Sharpening Thread
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Jan 27, 2014.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    Are you bringing it to the GTG?
  2. w8ye
    w8ye
    Mansfield, Ohio
    I had planned to.
    It is a mixture of 066 parts and was done by Brent Combs.
    The cylinder and covers are Red light but the crankcase is a early poly flywheel type.
    The starting handle is from a 460 rescue saw.
    It is just woods ported. You can run it all day.
    It has been around North Central Ohio since around 2008.
    mdavlee, Hedgerow and DexterDay like this.
  3. Hedgerow
    Hedgerow
    SW Missouri
    My 90cc cookie cutter / work saw..
    I think Andy was diggin on how the ole 9010 was kicking the crap out of a hot 288...
    I use an 8 also, with a 72dl chain on a 20" bar..
    Helps reach through larger cants without taking the big felling spikes off...
    mdavlee likes this.
  4. Hedgerow
    Hedgerow
    SW Missouri
  5. sam-tip
    sam-tip
    Waukee Iowa
    How much do you shape the tie straps or clip the tail of the cutter. I was going to grind some 325 chain but it sounds like a waist of time. Sticking to 3/8 chain. I did some 404 but have not tried it yet. I did get to try the 3/8 LP square chain. Me like! I think I have the theory of square chain but not the time to put paper to practice. Don't think filing in the hotel rooms would go over very well.
    Hedgerow likes this.
  6. Oliver1655
    Oliver1655
    Central Missouri
    Keep the door shut. :whistle:
    Hedgerow and concretegrazer like this.
  7. DexterDay
    Northeast Oh
    Hey Sam-tip.. Don't know how I missed your 1st post, but this is the first one I seen.
    Welcome to FHC. :)
  8. mdavlee
    mdavlee
    I had thought about a vise to hold a filing jig so I could file in motels while I was traveling.
    Hedgerow and trx250r180 like this.
  9. w8ye
    w8ye
    Mansfield, Ohio
    40 something years ago I built model airplanes in hotel rooms all the time. There was a lot of sanding dust???
  10. concretegrazer
    concretegrazer
    Southwest MO
    Why do you trim the rakers?
  11. mdavlee
    mdavlee
    Less weight and drag. The chain wasn't done there. I had finished clipping the heel cleaning the gullet and tunneling a little bit on the cutter. The rakers a been thinned but not set yet.
    DexterDay and trx250r180 like this.
  12. mdavlee
    mdavlee
    Here's a video of the 550 with the chain I filed to send off to a chain race and didn't get to finish the rest up on it. Chips in my hand at the end.
  13. Hedgerow
    Hedgerow
    SW Missouri
    Nice chips!
    And clean end of log...
    mdavlee and Oliver1655 like this.
  14. mdavlee
    mdavlee
    It was a smooth cutting chain. Might try to run it on the 390 to see what it will do.
    DexterDay likes this.
  15. Hedgerow
    Hedgerow
    SW Missouri
    Go fast...
    Gear it up and watch the stuff fly...
    DexterDay, Oliver1655 and mdavlee like this.
  16. mdavlee
    mdavlee
    9 pin and let it eat huh? :bug:
    DexterDay, Oliver1655 and Hedgerow like this.
  17. mdavlee
    mdavlee
    9 pin wouldn't fit. Have to trim the bar. I put an 8 pin on and run it. The chain needs more raker depth for a big saw.
    Hedgerow and Oliver1655 like this.
