Sketchy trunk
Discussion in 'The Wood Pile' started by Sirchopsalot, Aug 16, 2021.
  1. Sirchopsalot
    Sirchopsalot
    medium city in CT
    So I called the fellow from whom my spring score came. We had a tree he wanted to work on together. But, he had another tree on the ground that needed dealing with. Red oak, some of it cut up, all the brush gone.
    But the trunk gave me the willies. I've never gotten surgical on wood, but this was.the time to cut a little, see how it reacted, cut a little over there to release the tension, and stayed ready to move quick if something was about to release.
    Essentially, the tree fell and twisted. 22" around.
  2. MikeInMa
    I hope it's not too rotted inside.
  3. Backwoods Savage
  4. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Rot extended from the stump maybe 3'. And thats where it broke. Everything on the ground is solid.
    After the pictured cuts, I made a handful of relief cuts just to take the tension out. Nothing popped or snapped. But it could've been nasty. I stayed well at arms length to the side, and was prepared for the saw to move unexpectedly.
    Sca
  5. buZZsaw BRAD
    Sometimes those can be tricky. Read the log carefully to see active and reactive forces. Prop with stickers under log if possible. EDIT: which i see you did. Much easier to buck elevated than if directly on the ground. Use my "door stop" wedges to keep the kerf open to avoid pinching your saw. Nice that it split open. Probably dry rot and/or ants inside. Been my experience with bigger oak. Wish i was closer id help you out.
  6. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Looks like it will make nice firewood.
  7. sirbuildalot
    sirbuildalot
    Mass
    Reading the title I thought you were buying black market jewelry or sumtin'
  8. MikeInMa
    I figured a sickly elephant. :rofl: :lol:
  9. Eric Wanderweg
  10. T.Jeff Veal
    Good job, brother. Got some pre-split...that's a bonus.
    Sometimes you have to plunge cut in and then down to relieve the tension. Glad you got it done safely.
  11. Eckie
    Eckie
    x 2
  12. billb3
    Sometimes the high BTU wood is a little extra effort/time.
  13. amateur cutter
    Nice work getting that apart safely. We've got 4 or 5 similar trees to get off properties yet from storm damage. Finally got all the real hazard trees finished up so that's good.
  14. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Funny.
    I like it.
    Sca
  15. Sirchopsalot
    Sirchopsalot
    medium city in CT
  16. Sirchopsalot
    Sirchopsalot
    medium city in CT
    It was definitely an abundance of caution type job.
    Mostly cut up as of this morning. A.bit of splitting and a few more cuts, and we're done. Cord and a half so far.
    Sca
  17. amateur cutter
  18. billb3
    I like the wood wedges. I've used wood door stops in a pinch ...
  19. buZZsaw BRAD
    When i gave some to Ctwoodtick when we met up he asked me "what am i going to do with doorstops"?
    A tradition now when i meet up with a new FHC member. Those are actually cut off scraps from rafter birds mouth cuts!
    Slocum, MikeInMa, T.Jeff Veal and 2 others like this.
  20. MikeInMa
    You need to make them "official".
    Get out a wood burner and etch in the FHC logo.
    buZZsaw BRAD and T.Jeff Veal like this.
