Small engine, no spark
Discussion in 'Chainsaws and Power Equipment' started by jo191145, Oct 8, 2024.
  1. brenndatomu
    I dunno...I'm not so sure a copy of a Honda isn't better than a B&S right off the bat...
  2. Lehman
    Lehman
    Minnesota
    All made in China and I’m not so sure the Briggs isn’t made by lifan like the predator. Cub and toro have their own branded engines made by lct which is the company that bought out the left over techemseh stuff. Briggs is owned by a large holding firm right now but i wouldn’t doubt Stihl purchases them along with the Ferris zero turns. For a cheap engine the Briggs as good as anything. Put a new Briggs just like this in place of a lyfan on a log splitter, thing had some hours on it and it just quit. Everything matched up perfectly with the old engine stuff.
    Horkn, morningwood and brenndatomu like this.
  3. Scotty Overkill
    It's gotta be a simple wiring issue, or a low oil switch or something easy. Check all that stuff out before dropping coin on another engine....
    Might even be the coil which isn't real hard to replace.
    Horkn, jo191145 and brenndatomu like this.
  4. jo191145
    jo191145
    Ct
    I think you’re right but this motor is 2021. Not very old. But the top yellow wire does go to a ground screw. The black one ran inside the engine shroud to where the coil probably is.
    So as I see it that black wire is everything. The low oil is connected in some fashion to it also,,,,,must be, only wire going anywhere.
    I guess it wouldn’t hurt to cut all the wires and see if that works before I replace it.
    I’ve been second guessing myself today. I was thinking maybe it’s the low oil because I had lowered it down which changed the angle of the engine.
    But then I’m thinking hey the only wire that runs inside the engine is off and it ran like that. How could the low oil sensor be working with no wire running to the engine?
    So I went and bought the dang predator engine.
    im wondering if that black wire that tore loose left a few strands behind and they’re shorting out inside somewhere.
    I also noticed when I took the new plug out there was some strange black residue inside already. Like wood dust. Wasn’t hard carbon but it’s black from carbon but softish. Air cleaner doesn’t seem to be leaking. I only ran it a few minutes but did rev it up.
    It was running rich/black but not too bad on the old plug. This motor has been run at just above idle for its short life. It’s all you need to run a conveyor. Maybe that’s not too good for em.
  5. jo191145
    jo191145
    Ct
    unless crud is getting in the engine you’re right. It’s something simple. The pain is the time it would take to figure it out and the engine needs to be removed to work on it anyway. It’s tucked under the conveyor where I can’t get to it too well. Someone who works on them often may be able to do it but I’m dumb on little 4 strokes.
    And finding a small engine repair around here is not easy and they’re usually booked for months. Plus the money they charge. And the few that are left are in more urban areas where they have no room for 25’ of conveyor LOL
    For 149 bucks I have a predator in the box. I think it will be easier and faster to swap than fix. Maybe I’ll give the other one to some kid that wants it.
    Horkn, MikeInMa and brenndatomu like this.
  6. jo191145
    jo191145
    Ct
    Another question. Before I pound the snot out of this clutch is there an Allen set screw behind it? I see a tiny hole. Can’t imagine a set screw that small,,,,,,much more getting it loose.
  7. brenndatomu
    Got a pic?
    eatonpcat, Horkn and jo191145 like this.
  8. Warner
    Warner
    BFH is always the answer!
  9. jo191145
    jo191145
    Ct
    Many years of BFH will fix it. In this case a spot light told me this was a tiny set screw behind the clutch. Luckily I bought a set of super long Allen wrenches 30 years ago. Unfortunately I haven’t seen them in 25 LOL
    A friend is a machinist from a long line of machinists. Doesn’t mean they know much about centrifugal clutches but they do have every tool known to man in an antique velvet lined box.
    We got it off. Tomorrow I put it back together.
  10. Horkn
    Right? Then again b&s has some engines made in China. So a Chinese clone of a Honda, is better than a Chinese clone of a Chinese made US branded engine. Yeah, probably.
  11. Lehman
    Lehman
    Minnesota
    I’d save that 950 and bring to the nearest Briggs dealer, has a 2 year consumer warranty. They have a cast iron sleeve in them and forged crank not cast like the 212 predator. While china built it is built to better specs metal wise and has 9.5 ft lbs torque vs 8 to go with the. 6.5 hp. Been quite awhile now that they have torque rated small engines in the USA. Gives you a better idea how much work they can do and a better way to compare brands. Test the torque it makes at 2800rpm on them all, the hp rating wasn’t accurate a lot of times because they would over rev to get it ect. Not say hp couldn’t be rated at the same rpm like the torque is now but it wasn’t and some 12 hp engines out did 14hp. All new Briggs series numbers are the tq rating I believe 950 is 9.5, 1150 is 11.5 and so on.
  12. jo191145
    jo191145
    Ct
    Now that the motors out of the frame I was able to shine a light down the plug hole. Engine seems to have accumulated black carbon on the piston. I imagine that’s from running at just above idle all the time. I’m wondering if when I revved it up a bit and some of that carbon broke free if it didn’t kill the new spark plug? Noticed this new plug is somewhat defective right out of the box. Insulator is skewed to one side, not centered. Weird, thought it was broken, it’s not. Maybe it’s just me but I think spark plugs are more susceptible to failure these days compared to years ago.
    Well except for the 2 stroke dirt bikes,,,those failed often too.
    I’ll have to test that plug in another engine, see it it sparks.
    brenndatomu, MikeInMa and eatonpcat like this.
