperature matters too so if your tool shed hits 140deg in July sun and drops to 50-60 something at night, that only amplifies the breathing/condensation process that turns fuel bad.
    Store your treated fuel in a cool, dark location in a sealed container and you will eliminate most if not all of the trouble. No additive that I know of will protect from lousy storage conditions, and yes, the best time to treat fuel is right after you buy it.
    Storing fuel in dormant equipment is not recommended either. Now, this statement does not mean you need to drain/run dry every tool you are not using this week. If a piece of equipment is going to sit for a few weeks in between uses, you are most likely fine with just treating your fuel with an additive and then running it dry after the season is over. You should however, keep fuel tanks either empty, or full. Full tanks leave less room for the tank to "breathe" reducing the amount of atmosphere exchange and condensation.
    Ther is plenty more to this issue but the main point is good storage habits make workable solutions for those of us that have little choice but to run ethanol blended fuels.
    Horkn, Butcher, mike bayerl and 4 others like this.
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    Well said MM!
  15. chris
    chris
    SE WI
    Another part of the equation is the ethanol is added at the distributor, and some are getting very sloppy about the %. This is already documented if ya care to look it up. Between the water attraction and the ethanol attacking various soft parts of the fuel system AND that ethanol causes your engine to run much hotter than without it + the new EPA regs = self destruction.
    XXL, Drvn4wood and raybonz like this.
  16. Sunfish
    Sunfish
    Success Mo
    I keep 20-25 gallons of non-E gas here all the time & I treat it with Marine Sta-Bil. It gets rotated with-in 6 months or so... Don't know if it helps or not, but I'm going to keep using it.
    I had some trouble with a 40hp four stroke Yamaha outboard motor from 2003 to 2008. The trouble was traced to ethanol in the un-treated gas. I've had a 25hp 2 stroke Mercury since 2006 running non-E treated with Sta-Bil. No trouble at all & it has gas in it year around.
    Drvn4wood and XXL like this.
  17. My IS heats my home
    My IS heats my home
    Albany, NH
  18. My IS heats my home
    My IS heats my home
    Albany, NH
    Is this fuel stabilizer any different than Sta-bil (as is) found on the hardware store shelf?
    Do these work differently with ethanol?
  19. jetjr
    jetjr
    Pa/Md line
    I like to use the startron stuff. I buy it at a marine store and get it a little cheaper than buying the small bottles at Walmart/Lowes.
  20. My IS heats my home
    My IS heats my home
    Albany, NH
    What does that stuff do for fuel?
