Scrounging six cords a year plus
Discussion in 'The Wood Pile' started by Rowerwet, Mar 6, 2018.
  1. Woodwidow
    The dihedral wing formation makes a nice ride in turbulence. Coastal flying out here is in and out of a lot of hills or mountains as some would call them. We had a similar flight path as a Cessna 180 crossing the Rockies to the prairies with the Sundowner. Our ride was fairly comfortable and theirs was pretty rough. I don't quite understand the wing construction difference but it seems it was the way the wing spar was set up.
  2. Woodwidow
    Nothing nicer than an evening sail in a small sailboat. Our first sailboat was a Paceship 23 trailerable with a shoal keel and daggerboard. We had a lot of fun in it just going out for an hour at a time in the evening.
    Rowerwet likes this.
  3. Rowerwet
    Rowerwet
    Seacoast NH/MA
    High wing aircraft tend to have a straighter wing since the weight of the aircraft naturally hangs below the wing and tends to level the aircraft in roll axis.
    A straight wing is more efficient because the lift it generates from each wing is directly up, vs low wing aircraft with sloped wings that actually generate lift at an upward and inwards angle.
    Low wing aircraft need this V shape to the wings for roll stability, since the weight is above the wings. When the plane banks, the wing closer to horizontal generates slightly more lift, and this tends to right the aircraft from the bank.
    The tradeoff is that the V shaped wings don't "grab" the air as firmly as a straight wing, so the V shaped wings ride easier through bumpy air.
    You can easily test this with boats, V hulls cut through chopp and give a smoother ride that flat bottomed boats that tend to pound in rough waters.
    The interesting thing is that the low wing Sundowner is faster than the low winged piper Cherokee, even though parts of it look less streamlined, and weights and engines are almost identical.
    Beech managed to squeeze out some more efficiency somewhere.
    Stephiedoll and Woodwidow like this.
  4. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20230916_133945.jpg 20230916_134422.jpg 20230916_135412.jpg 20230916_143237.jpg 20230916_144215.jpg 20230916_150827.jpg 20230916_151856.jpg 20230916_151829.jpg 20230916_152039.jpg 20230916_152345.jpg 20230916_152758.jpg 20230916_152911.jpg
    My wife and I have birthdays 1 day apart. We were given passes to gunstock and planned on having fun on the mountain coaster, but the weather ended up cold and rainy. We ended up taking a drive up to Franconia notch anyway, did a short hike and checked out the old man of the mountain museum at Cannon mountain.
    None of our children is old enough to remember seeing the profile, but they have things set up so you can see what it looked like.
    20230922_061320.jpg 20230922_061348.jpg 20230922_061402.jpg 20230925_085711.jpg
    Sunrise at Logan, and the fire department training
  5. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20230929_063837.jpg 20230929_063913.jpg 20230929_064248.jpg 20230929_064342.jpg 20230929_064500.jpg
    found a great source of wood, all scavenged from a dumpster 20231002_064911.jpg 20231002_064909.jpg 20231002_064957.jpg 20231004_171927.jpg 20231004_172009.jpg 20231004_172021.jpg
    Maverick vs explorer sport Trac
    Busy day on the rail trail
    Don't mind that floating hotel gliding past the airport
    20231010_091726.jpg 20231010_164853.jpg 20231010_171107.jpg 20231010_171118.jpg
    Making real progress on my backlog and stacking the salvaged boards
    MikeInMa, Stephiedoll, Chud and 2 others like this.
  6. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20231011_073052.jpg 20231012_070140.jpg 20231012_070213.jpg 20231012_070238.jpg 20231012_070330.jpg
    Sunrise over the Merrimack River in Haverhill
    Very fancy interior in a jet I worked on
    Sunset over Newport harbor, same day as the Sunrise.
  7. BC Doug Fir
    BC Doug Fir
    Cariboo BC
    If someone built a runway that went all the way around the world, Cessna would design an aircraft that would need to use it all.
  8. Woodwidow
    Thanks for the information. We did notice that our Paceship 23 sailboat which had a flatter bottom was a rougher ride than the Ranger 29 had a wineglass bottom. The Paceship was a wetter boat for spray on deck than the Ranger as well. campinspecter courted me in a 13 ft 6 in runabout boat that was totally flat. Now that was rough going in a chop.
  9. Rich L
    Rich L
    Eastern Mass.
    I enjoy your family's outings.Your the most outdoor loving folks I've come across and it's great to see.Though I didn't like seeing those empty wood racks with winter upon us.
    Rowerwet and Stephiedoll like this.
  10. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20231014_064947.jpg 20231016_074124.jpg got my first ride in a corporate jet, trying to figure out what caused one engine to start shaking the aircraft.
