secondary burn?
Discussion in 'The Wood Pile' started by Spirch, Oct 28, 2018.
  1. bear 1998
    bear 1998
    S.C.Pa
    2 great minds think alike...:D
    T.Jeff Veal, Horkn, HDRock and 4 others like this.
  2. Spirch
    Spirch
    Canada
    so, i just did a test, not much resistance all around the door and I checked the manual and it say to replace it every year, I guess i need to figure out how now...
    T.Jeff Veal, papadave, Horkn and 6 others like this.
  3. bear 1998
    bear 1998
    S.C.Pa
    Write down or take a pic of manufacturer label....what make of sbi do you have? They make Drolet,Enerzone.Etc.
    You can go to the makes website n download users n parts manual (make sure you get serial #s). Should be a part # for door gasket kit...manual will tell you how to install it.
    Google part#....you may find it quicker n cheaper than orderin from the factory.
    T.Jeff Veal, Horkn, HDRock and 3 others like this.
  4. Spirch
    Spirch
    Canada
    Wood stoves : XVR-II
    this is what I currently have
    I just pinch/massaged the gasket all around the door a few time with some kleenex and i tightened the handle / lock of the door by turning the bolt about 1/8 of a turn (english is not my first language, i hope i'm using the proper wording here)
    it is way better now, I still need to change it but at least it is "better" until i get the new one
  5. Loon
    Loon
    North of the border
    :hair:
    Plastic bills: Quick! Spend them before they melt | The Star
    They seem to stand up better than the old ones when found after being flushed down the toilet though! :coldone:
  6. brenndatomu
    You have proof?! :whistle: ;) :rofl: :lol:
  7. Spirch
    Spirch
    Canada
    I got the part # AC06400
    self adhesive gasket, manual say to apply silicon ... i will see when I get one, maybe tomorrow
    I just started a fire and when i closed the door, the fire didn't behave like i'm used to, i nearly killed it ... good sign i guess that what i did worked
    T.Jeff Veal, Horkn, Loon and 3 others like this.
  8. HDRock
    I do that a couple times a year
    T.Jeff Veal, Horkn, Loon and 2 others like this.
  9. Spirch
    Spirch
    Canada
    or part # AC06500 ... i guess i'm going to check tomorrow now that the fire is started
  10. bear 1998
    bear 1998
    S.C.Pa
    Did you find part# for kit ?.....$24.00.
    Ok....i see you found it....
    Horkn, Loon and brenndatomu like this.
  11. Spirch
    Spirch
    Canada
    the local Rona seem it might have it, I will check tomorrow
    yup first fire since i played with the gasket / door ... it seem it worked and it is more sealed, the temperature behave completely differently, flue temp is way lower than normal, from a fresh fire
  12. bear 1998
    bear 1998
    S.C.Pa
    Good job
  13. HDRock
  14. blacksmithden
    blacksmithden
    Alberta Canada
    I dont have a flue thermometer. The one on top of the stove floats between 400f and 800f. I dont pay much attention to it. If it's in the red, I close off the air a bit. If its wound nearly off the end, I back it way down. This year, I finally put an automatic temperature sensor on the stove to turn on the fan automatically. My major concern is smoke since I'm in the middle of a tightly packed subdivision. To me, hot as heck gets me more complete combustion, so I run it hard for at least the first 20 minutes after loading to get the smoke levels down quickly. My stove is in a small alcove of my basement...10ft x 11ft. I can pretty much tell what the stove is doing just by how the heat is radiating off of it. My grandfather ran his stoves without a thermometer his entire life without any problems. Good enough for me. :)
  15. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Bah. The logs are merely too long.
    NS should not affect the secondaries, it just allows you to to load the stove more efficiently.
    What are you burning, btw? Not saying you shouldn't get secondaries with certain types of wood but generally the less desirable wood makes wilder secondaries.
    New stove? Are the tubes in the correct sequence, and oriented properly?
    Getting the slow, lazy rolling secondaries with minimal fire below takes a bit of balancing on the air flow. Too little air and the main fire won't stay sufficiently lit to ignite the off gassing in the secondaries. Too much air and although the secondary combustion is difficult to spot from the larger fire. On a reload make sure to rake the coals forward, and you will cook off the wood gas on the fresh wood, restarting the secondaries.
    T.Jeff Veal and HDRock like this.
  16. Marvin
    Marvin
    Huntingdon, Pa
    I tried this this evening for chits and giggles. You aren't kidding. That puts on quite a show.
  17. Loon
    Loon
    North of the border
    Always! :coffee: :coldone:
    T.Jeff Veal, HDRock, Horkn and 3 others like this.
  18. Spirch
    Spirch
    Canada
    i got a new cellphone that can do 960fps and took a few videos here 3 :cool:
    I think i'm seeing secondary burn in all of them, right???
  19. Suburban wood snob
    Suburban wood snob
    Milwaukee
  20. Horkn
    What phone did you get? My new phone has that super SLO mo too. I'll shave to try it when I load up some cray-cray flame wood.
