Sealing hole in concrete outside?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Triple A Arsenal, Feb 12, 2015.
  1. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Thanks badbob!:cheers:
    ivanhoe likes this.
  2. ivanhoe
    ivanhoe
    Northern Ontario
    Looks like a busy area outside but I shouldn't say anything, mine is similar:zip:
    Otherwise it looks :thumbs:
    Two cleaning T's is very helpful:yes: I wish I had that:(
    Triple A Arsenal and slvrblkk like this.
  3. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    By busy do you mean messy? Someone missed spring cleanup :eek:
    ivanhoe and slvrblkk like this.
  4. DexterDay
    DexterDay Administrator
    Northeast Oh
    25.5' is what I added up. You should still be fine because it's 4" vent.
    Not counting the 45° vent angle because it's the last piece. Even with that, it's 28'.
    Good to go
  5. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    I was looking in the manual but no furnace EVL recommendations. What are some of the effects when the EVL is too high?
    slvrblkk and ivanhoe like this.
  6. jtakeman
    Lazy flame, Sooty burn(mostly on low fire).
    I've had no issues with 4" and 28+ EVL. And my blower aint got the power yours does. I had to increase the blower speed one notch on low burn is all I saw for draw backs.
  7. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Do you guys remove the cold air box and clean in the back ? I believe just the combustion fan is back there correct?
  8. ivanhoe
    ivanhoe
    Northern Ontario
    oil the distribution motor but that can be done on the side panel. Dex mentioned the oil slots is on the bottom of the motor, true enough. I yanked mine out and gave it a few drops. I will look into rotating the motor next time I lubricate it.
    slvrblkk likes this.
  9. DexterDay
    Northeast Oh
    I wish I would have rotated mine.
    The distribution blower should be cleaned/brushed/blown out every year (or every other year at most if you run a filter constantly)
    The combustion blower should be removed yearly (old style like Mike and several others) as well if your burning 3-4+ ton. The new units have the clean out plate like yours.
    I also clean and blow out the 2 channels that the distribution blower blows through (50% goes through the heat exchange tunes, the other 50% blows under the bottom of the furnace and comes out at the little slot by the bottom of the door). Just a quick hit with my little brush and blow some compressed air through there.
    ivanhoe likes this.