    Turns out it was compressor stalls. 20231016_134317.jpg 20231016_135611.jpg 20231016_135611.jpg 20231016_135618.jpg 20231016_135645.jpg
    thre are four bleed valves on this engine and any one of them could be causing the stall. 20231016_135504.jpg
    A jet engine produces too much air at idle rpm, so to keep the flame from getting blown out, there are valves that bleed off the extra air, keeping the airflow inside at a low enough speed.
    These valves are closed by air pressure as the engine power increases, and must be fully closed at full throttle or you get momentary unlit conditions and then explosions that cause momentary backwards flow of air in the engine, called compressor stalls.
    20231015_095055.jpg oil tank in the church started leaking after it was filled for the winter, ugh. 20231016_164705.jpg 20231018_153220.jpg 20231018_181103.jpg took me a week plus, but I got it changed by myself, glad it wasn't in the middle of the winter. 20231020_063127.jpg the new international terminal extension at Logan Airport
    MikeInMa, Woodwidow, Chud and 3 others like this.
  11. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Stephiedoll likes this.
  12. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20231023_093606.jpg 20231023_093629.jpg 20231023_093645.jpg 20231023_093709.jpg 20231023_093716.jpg 20231023_093745.jpg 20231023_094440.jpg 20231023_094500.jpg 20231023_095111.jpg 20231023_095126.jpg cool wooden scale replica of a Sherman tank I discovered in a hangar on the airport, it's powered by two lawnmower engines
    Chvymn99, MikeInMa, Woodwidow and 3 others like this.
  13. Stephiedoll
    Stephiedoll
    Omaha, NE.
    And here I thought you got a bonus that ended up being a tank. It would be so kewl to have your own tank.
  14. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20231024_182134.jpg really making a dent in my backlog 20231025_174227.jpg getting the racks filled up for winter. Thankfully this all ash, which is ready to burn right off the stump 20231026_072918.jpg 20231027_071043.jpg 20231027_072002.jpg 20231027_072705.jpg 20231027_072715.jpg 20231028_064349.jpg sorry, I just love the sunrises at the airport 20231028_133425.jpg 20231028_142020.jpg 20231028_144114.jpg 20231028_144500.jpg 20231028_145755.jpg brought my sister and her younger two out to Halibut point, they're used to scrambling over rocks at the top of a mountain. 20231030_094809.jpg interesting perspective at Boston 20231101_141248.jpg over the years I've created custom tools to make my job easier. The screwdriver on the left is my latest.
    Small aircraft cowlings are often held on with spring loaded, quarter turn fasteners, and when they pop up they can launch the screwdriver tip onto the paint.
    I discovered years ago that a short tip with a fill handle allows me to use the heel of my hand to maintain paint protection, even at awkward reaching angles.
    I had the straight blade created years ago when that handle style was the latest from snap on, I had a cheapo Phillips that did the job until it wore out recently.
    Took me a bit to convince my new dealer to create what I wanted, but it works great. 20231101_184515.jpg don't ever buy an LG refrigerator, we have to remove the iceberg it creates in the bottom of the freezer every few weeks.
    No, the ice maker isn't leaking, this is a condensation problem. 20231103_072153.jpg 20231103_075322.jpg 20231103_174909.jpg finally cleared enough of the ash off the top of my backlog that I could dig out the stuff the tree crew dumped on top of.
    Finally able to dice up the big chunks so I can burn the good stuff and take the garbage to the recycle yard 20231104_102903.jpg 20231104_102937.jpg cool old trainer at the airport. These are really a Beechcraft bonanza with tandem seats and some other modifications.
    One way to have fighter pilot fantasies without a huge budget. 20231104_105934.jpg 20231104_141100.jpg more scrounged wood from a dumpster I have access to.
    Been burning this stuff for weeks now
    Chvymn99, Chud, MikeInMa and 5 others like this.
  15. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20231106_110833.jpg 20231106_112331.jpg 20231106_113031.jpg 20231106_115151.jpg 20231106_115914.jpg 20231106_120324.jpg 20231106_121216.jpg 20231106_122000.jpg 20231106_122049.jpg 20231106_122216.jpg 20231106_122301.jpg 20231106_122403.jpg 20231106_124559.jpg 20231106_125128.jpg 20231106_125545.jpg 20231106_125950.jpg 20231106_130642.jpg
    Isabella Stewart Gardner museum, I really can't believe my parents never took me here as a kid. My parents met at northeastern University
    and went here all the time because it was free back then.
    This was my first time visiting, we went for a homeschool field trip. The artwork collection didn't impress me as much as the room decor and the central courtyard.
    Toppsfield memorial day remembrances
    Lots of boards for fuel.
    Took her over 20 years, but my mother wore out a Nordic Trac exercise bike, found her a replacement for less than the parts to fix the old bike
    More progress on the backlog
    Chvymn99, Chud, Woodwidow and 4 others like this.
  16. Woodwidow
    That was quite the building. I thought you had taken the family to Europe judging from the style of the architecture.
    campinspecter, Stephiedoll and Chud like this.
