Small Engine Question?
Discussion in 'Chainsaws and Power Equipment' started by IHATEPROPANE, Aug 7, 2015.
  1. IHATEPROPANE
    IHATEPROPANE
    I have a small inverter generator. I thought it was seized but after taking the casing off and starter rope off I can see the piston move when I crank it by hand. Thing is, it will not pass the top of the cycle. Is there a simple fix? Disclosure: I am not in the least knowledgeable in the subject, which is probably Pretty obvious.
    Eric VW and eatonpcat like this.
  2. ironpony
    ironpony
    Mid Ohio
    Possibilitys something in cylinder broken valve or cam
    Tooth on cam or crank gear
    Eric VW and IHATEPROPANE like this.
  3. IHATEPROPANE
    IHATEPROPANE
    I was looking for a minor adjustment lol. Probably just donate it.
  4. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Wrong plug which may be hitting the top of the piston?
    MasterMech, Eric VW and IHATEPROPANE like this.
  5. IHATEPROPANE
    IHATEPROPANE
    It stops even without the plug.
    Eric VW likes this.
  6. rookie1
    rookie1
    Interesting. You can turn it both ways until it comes close to top dead center?
  7. Guido Salvage
    Guido Salvage
    2 or 4 cycle? If 2, pull the muffler and see if you have a ring snagging the exhaust port.
    Horkn, Eric VW and IHATEPROPANE like this.
  8. IHATEPROPANE
    IHATEPROPANE
    Yes indeed.
    Eric VW likes this.
  9. IHATEPROPANE
    IHATEPROPANE
    Four cycle
    Eric VW likes this.
  10. Guido Salvage
    Guido Salvage
    Time to pull the head...
    Horkn and Eric VW like this.
  11. IHATEPROPANE
    IHATEPROPANE
    I took it apart from the muffler side. There are four gears there and a couple of them have sheered teeth. Wonder if it is lodged somewhere it shouldn't have.
    Eric VW likes this.
  12. rookie1
    rookie1
    Bummer
    normanscag and IHATEPROPANE like this.
  13. IHATEPROPANE
    IHATEPROPANE
    Yeah, but no big deal. Always better when they can be fixed for cheap. But I had already written it off so it was mostly used as a learning tool. I Never opened up a small engine before.
  14. Horkn
    There was nothing on top of the piston preventing it from getting to TDC?
  15. IHATEPROPANE
    IHATEPROPANE
    Nothing I could see
