Single digit temps first of 2016 what are you roasting ?
Discussion in 'The Pellet Bag' started by will711, Jan 4, 2016.
  1. Rich250
    Rich250
    Berks County PA.
    Real good, took a weeks worth of tuning but its dialed in now
  2. Smokinpiney
    Smokinpiney
    "South" Jersey
    Put a bag of independence softwoods in last night. I've been saving them for the single digits. They burn HOTTTT :thumbs:
  3. bogieb
    -21* here this morning. Woke up about 4 am (after my normal time) and raised the feed rate to both stoves to 2. The house had "cooled" off to 71* - with it being 67 in the bedroom. I recently turned feed rate the main floor stove back down to 1.5 as it is 73 in the middle of the house and 69+ in the bedroom. Did leave the bedroom bay window curtain open last night so the poor plants wouldn't freeze, so that lets in a bit of extra cold to compensate for.
    The window isn't the big heat loss factor; it is the floor over the garage (that is cold on the tootsies - I can feel exactly where the floor transitions from conditioned basement to garage. Makes for planned path thru the bathroom since it directly straddles the partition - tub side is warmish and the vanity side is cold.
    IHATEPROPANE, ttdberg and slvrblkk like this.
  4. artc
    artc
    Rocky Hill, CT
    -10 this morning. I let the oil monster run for the upstairs MBR to keep that attic heat exchanger warm. don't need a burst pipe. 67 downstairs with the 52I trying to catch up. prolly should have upped the feed from 3.5 to 4. But when I used only the oil, (they size them for 0 degrees around here) with these temps and wind would have the burner on at 100 percent and loosing some ground, so i'm liking the dual heating plants.
    ttdberg, will711, slvrblkk and 2 others like this.
  5. will711
    will711
    Pocono Mts.
    Just in time for this Arctic Blast :yes:
  6. schoondog
    schoondog
    Dutchess County N.Y.
    I don't like flannel lace ! ;)
    Doggy
  7. subsailor
    subsailor
    Winthrop, Maine
    Are you talking feed rate or heat setting? Actually it doesn't matter. How do you keep your house warm with either of the set at 1.5 or 2? I always leave my feed rate at 4 and last night I had the heat setting at 4.5. Is your house super insulated?
    slvrblkk, IHATEPROPANE and ttdberg like this.
  8. bogieb
    Setting for stoves during this cold spell: During day; stove temp (fan high) / auto, heat setting at 70* and feed rate at 0.5-1.0. During evening I raise the feed rate to 2. Keep in mind, I was running DL's in the basement stove and Vermont's / LaCrete's during those two cold days. The main floor stove has given indications that it is past that good stuff and back to PTL's, so I'll find out when I get home how well a feed rate setting of <1 worked today. I also get good solar gain during this time of year, which is a blessing.
    No super insulation in this 2x4 built R13 (I know, I put it and a vapor/air barrier in last year). Basement walls are insulated with R5 rigid foam and the concrete floor is not insulated at all. The ceiling to the main floor is acoustic tiles instead of sheetrock, which allows a lot of cold air to drop down from the attic. The 2 places I can't physically feel the air coming down from the ceiling are the hall way and bathroom, both of which are sheet rocked. The attic has R19 insulation but it isn't laid down well - another thing I have to fix at some point. Does have 90% new windows and all 3 exterior doors are new with 2 new storm doors (door to garage doesn't need one). I also insulated the sill pretty good.
    I have a small house - the upstairs is 950 sq/ft and the basement 650 sq/ft. The main floor stove is situated on one end, and the air flow is pointed directly down the centrally located hallway into the bedroom door at the other end of the house. Plus, since the basement is unfinished the mainfloor floors warm up a bit from the downstairs stove when the P61 is in constant burn mode.
    slvrblkk and IHATEPROPANE like this.
  9. subsailor
    subsailor
    Winthrop, Maine
    I just don't see how you can heat your house, any house at a feed rate of .5 to 1. IIRC the feed rate on Harman's indicates the lbs./hr fed to the stove. Therefore at a feed rate of 1, you should get 40 hours out of 1 bag of pellets. Maitenance burhn on my stove will eat a bags of pellets in 24 hours. Harman recommends setting the feed rate at 4.
    slvrblkk and will711 like this.
  10. will711
    will711
    Pocono Mts.
    Totally agree with you Sub , I know this was discussed here a few years ago , I'll find that thread . Just set the rate at 4 and leave it alone turning it lower and the stove will under feed .
  11. will711
    will711
    Pocono Mts.
    slvrblkk, subsailor and IHATEPROPANE like this.
  12. subsailor
    subsailor
    Winthrop, Maine
  13. will711
    will711
    Pocono Mts.
    This is my take on adjusting the Feed rate of a Harman , don't over think it :whistle:
    if you do You're doing it wrong :thumbs:
  14. bogieb
    I know you guys mean well, but I have been thru all that and used those settings. I don't think the Stove temp / auto mode is well understood (I know I don't) - heck, I just learned about it a couple of months ago because older manuals don't even mention it as an option.
    All I know is at the feed as low as it will go, the middle of my house is 77 degrees right now and the stove is doing a maintenance burn at all times with my being able to control the fan at all times (going thru about a bag in 24 hours). I couldn't live in here if the feed rate was set higher (been there, done that).
    Tomorrow morning I will be switching to Room Temp / auto - heck, might be doing it tonight if the temps rise another 5 degrees. Them, the feed rate will go to 3 on the P43 (small pellets) and 3-4 on the P61 (varied pellets).
    IHATEPROPANE, slvrblkk and will711 like this.
  15. will711
    will711
    Pocono Mts.
    Hey ,what ever works for you girl friend that's all that matters :thumbs: :handshake: I go against the norm too I don't have an OAK nor do I want one .
    Bottom line is are you warm ?? Don't matter how you got there :yes: :drunk:
  16. slvrblkk
    slvrblkk
    Northampton, PA
    We're gonna have to get you oak'd up at some point but before we start we'll have a couple :cheers: and game plan the project :D
    artc, bogieb, IHATEPROPANE and 2 others like this.
  17. will711
    will711
    Pocono Mts.
    Of 30 packs :drunk::drunk::drunk:
  18. slvrblkk
    slvrblkk
    Northampton, PA
    Nothing will get done but a bunch of smoothies being consumed :rofl: :lol:
  19. will711
    will711
    Pocono Mts.
    That sounds like a plan to me :drunk:
  20. slvrblkk
    slvrblkk
    Northampton, PA
    :drunk:
    IHATEPROPANE, ttdberg and will711 like this.
