Sharpening Thread
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Jan 27, 2014.
  1. Hedgerow
    Hedgerow
    SW Missouri
    The Stihl dealer will either get you for chains, or sell you lotsa files... ;)
    mdavlee likes this.
  2. MasterMech
    Funny thing is, when you get the itch to try square filing, just go ahead and forget everything you were just taught about round filing chain.
  3. w8ye
    w8ye
    Mansfield, Ohio
  4. trx250r180
    trx250r180
    I have been doing square so long i forgot how to file round :whistle:
    sam-tip, Hedgerow, mdavlee and 2 others like this.
  5. mdavlee
    mdavlee
    That's pretty close to the truth for me. Made it too aggressive for a ported 70cc saw. Hopefully soon I'll have some cutting done with a ported 390xp and maybe a round/square shootout in big wood.
    trx250r180 likes this.
  6. Chvymn99
    Well, I tried it out on Sunday. It throws chips, seems to run a little different than my neighbors sharpening. If I let it cut on its own, it will cut just fine. But you add pressure she'll try to stall out. (I was using it on my 034 with a 20" bar). But its not as hard as I thought it would be, I was majorily intimidated by this whole process. Thanks for all the help and pointers. Throughout this thread and the others... :thumbs:
    mdavlee likes this.
  7. mdavlee
    mdavlee
    If it was easier to bog you put more hook on it and it's biting harder on its own. Does it pull the saw into the cut or try to jerk it into the wood?
  8. Hedgerow
    Hedgerow
    SW Missouri
    For good filing of square, one must get in "The Zone"...
    A whiskey on the rocks helps at times...
    Then hurts at times...
    But knowing what you want to do, then doing it over and over, helps with the muscle memory.
    I can square file a 72dl chain in 10 minutes, but when the results really matter, I've spent several hours...
    w8ye and mdavlee like this.
  9. mdavlee
    mdavlee
    I've spent up to 11 hours on one 60 DL chain over the course of 2 days. A quick touch up with a square file is about 10 minutes for a 24" semi skip loop.
    Oliver1655, Hedgerow and w8ye like this.
  10. Hedgerow
    Hedgerow
    SW Missouri
    some "chips"?
  11. trx250r180
    trx250r180
    Hedgerow likes this.
  12. Hedgerow
    Hedgerow
    SW Missouri
    For a work chain, yes...
    But do ya think they too high for a race chain??
    Didn't plug up in a 10" cant.. Sooo...
    Not real sure at this point...
  13. trx250r180
    trx250r180
    i like min high too ,does not overwork the saw that way ,plus chain stays sharp longer ,doug fir chips ,that wood must be dry to have the splintered edges ? look how crisp mine are here wet off the stump ,rakers were at .025 here ,chain sharpened almost halfway in life
    Oliver1655 and MasterMech like this.
  14. MasterMech
    So if it's not a top secret topic, race chain runs the rakers less aggressive than even a stock chain?
  15. Hedgerow
    Hedgerow
    SW Missouri
    Ya... Test cant been sitting around for 7 or 8 months... What I thought was interesting was how clean the cut side was and the chips were actually wider than the cutters... The end of the cant was like glass. We'll see how fast that chain is this Saturday...
    So jury is still out... It has been stoned and thinned also...
    Oliver1655 and mdavlee like this.
  16. mdavlee
    mdavlee
    Depends on the saw, operator, and size of wood.
  17. Hedgerow
    Hedgerow
    SW Missouri
    Well??
    Not always... I've seen fast chains at almost 40 thou under cutter... And some like this one about 20 thou...
    A normal work chain for me would be anywhere from .025 to .035.. depending on application.
    mdavlee likes this.
  18. MasterMech
    I'm guessing then that what's fast in one log on a particular saw can be slow under different conditions then. That makes sense but there is no general rule of thumb then? It can't possibly be all left to chance. ;)
    Hedgerow and mdavlee like this.
  19. Hedgerow
    Hedgerow
    SW Missouri
    I've always liked a more aggressive chain for three cut racing, so you could focus on changeovers instead of pushing on the saw.
    But too aggressive, and you got a crazy chain that stuffs itself full of crap.. I learned that the hard way...:confused:
    mdavlee likes this.
  20. Hedgerow
    Hedgerow
    SW Missouri
    A fast, sharp chain is a fast, sharp chain... But if a heavy handed operator ran one chain made special for his 3120, on his 346, he'd have to completely change the way he fed the wood to it. I have used one of Mike's chains one week on a hot 54cc Dolmar, then the next week on a strong ported 394, both with good results, but the race the 394 was in was an aussie style race where you had to bore cut in, then down to the bottom, then come back up to finish the top off..
    In other words, make the chain suit the power, and application of the saw or race..
    MasterMech likes this.
