Size of splits
Discussion in 'The Wood Pile' started by Tasmaniac, Jun 3, 2014.
  1. Grizzly Adam
    Grizzly Adam Guest
    I wish, chipper would be great but I can't imagine selling much due to the giant pile for free at our tree dump.
    jetjr likes this.
  2. firecracker_77
    firecracker_77
    IL
    I like small splits as I can get the stove hotter and they dry quicker as mentioned before. The main seasoning months appear to be May - November around here. Then, it's cold enough that seasoning slows. I don't always split them small before seasoning though. Sometimes, I split them smaller right before they go into the stove. They catch much faster that way and when starting without coals, I can get my room up to temperature a lot faster that way.
  3. WVhunter
    WVhunter
    Mountains of WV
    Ahhhhhhhh, I misunderstood. No my house is not really big enough for two stoves. It is a single story old farm house, I remodled. It is only about 1200 sq ft, stove is located pretty much in the center.
    Well Seasoned likes this.
  4. Tasmaniac
    Tasmaniac
    Tasmania
    Gotcha
    WVhunter likes this.
  5. Well Seasoned
    WV- We run in a similar sized house...... stove centrally located, mostly open concept.
  6. Tasmaniac
    Tasmaniac
    Tasmania
    Do you generally load the big ones after that?
  7. firecracker_77
    firecracker_77
    IL
    Yeah...that's a fair statement. Once I have coals, I can get away with burning about anything except for real big logs. My stove isn't that big to hold decent heat with the bigger rounds. They all need to be split at least once or quartered. I am not as far ahead as you are and we have less than perfect drying as pointed out by someone else. For some reason, I picture Australia as dry enough, that you can get that wood seasoned way faster.
  8. Tasmaniac
    Tasmaniac
    Tasmania
    Getting over the hurdle of having a enough put back so you have ample to time to dry your wood is the key it seems in a lot of states where the people here reside. Could be a good reason to take out a small loan with the low interest rates you have there to get established in wood and have the piece of mind. A $3000 loan over 3 years would barely be $10 a week in interest.
  9. Paul bunion
    Paul bunion
    It get my logs from a tree guy. He puts most everything <15" into his chipper, he says it is easier for him to dispose of that way. No such thing as limbs in his loads.
    I like to split them a bit larger than what I see a lot of others doing. I think it burns longer and is easier to control. It is also fewer individual pieces to handle so it is less work overall. I can stay far enough ahead so getting it seasoned isn't an issue. Just have to keep the rain off it and it keeps getting drier.
    jetjr likes this.
  10. Tasmaniac
    Tasmaniac
    Tasmania
    I think that's how most tassies must view it too.
  11. firecracker_77
    firecracker_77
    IL
    How big is your stove cubic footage wise though? That is a key factor. My brother burns big logs in his, but he's got 4 cubic feet to play with. At 2 cubic feet, I have to keep them smaller by nature. I think moisture and size of the firebox are key for me, plus whether I have that all important coal bed to work with.
  12. Grizzly Adam
    Grizzly Adam Guest
    We split all of Dad's really small because he is just looking to start a quick fire in his garage and get fast heat. He says when he uses big splits by the time it finally gets going good he is done with his work.
  13. firecracker_77
    firecracker_77
    IL
    I would tend to agree with that. I want small hot fires until I get the coal bed, and then you can stretch them a bit, but there is a point at which the big splits don't hold the stove top temps up high enough, and I have to go back to the smaller splits.
  14. firecracker_77
    firecracker_77
    IL
    Certainly won't get creosote issues this way. What is the typical temp in the garage when he starts and by the time he finishes his work a few hours into it?
  15. Grizzly Adam
    Grizzly Adam Guest
    Very cold and warm :) last year it was so cold he had to plug in the diesel heater because it was too cold for arthritic hands to start a fire.
  16. Backwoods Savage
    We like a few larger splits or rounds for overnight burns but if we don't have any, we still get along just fine.
    Keep in mind that the stove will also determine what size you should burn. The newer stoves with more control do just fine with smaller splits.
    WVhunter and splitoak like this.
  17. splitoak
    splitoak
    jefferson co wv
    Ive been tryn to square spit in the 3×3 to 4×4...and put a biggun in for overnite...my stove is not huge either..
  18. firecracker_77
    firecracker_77
    IL
    We have the same stove set-up...even the same saws. I'm not running a flue damper.
    splitoak likes this.
