Sealing hole in concrete outside?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Triple A Arsenal, Feb 12, 2015.
  1. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    That side of the house gets zero snow drift/wind. We had 14" last week and it only had 4-5" on that side of the house.
    The clearances are 12" from house, 12" off ground.
    ivanhoe likes this.
  2. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Should I go up or just extend? I want to fix this once and done. It's bothering me lol.
    Sounds like UP gets majority vote. I have this setup inside. Do I need another T if I go vertical? I would have to calculate the EVL.
    ivanhoe likes this.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    Using 4" the EVL doesn't bother me. If you went out 1 more foot, the a 90° and went up at least one more foot would be ideal (24" or better). Then I would just use a vertical termination, rather than another 90° and your horizontal termination.
    ivanhoe likes this.
  4. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Really....another 12" horizontal, then a 90 bend, then a 24" vertical with cap?
    Is the addition 12" horizontal necessary?
    ivanhoe likes this.
  5. DexterDay
    Northeast Oh
    I messed that up...
    12" out and a nozzle cap "Or" a 90° where it's at now and 24" up.
    Sorry...
    ivanhoe and IHATEPROPANE like this.
  6. badbob
    badbob
    Double cleanout t,up at least 24"(but I would go more), 90 then jet/vortex cap.
  7. eatonpcat
    I drove by the other day and Kenis was blow drying his hair under that thing!!
  8. IHATEPROPANE
    IHATEPROPANE
    T it and add 2-3 feet of vertical. Take a look at T-BONE pic a few posts up on page one.
    ivanhoe likes this.
  9. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Thanks guys, I need to find a place to purchase the 4" tee. HD wants $90 just for the Tee. Also need to locate Jet cap. I'll also go up 3ft since 24" looks frowned upon lol.
    Also Dex was right, these pellets are different then the FSU I was using first. These GTP needs lots more air. I adjusted the damper, looks like better flame. Lost some flame height but I'll keep a feel for heat loss. I have zero complains about HEAT from GTP. Other than fines, soot, ash lol lol. I think the damper adjustment will fix the outside soot. But if I can get that siliconed cap off, I will add the tee and 36" rise, and bracket.
    IHATEPROPANE and ivanhoe like this.
  10. IHATEPROPANE
    IHATEPROPANE
    :bug:
    ivanhoe likes this.
  11. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Yeah from HD it's $200 for Tee and 36" of 4" multi fuel vent. Still need Jetcap which they don't sell
    ivanhoe likes this.
  12. IHATEPROPANE
    IHATEPROPANE
    :faint:
    ivanhoe likes this.
  13. ivanhoe
    ivanhoe
    Northern Ontario
    I agree with the extra T, easier clean out. Added vertical will help on the natural draft and raise it off the ground. The jet cone to get it away from the siding. Now we're talking:D
    IHATEPROPANE likes this.
  14. ironpony
    ironpony
    Mid Ohio
    back to the original question
    being it is going thru block I would use hydroment by quickrete. expands as it cures and seals great.
    343amc, T-BONE, eatonpcat and 2 others like this.
  15. krooser
    krooser
    Waupaca, WI
    Well I cleaned up the old St Croix a little better… I had a better flame on #3 after I was done BUT it's still not to my liking. So I opened my air damper a little and waited a few minutes. Now I have a better burn but I know this is just a band-aid. My stove is still dirty so I'm going to pull the combustion fan this weekend to clean out the soot and ash.
    This was the first time I changed the setting on my damper in the nine years I have had the stove. My dealer sez if you need more air your stove is dirty...
    ivanhoe, imacman and IHATEPROPANE like this.
  16. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Is that easy to remove if I need to get it out? I never used that before and was thinking about cement patch.
    ivanhoe likes this.
  17. IHATEPROPANE
    IHATEPROPANE
    Is your exhaust fan getting tired?
    ivanhoe likes this.
  18. ironpony
    ironpony
    Mid Ohio
    no harder than cement patch. just expands instead of contracting when drying. stays watertight
    ivanhoe likes this.
  19. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Any ideas how to remove the end cap that I applied hi temp sealant to?
    Since its outside it probably wasn't needed correct?
    I have my Tee and 36" vent on order.
    Still need support bracket and a cap
    ivanhoe likes this.
  20. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    That's great! I will pick some up on the way home.
    ivanhoe likes this.
