Single digit temps first of 2016 what are you roasting ?
Discussion in 'The Pellet Bag' started by will711, Jan 4, 2016.
  1. jtakeman
    :eek:
    :doh:
    Did you just jinx yourself? o_O
  2. IHATEPROPANE
    IHATEPROPANE
    Most likely :headbang:
  3. Pete Zahria
    Pete Zahria
    New Hampster
    I hate it when that happens......
    Dan
    bogieb and ttdberg like this.
  4. ttdberg
    ttdberg Pellet Pig
    CT
    Man I hope you are right on that.
    jtakeman and bogieb like this.
  5. oldspartantrader
    oldspartantrader
    Northern NY
    Looks like it will miss the lake area by 50 - 100 miles.
    HOWEVER
    The snow blower is gassed & ready, couple hundred pounds of pellets are within easy reach, backup power is on alert, and we are mentally prepared.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    Thought I'd bump this back up since we'll be in negative temps this weekend. I have a couple bags lined up of PTL softies and then will probably roast some LaCrete after that.....only if I have too, don't want to waste them :D
    wildwest, CleanFire, will711 and 3 others like this.
  7. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    chows and oakie platniums
  8. ttdberg
    ttdberg Pellet Pig
    CT
    Vermonts in the P68, Vanderhoofs in the P43. This cold snap is two stove weather around here. Burn em if ya got em!
    :fire:
  9. oldspartantrader
    oldspartantrader
    Northern NY
  10. jtakeman
    Sets are doing fine. Woke up sweatin this AM.
    Gotta try an avoid burnin em all up and get us some shoulder stuff to ride out the spring.
  11. ttdberg
    ttdberg Pellet Pig
    CT
    JT, have you checked any local HD stores for FSUs or chows?
    CleanFire and IHATEPROPANE like this.
  12. IHATEPROPANE
    IHATEPROPANE
    I hope I will burning Blazers. I am away in Florida and am depending on the BIL to keep the hopper filled.
  13. slvrblkk
    slvrblkk
    Northampton, PA
    Hmmm, since you are away I might send >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> :vulture: especially for Blazers :D
  14. Pete Zahria
    Pete Zahria
    New Hampster
    Absolutely.
    They don't do you any good laying on the floor.........
    It was 1° here this morning, and it's going to be colder next couple of days...
    What the heck would we be waiting for to burn your best stuff??
    It was cold enough here for me to touch the stove off in the shop.
    I have stuff in there I do not want to see freeze..
    Haven't done it but a couple of times this season..
    It was 30 in there yesterday... dumped some DF's in it yesterday pm,
    this morning it was 60° in there... Nice!!
    There are two cars in there... that is a lot of mass to bring up to temp...
    Dan
    ttdberg, wildwest, CleanFire and 2 others like this.
  15. IHATEPROPANE
    IHATEPROPANE
    I will be watching........
  16. bogieb
    Turned the ThermGuard on yesterday to run the FHW every 6 hours to keep the pipes in the garage from freezing.
    Loaded DF's in the Cellar Dweller and Vermont's into the main floor stove. None of that stuff will hit the fire until sometime tomorrow. Looks like I will have timed it just about right as Sunday morning and Monday Morning are slated to be the cold ones.
  17. artc
    artc
    Rocky Hill, CT
    EasyBlaze SYP in the hopper till Monday at least.
    i have a hydro-air heat ex-changer in the attic for upstairs zone of the oil burner. it hasn't run this winter at all. but it has water in it, which has concerns me when burning pellets. i insulated the sh$% out of it and kept the plumbing super short but i still woke up this morning with a little worry in my head. the coil lies in the duct work and thus is warmed by the heat from below and i had the HVAC guy install the 40 degree no freeze fix that is supposed to start the circulater and open the zone valve. BUT it has not been tested. sooo i worry a bit. I set a hold of 64 degrees on it, and might up that to 65 for Sat night just to circulate the water in the system a couple of times. I'll sleep better. Oh, and i closed the automatic water feed to the system so if something bursts, it will not continue to pump water into the house....
    bogieb, ttdberg, IHATEPROPANE and 2 others like this.
  18. will711
    will711
    Pocono Mts.
    That sounds like a good plan , I might go as far to make sure that it does run , test it now :yes: and really sleep good :sleeping::sleeping:
  19. will711
    will711
    Pocono Mts.
    You're Saving them :yes::yes::yes: :rofl: :lol::rofl: :lol::rofl: :lol: I am :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    bogieb, ttdberg, slvrblkk and 2 others like this.
  20. slvrblkk
    slvrblkk
    Northampton, PA
    At this rate I'm going to have certain pellets for years......Turman, PTL softies, LaCrete....hope they don't go bad :rofl: :lol:
