Show me your 5 gal fuel can. Any hack?
Discussion in 'The Wood Pile' started by Marshel54, Jul 2, 2020.
  1. In the Pines
    In the Pines
    now that looks like a can worth buying! never saw those before
  2. Loon
    Loon
    North of the border
    Was thinking the same Pines.:salute:
  3. Rush Battle
    Rush Battle
    WNC
    I’ve got one also, and the ultra frustrating kind. The sure can is fantastic, if you can find a place to rest it while pouring. The other one is unused for obvious reasons.
    Screwloose, brenndatomu, Chaz and 3 others like this.
  4. Chris F
    Chris F
    Micksburg, Ontario
    The can on the left is five real Canadian gallons and I bought it new in 1978. It'll last me two weeks in the spring and early summer cutting grass.
    The middle one is two gallons and I use it for the snowblower and the push mower and weed whacker. It's about 30 years old.
    The small one is for the chainsaw.
  5. Wes Hightower
    Wes Hightower
    North Carolina
    I use us military issue 5 gallon expeditionary fuel cans. Made in Canada by Scepter, hard to find and not sold to the public. I recently found a real close clone by Scepter at Northern Tool.
  6. Loon
    Loon
    North of the border
  7. dahmer
    dahmer
    Ellwood City PA
    I have this can in 5 gal. and 2 gal. They are expensive but they work great.
    Screwloose, Loon, Stephiedoll and 2 others like this.
  8. mike bayerl
    mike bayerl
    I would love to find economical options. I have and like the No Spill for small (1.25 gal) for fuel:eek:il mixes. The full 5 gal No Spill takes forever to empty. I have a VP 5 gal the hose. It empties much faster but as above, has no great way to shut off quickly. Both the NoSpill and VP are very expensive.
  9. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I have the 5 gallon No Spill as well. Only complaint I would have is the auto shut-off they talk about doesn't seem to work for me. Minor issue and I'm guessing there is a trick to it.
    Screwloose, Brandon Scott and Loon like this.
  10. T.Jeff Veal
    The best right here, expensive, but worth it.
  11. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I am slowly moving all of my fuel cans over to VP jugs. I use the regular hoses, and haven't had an issue. However, someone does sell a hose with a ball valve. Its pretty spendy, but I guarantee it could be made for significantly less if you source the ball valve.
  12. Skier76
    Skier76
    CT and SoVT
    Thanks everyone. I have some older fuel canisters and I'm looking for some new/different nozzles. Some are just old and cracked...and some of the no spills make a mess. I do find it a bit ironic that the ones designed to contain the spills end up causing more spills and wasted fuel vs the old style.
    I will say, the one MikeSS posted works well. I have one of those for my premix and it's very easy to fill the saw and other two stroke equipment.
  13. jo191145
    jo191145
    Ct
    Very ironic indeed. When I first used on of those new epa jugs I had it in the sun on the back of the truck. Noticed it was expanding like a balloon. Pushed the button and doused the entire truck with gas. What an accident that could have been. Also had the pressure blow fuel out of the chainsaw tank a couple times. What a learning curve :)
    The only good side is they automatically seal out air keeping the fuel a little fresher.
    on those cheap push in spout types I’ve drilled a hole in the handle and just screwed in a lag bolt. Remove to pour. PIA but better than as is. Filling a snowmobile without takes forever and they burn fuel pretty fast.
    Have all push buttons now. Better but still a PIA.
  14. mikeward
    mikeward
    Long Island, New York
    I have a bunch of the older 5 gallon jugs and the spouts have all broken.
    I've bought replacements on eBay and Amazon.
    I try to keep them out of the sun to protect the plastic from UV light since it males it degrade.
    I did buy the yellow replacement vents and they work fine. BUT the squirrels here like to chew on them, especially the plastic that attaches the top to the jug. now I just use a coarse threaded metal screw and twist it in by hand.
    Also, you don't need a spout for every jug.
    I have a couple of spouts and found solid caps from the same company that makes replacement spouts.
    I use them for most of the other jugs.
  15. billb3
    A golf tee works in an appropriately sized hole as a stopper in a pinch.
    Not approved for use in most if not all New England States but the local EPA police are not spying on homeowners (yet).
  16. Screwloose
    Screwloose
    I've got several of the no spill brand ones and overall I've been pretty happy with them.
    Brandon Scott and brenndatomu like this.
  17. brenndatomu
    Ah...you're just under the spell of the company's spokes-lady...:whistle: ;) :rofl: :lol:
  18. mike bayerl
    mike bayerl
    Nice!
    Screwloose and Brandon Scott like this.
  19. billb3
    Stens advertising certainly has memorable ads.
  20. Screwloose
    Screwloose
    I had to look that one up on YouTube.
    She had me at "hi, I'm no spill Jill".
    brenndatomu and Brandon Scott like this.
