shop tips
Discussion in 'Chainsaws and Power Equipment' started by angelo c, Dec 30, 2015.
  1. MG2186
    MG2186
    Summer,IA
    Where can a guy buy this at?
  2. clemsonfor
  3. MasterMech
    Available from multiple sources online or you friendly Stihl dealer of choice.
    bobdog2o02 likes this.
  4. MG2186
    MG2186
    Summer,IA
    Ok thanks, I'll ask my Stihl dealer next time I'm down his way. You prefer that over Threebond 1194?
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Your Mike Rowe quote is remarkably accurate.
    MasterMech likes this.
  6. pantelis
    pantelis
    Europe
    Three bond 1194 must use husqvarna in some models but i am not 100% sure
    Dirko HT is the top gasket maker
    END OF STORY
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    The best penetrating oil I have ever used is aerokroil. Kinda pricey, but is used in most large industrial gas turbine outage crews. Tried a can and love it. for a good set of gloves look up knuckleheads :dex:
  8. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I've made small work platforms out of a 2 x 4 or 4 x 4's with a plank screwed into them. They are set in my bench vise and give me a raised platform. Instead of leaning over the bench working on something, this can bring it up a foot higher. The plank can be cut to any size you want. It is also sacrificial for drilling into or cutting into it with a jigsaw.
    JustWood, BillinTX, gregbesia and 4 others like this.
  9. NewToStihl
    NewToStihl
    Central Indiana
    I apologize in advance for no pics...
    This is more of a chainsaw tip rather than a shop tip, but I was pretty excited tonight when it worked! I had a saw that was passing the vacuum test 100%, but had a slow leak on the pressure test. A little listening around told me the decompression valve (a.k.a. sissy button) was the culprit. I inspected the valve and discovered that it had some degradation on the seating surface of the plunger rod. I disassembled the valve and chucked the stem in my foredom and ran it slowly while pressing the tapered end up against some scotch brite. After it appeared the damage was mostly gone I put it all back together and tried again. Still bled out, but more slowly. A couple "rinse and repeat" cycles of that got it to a VERY slow leak, but still not up to par with my standard. I was trying to figure out how to avoid buying a new decomp valve and it occurred to me what to do...
    I slid the stem back into the housing (outer part with the threads for the cylinder) and then chucked the end (top) of the stem back into the foredom leaving room so the outer housing had plenty of axial play. I don't have any valve seating compound which would have been ideal, so I put some polishing compound on the tapered seat and applied light pressure (imaging 'closing' the decomp valve) while slowing rotating the stem. I applied compound a few times until I saw a nice 'perfect' surface on both seats. I thoroughly cleaned everything up, reassembled, and put the valve back on the saw. Help pressure perfectly!
    I've always just replaced leaking decomp valves, but now I have a potential fix which in this case saved me $20-$30!
  10. angelo c
    angelo c
    People's Republic of North Jersey
    Nice work Beau,
    I usually just "ditch the $itch"....decomp bolt plugs are a few bucks each by the dozen. Just toss 'em.
    (My ported 385 not withstanding)
    pantelis and mdavlee like this.
  11. pantelis
    pantelis
    Europe
    And i think that you dealing only with stihls :whistle:
    angelo c likes this.
  12. clemsonfor
    So he was lapping his docomp valve?? I read it but did not pay any attention, your right it seats against itself not the cyl! Yea I would toss that bad boy!!
    I had one fall apart into a ms390 and lock the saw causing a tear down. No damage though. It was the original stihl. Made it like 8 years.
    pantelis likes this.
  13. NewToStihl
    NewToStihl
    Central Indiana
    Although that's a perfectly rational line of thinking, my completely irrational OCD won't let me do that. Then there would just be this awkward hole in the top shroud for no reason! :eek:
  14. clemsonfor
    Replace it with a new one :)
  15. NewToStihl
    NewToStihl
    Central Indiana
    I don't need to . . . I repaired the one I have . . . which was the whole point of my post.
  16. clemsonfor
  17. angelo c
    angelo c
    Duct tape to da rescue !!!
    concretegrazer and pantelis like this.
  18. angelo c
    angelo c
    You made me think about this for a few minutes ( and yes my head now hurts from that) ...I wonder if the Stihl decarbonizer will work as well. I'll soak the next one that gives me grief and post back. Maybe just taking a torch to the tip and burning it some ? like a clogged muffler screen >
  19. pantelis
    pantelis
    Europe
    without deco a nut and the job done
  20. clemsonfor
    Or just replace with a new one
