Should go 20+
Discussion in 'Modern EPA Stoves and Fireplaces' started by rdust, Dec 4, 2013.
  1. rdust
    rdust
    SE, Michigan
    Here is a load in the Princess. It's not too cold here tonight(low 30's/upper 20's) and tomorrow is supposed to warm up a bunch.(upper 40's low 50's) Loaded the stove with cherry, silver maple, a couple hickory chunks and ironwood fillers. None of these splits are particularly big so who knows how long it'll go. I hate loading the stove before work so I filled it up. I may be wasting wood due to tomorrows temps but I'll be able to sleep in though extra couple minutes! :D
    Notice the one ironwood split with the water coming out of the end, happened about as soon as I loaded it. This cracks me up, that stuff has been split since the spring 2009 and in my shed for 2 seasons! Such a small piece and still holding on to some moisture. :confused:
  2. bogydave
    You use a hammer to get the last ones in there LOL :)
    Full load+ :thumbs:
    Cook out the water before cranking it to low.
    You'll be fine.
    We're up to 16°f now. Warmest it's been in a week +. :) :)
    Think I'll go with a full load of some birch tonight ;)
  3. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I always love a good BK load.
    Scotty Overkill likes this.
  4. Backwoods Savage
    rdust, we too will occasionally get one that sizzles. I remember once having a couple splits sizzle and the wood had been split and stacked for like 8 years. Never have figured that out but just accept that it will happen occasionally.
    papadave and raybonz like this.
  5. rdust
    rdust
    SE, Michigan
    At the 20 hour mark stove top was 260ish, house still in the low 70's with the stove room being mid 70's(warm today). Pulled the coals/charred wood from the sides/back to the front and turned the air up. Stove top is right around 400 after about 30 minutes with the air turned up. Gonna get warm in here while I burn these coals down for the next few hours so I can load before bed.
    papadave and Beetle-Kill like this.
  6. rdust
    rdust
    SE, Michigan
    Made it 23 1/2 hours, getting tired so I reloaded. Could've made it longer if I didn't want to burn the coals down faster so I could reload. Stove top was 330ish when I reloaded.
    papadave and alforit like this.
  7. swags
    swags Moderator
    What setting and temps are you running at getting the 20+ hour burns?
  8. rdust
    rdust
    SE, Michigan
    Usually 1 3/4 will go 20-24 hours on average wood. If I run the same setting with the blower on low it's more like a 15-18 hour burn.
  9. rdust
    rdust
    SE, Michigan
    Picture of a typically t-stat setting. When it's teens or colder I may bump up to the n or o on normal, it's not often I need to burn hotter than that.
  10. swags
    swags Moderator
    What size of house are you heating?
  11. rdust
    rdust
    SE, Michigan
    Just a tad under 2K, 1100ish on the main level the rest is bedrooms upstairs. It was built in 80 so the insulation is probably average at best, windows/doorwalls were replaced in 2005 and seem decent.