  13. Lehman
    Lehman
    Minnesota
    is it too fast at higher rpm? If not it probably would be better to run at 1/2 throttle or so, also giving it a sea foam treatment through the carb once and awhile would help also.
    brenndatomu, eatonpcat and jo191145 like this.
  14. jo191145
    jo191145
    Ct
    yeah it’s too fast IMO. There’s no need to put all the rest of the machine through that much extra stress. The conveyor belt alone probably costs as much as three or four engines LOL
    Sea foams a good idea. I may even tinker with the carb adjustments, not something I like to do but wouldn’t hurt to learn.
  15. Lehman
    Lehman
    Minnesota
    The carb adjustments won’t do much if it’s to fast depending on style of drive you could add a jack shaft and do a double reduction to get rpm up and keep belt speed down all while adding torque to keep load moving. I’m surprised the company would sell it not geared properly because idling any little 4 stroke extended periods isn’t good.
  16. jo191145
    jo191145
    Ct
    I was thinking adjust to run it leaner. I also think you’re right. Running it slow all its life isn’t that good for the engine. Maybe the rings never got to seat properly? I was using synthetic in it also thinking I was doing it a favor by springing for the good stuff LOL
    It does have a jack shaft reduction. Could always try to find a larger pulley for one side to gear it even lower.
    These are made by a one man outfit in his barn. Usually comes with a 3.5 Honda but they were unavailable during Covid. I wonder if the clutch for a 3.5 Honda comes with a slightly smaller pulley on it? That may have messed up the normal gearing.
    predator is on and running. Started first pull, that’s a good sign. I’ll have to check the plug after awhile and see what it looks like. I’m using standard oil for this one
  17. MasterMech
    All wires that lead to the ignition module/coil are just connecting various devices (oil level shut-off, ignition switch(es), etc. to each other and the kill/grounding terminal in series. Remove the blower shroud, disconnect the small wire at the coil/module, and it will be permanently "on". Connect to one side of a switch, connect the other side of the switch to ground, and you have a simple, manual on/off control.
    Likely from using the choke to kill it. This floods the engine with fuel and for a few seconds there, it'll run rich before it shuts off, and for a bit after restarting until the extra fuel burns off from the intake tract. This also "washes" the cylinder walls in fuel, and causes oil dilution. This increases wear, and reduces the life of the engine oil.
    brenndatomu and eatonpcat like this.
  18. MasterMech
    Regarding Chinese (or Japanese, [any KOTH fans out there? :rofl: :lol:) engines vs Briggs/Honda/Kawi/Rolls Royce etc.
    If you don't have the knowledge to understand how the ignition systems, carburetion, or governor systems work (no hate, just the way it is in some cases) - I wouldn't be too concerned about how "good" the engine is to start with. It isn't long for this world anyways, after the first minor issue and resulting "fixes". A premium engine isn't going to accept the abuse of grossly over rich (or lean) fueling, diluted oil, clogged air filters, or mal-adjusted governors any better than an economy unit. Better off just buying a 2nd engine to put on the shelf and just replace the first one.
    And we wonder why 90% of the market is cheaper clone engines these days....
    Sandhillbilly and brenndatomu like this.
  19. Lehman
    Lehman
    Minnesota
    My kohler command pro 14 on my sawmill is made overseas too. Runs nice and I’d like to think a little better built than the average Chinese engine but maybe not.
    brenndatomu and MikeInMa like this.
  20. MasterMech
    Are we talking about one of these?
    They do have some nice features, and that cyclonic filter is probably well-utilized on a sawmill. Most modern small engines run just fine, even the cheapest clones. Heck, we're buying sub-$20 carburetors off Amazon that seem to work fine.
    But these modern-ish engines are replacing these which is the comparable "classic" US-built Command Pro engine. One could argue that the extended life offered by the full-pressure lube system (with filter) and the maintenance free valvetrain (hydraulic flat-tappet lifters) was seldom realized on an air-cooled engine in a dirty application with less than awesome maintenance. And finding a horizontal crank single-cylinder small engine with a full pressure lube system, is pretty rare these days.
    OEMs have given up on a lot more than just US labor. Small engine repair is a rough business in 2020+. Replacement engines are cheap, OEM service parts are expensive, labor to repair is both a risky and expensive investment. As a result, anything under about 20HP is built to replace vs repair and if it makes it to 500hrs, it's considered a good run. Engines that are well cared for still make it to 1,000+ hrs, even without some of the nicer build quality from yesteryear. When was the last time you saw balance shafts in a small-engine? They were pretty common in premium engines from 40+ years ago. (Kohler K-Series anybody?) Stuff like special heat-treating of bottom-end parts, Stellite exhaust valves, hydraulic valve-trains, oil coolers, etc. are GONE from the market (and all existed previously!) because they just were not what was selling engines, OEM or aftermarket. The customer wants it to start first pull, run quiet, and develop adequate power. Oh, and it better be cheap, because the first time it coughs wrong, it's getting replaced with a Harbor Freight Predator anyways.
    My rant wasn't to hate on any specific engine model/brand, just pointing out that quality doesn't sell anymore since they ALL are considered pretty disposable these days. Engines like the old Kohler K-Series, Magnums, Wisconsin's, etc. are long extinct along with the supply of rebuild parts (over/under size parts for these were once nearly as abundant as they were for automotive engines) for them. Most of the applications where those engines earned their reputation for being immortal are now filled by small, liquid-cooled diesels.
    brenndatomu, Lehman and MikeInMa like this.
