Simple pallet firewood rack
Discussion in 'The Wood Pile' started by Rowerwet, Nov 29, 2017.
  1. SkidderDone
    SkidderDone
    Pollock Pines
    Looks great! I did pallets and cross stacked the ends this year. It worked well but because I hand split it was a real pain getting the ends sturdy. I'm going with pallets and tposts next year so stacking is easier.
  2. cre73
    cre73
    Central Il
    0951ED27-407C-414F-BC24-3B22EBDB8051.jpeg On the crates I build, I set them on other sacrificial pallets. Most have lasted about three years or more that way. This one is for shorts and uglies the others are built more open to allow easier stacking.
  3. Firewood Bandit
    Firewood Bandit
    Nice work Rowerwet.
    I just crib up the ends. Plant a little bit while splitting and save the nice big square splits that are consistent in size.
    T.Jeff Veal, savemoney, Maina and 3 others like this.
  4. Hookedup24
    Hookedup24
    Bucks county, PA
    Quality build. I think Makita has sold 8 billion of that model impact driver. I see them everywhere including my garage.
  5. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Added another rack to the end of the last one yesterday, then split another half cord or so in the beautiful spring weather.
    This rack will be my sixth cord for next year, if I don't have to break into one to finish up the season .
    T.Jeff Veal, Mag Craft, Maina and 3 others like this.
  6. NH mountain man
    NH mountain man
    WMNF N.H.
    Looking good! Nice neat setup.:yes:
    Maina, savemoney and Rowerwet like this.
  7. Rowerwet
    Rowerwet
    Seacoast NH/MA
    My problem is that I get guys from my church and my kids to stack, and some refuse to learn, while others just can't quite get it.
    This makes it easy and painless
    Maina and NH mountain man like this.
  8. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    FDCCBCEA-EFA3-44B0-8625-F2965FF77CCF.jpeg 5150A4EF-16DA-4C49-A388-E5DCD8FED90B.jpeg This is what I ended up doing, keeps it all off the ground and no tools or screws required. It’s practically free , for me anyway. Get 2x4 from work off freight trucks and the block company in town gives me cull blocks for a dollar or sometimes free. The wood pushing out when stacked ties it all together. Sketchy on uneven ground is only draw back I have had. I stack about 6’ ish.
    shack, Rowerwet, Chaz and 3 others like this.
  9. Rowerwet
    Rowerwet
    Seacoast NH/MA
    I would expect a block to fail at some point , they aren't the strongest that way.
    My luck, the ice would get in and shatter the blocks
  10. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Never have had that problem but I suppose it could happen. Here in NE Oklahoma the spring storms are the biggest problem, they can scatter one pretty quick.
    Rowerwet, Maina and Backwoods Savage like this.
  11. cre73
    cre73
    Central Il
    1EE6A225-D392-4CEE-864D-AFC5492351A4.jpeg Here is a pic of both styles of my racks. You can see both the front and back of them depending on how they were on the tractor when I brought them over.
    Maina, mikeward, savemoney and 4 others like this.
  12. Rowerwet
    Rowerwet
    Seacoast NH/MA
    U Have A 13 Yr Old Son To Fill and retrieve my racks, probably not cheaper than a tractor :)
    Maina, savemoney and Backwoods Savage like this.
  13. Backwoods Savage
    Enjoy it. He won't be around much longer as he will be out on his own. But hopefully now and then he'll come back and help Dad a bit.
  14. Rowerwet
    Rowerwet
    Seacoast NH/MA
    I have guys in my church who come by when they are bored, and plenty of people asking for donations.
    I'll pay for work, or give food from the church pantry, I actually get some work out of some of them
    Maina and savemoney like this.
  15. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Following in the cheap vein that this rack follows, I came up with the cheapest stack cover possible.
    We get deicing fluid for the aircraft I work on in IBC totes, and they don't want to pay to ship them back empty because of the hazmat shipping issue, so they give them away.
    I removed the internal tank
    Maina, Lone_Gun and leoht like this.
  16. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20180224_155551.jpg the tank is rectangular in shape, stand it on end
    Drill a hole in each corner of the end panel.
    Drill extra holes around the tank drain valve to make it easier to cut around it
  17. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Connect the corner holes with a saw blade
    Cut around the drain valve area
    Instant play house
    Maina likes this.
  18. moresnow
    moresnow
    Are you going to cut the tank in half from corner to corner for two triangular water shedding caps over the filled rack? I've got two in the backyard I plan on giving that treatment. They look like they work well for a few guys.
    Apparently not. Your photos must not have showed up when I was replying. Odd.
  19. savemoney
    when you are ready to make your move north, you might be able to forget the worries of termites. I have never seen them and don't know of anyone bothered by them. We have black flies that will try to eat you up, but I not aware of termite issues.
    Maina and WeldrDave like this.
  20. savemoney
    I bet I could find use for a few of those metal cages for the garden! I haven't seen them around here, but then I don't get out much.
    Maina likes this.
