Simington square grinder
Discussion in 'Chainsaws and Power Equipment' started by Rope, Dec 27, 2018.
  1. Rope
    Rope
    Alaska
    They look way meaner in hand than the photo. 56517068-A252-41F7-8F90-194645D60F6D.jpeg 316E2C4C-C251-4BBC-96EA-F2E7CA8D9B3F.jpeg 432CB08F-0305-4FF2-A502-38A34B976F1E.jpeg
  2. Rope
    Rope
    Alaska
    I made some test cuts yesterday, I am happy with it. Things will get better as I tune it to my conditions and wood. I am 7 chains into this journey. Only 53 more sharpenings and it’s paid for.
  3. The Wood Wolverine
  4. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    The handfiled pics on the last page would cut Good in red cedar or aspen/poplar and red alder. And by good I mean hoggin out big long noodles fast. But will dull faster in hard or hard frozen wood. The last ground ones on the last page are Great !
  5. Rope
    Rope
    Alaska
    Some Stihl round file that I converted over to square grind and filed out the gullet. 56621535-8232-4A70-A0F7-6D112BA39EC4.jpeg 165595B8-5DA6-4C9C-8D36-EA39AB2125F0.jpeg 73AE9FA4-DAF1-4E48-A9A2-61152B1272B1.jpeg
  6. Rope
    Rope
    Alaska
    Have been cutting after work, using one of the above chains on a ported 261 by huskihl . Today is the third day of cutting, I have been using between 1/2 and 5/8 a tank per day. Chain is still sharp, I am cutting standing dead spruce and live birch. Will be interesting to see how much I can cut my frozen wood before have to sharpen. The chain is self feeding well, nice and smooth cut.
    I have no regrets going down this journey. I am amazed at just how much faster a ported saw with a square grind is.
  7. dall
    dall
    West Virginia
    lol your still a slacker lol
    T.Jeff Veal and Rope like this.
  8. Rope
    Rope
    Alaska
    This is true.
  9. Rope
    Rope
    Alaska
    Was at the log pile bucking and splitting when I found one of the kids toys with the ported 461 with square grind. What I noticed on the snow was the safety yellow wood chips, I giggled to myself thought that will teach them to leave toys on the log pile. I go about bucking about 4-5 more logs, shut the saw down. Idle up the splitter and get to splitting rounds, after a bit see some yellow under the snow. I am thinking how much is this going to cost to replace on of the kids favorite toys. B91ACC3E-34A3-48C7-95E7-D62DEC25D42C.jpeg
    Nope it’s a sledge, thought I was lucky to not cut the handle off when I noticed the shinny spot. Then I thought, there goes that chain....no I cut 4-5 logs after I saw safety yellow wood chips in the snow. FB09FE35-567C-4643-A57D-F4FC4FAE1688.jpeg
    The deepest part cut is 3/8. And looked like this. BD26C6C3-A496-4446-B370-35E4E327B85F.jpeg F22E587E-C14A-4B4B-99F3-DA1B12D3BBDC.jpeg
    The chain is one from Dall, that he sent me last winter, have been running that chain on the 461 to see how the angles hold up. Today is the first time to sharpen it.
    Thankfully Dallas and Kevin have helped me with my grinder and have the angles set the same on mine. I was able to grind the chain with no issues. A quick touch up and that chain is ready to go.
    I decided while I was at it to convert a .325 chain over to square grind for the 024 super. Here is the sledgehammer grind on the .325 chain. The wheel profile and swing arm angles kept the wheel out of the straps. AEB96679-A8AF-4CBC-9898-91A2E784FBB8.jpeg BF649EF8-D6CA-4F71-AAD2-89F5147A8AF3.jpeg 1EC69BEA-8A3E-44D3-BEA2-5A92683989DD.jpeg FA4A6D2C-E819-4DDB-A25A-E5D09A49B440.jpeg 841579E2-CA67-43EE-A58D-6F9DACA1641D.jpeg
  10. concretegrazer
    concretegrazer
    Southwest MO
    Looking good Tom.
  11. Rope
    Rope
    Alaska
    Thanks Mark.
    T.Jeff Veal likes this.
  12. Salisbury Sugarworks
    Central NH, USA
    Hi all,,im new here,,should be getting a simington 451 c the end of the week..i have been reading all the threads i can find and am very greatful for ths knowledge here..im sure ill be picking your brains later
  13. Duane(Pa)
    Duane(Pa)
    Centre Co.
    There is a huge thread over on the OPE forum in the “just chains” section. Tons of info. Be sure to watch the vids on the Simington web site too.
  14. Salisbury Sugarworks
    Central NH, USA
    Hi Duane,,thanks, i read 57? Pages twice and took notes..the only thing that o dont quite grasp is how the dressers work/opperate,,but i think when i set it up i should be able to figure it out..if not i will ask here...
    I am really surprised there are not more hand filing square or grinding square videos on youtube...been working on my hand square filing and actually enjoy it,,but at this stage its pretty time consuming for me..think the grinder should be faster..
  15. Nixon
    Nixon
    West Sunbury,Pa .
    When you setup your 451 , you’ll notice that the swing arm stops ,and height adjustment don’t have any way to lock them to keep them from moving . I bought some well nuts at a box store to keep those adjustments from moving while I’m grinding .
    T.Jeff Veal, Rope and concretegrazer like this.
  16. concretegrazer
    concretegrazer
    Southwest MO
    The dressers are easy to understand once you have it in front of you. The only real drawback to grinding is the chain needs to be somewhat clean. Or you'll be redressing the wheel constantly.
  17. Eric VW
    Welcome aboard Salisbury Sugarworks :salute:
    As you’ve no doubt realized, plenty of info here and at OPE, which consequently was founded by an FHC member ( Mastermind ), plenty of excellent folks to network with and gain knowledge from.
    Speaking of which, where’s that huskihl....?
    :thumbs:
    T.Jeff Veal, Rope and huskihl like this.
  18. Nixon
    Nixon
    West Sunbury,Pa .
    As for the dressers ;the shallower you dress the top of the wheel , the less the top plate angle will be .
    The more you dress the side of the wheel from vertical , the more the side plate angle will lean forward .
    Found this at the Madsen’s site . It doesn’t deal much with the dressers , but it does have some useful info. http://www.madsens1.com/PDF/howtousesimington.pdf?
  19. T.Jeff Veal
    Welcome to the club. I think you will like it here. Great bunch of folks here willing to share humor and knowledge. dall sharpened a chain for me, super nice.
    dall, Rope, huskihl and 1 other person like this.
  20. huskihl
    huskihl
    :salute:
    Rope and Eric VW like this.
