Sawbuck
Discussion in 'The Wood Pile' started by LumberJacked, Oct 13, 2018.
  1. trail twister
    trail twister
    Ok explain to me how you save your back lifting those logs on to that thing?
    OH you wait to get help right?
    I just use one of these and need no help, can cut when or where I want.
    Mine is a home built copy, about $10.00 to make. Can buy them for about $40.00.
    Another model. I can lift a big log and then cut about 4 blocks before i have to reset it.
    :D Al
  2. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I hate to say it, but my excavator thumb is perfect. The joysticks do pull kinda hard, but the logs are at the right height. All joking aside, I cut about 25% more using it as I can move one big log or clamp down on a few smaller.
  3. bushpilot
    bushpilot
    Eastern Washington
    I am still using mine. My new po-folks sawbuck
    It works great, sawbucks really cut down on the effort when bucking smaller stuff.
  4. ReelFaster
    ReelFaster
    S.Jersey
    Welcome to the club LumberJacked !! Always great to see another close by member in NJ! Great job on the sawbuck, I put one together very similar earlier this year and it has served me well so far!
  5. Eric VW
    Welcome to FHC LumberJacked :handshake:
    I like the sawbuck and the pic of your stacks is fantastic :yes:
    What do you burn in?
    T.Jeff Veal, Maina, Horkn and 5 others like this.
  6. LumberJacked
    LumberJacked
    New Jersey
    1st question - Good point. I have only used the sawbuck for smaller diameter lengths about 8' or so. Once it is up, I'm not bending at the waist for bucking. When I'm using my timberjack for the larger diameters, I'm still bending at the waist to buck because the main benefit of the timberjack is to save your chain and so you don't have to roll the tree to finish bucking.
    2nd question - I just put the length on the sawbuck and get after it. No help needed. It does require some strength and technique.
    Those are very beneficial and I use one as well. Nice pictures.
    T.Jeff Veal, Maina, Horkn and 6 others like this.
  7. LumberJacked
    LumberJacked
    New Jersey
    Quadra Fire insert.
    T.Jeff Veal, Maina, Horkn and 7 others like this.
  8. Eric VW
    Sweet.:yes:
    Since Horkn has a QF we already know what one looks like (although I’m sure they sell different models)....:whistle:
  9. Marvin
    Marvin
    Huntingdon, Pa
    That means we want to see some :ithappened:
  10. ReelFaster
    ReelFaster
    S.Jersey
    Those timberjacks raised my eyebrow ever since I saw one on Life In Farmland video. I think he was using a newer tool called a LogOx, really cool tool but they are wow $$. I do like how the timberjacks get that log off the ground to buck up or roll it.
    Maina, Horkn, LumberJacked and 6 others like this.
  11. Backwoods Savage
    Welcome to the forum LumberJacked. This is a great start for you and you did a good job building that sawbuck. And yes, fatherhood comes before firewood!
    Here are a couple of ours. The brown one was made by one Shawn Curry. Please pardon the expression on my wife's face. She didn't want this picture taken.
  12. Backwoods Savage
    Sorry Al. Please don't take this all wrong but first your sarcasm is a bit out of line on this forum. This guy is a new member and to post like you did is not in good taste. Second, it is easier to use a sawbuck than one of those tools. I tried one and found it to be the more useless tool I ever owned. I gave it away and now that person won't even use it. Methinks the OP is right with his sawbuck buy we do still respect that everyone has his own opinion.
  13. billb3
    I've never put big logs on my sawbuck, or never anything that the rounds would need splitting any more than in half. But it can hold more than one of those.
    Mine was made with the cheapest of 2x4 and fell apart when I moved it this Spring. The three bolts and nuts and washers are still good though.
  14. OldJack
    OldJack
    Saskatchewan, Canada
    Let's see if this posts. I'll write it up later.
  15. In the Pines
    In the Pines
    Don't lift the entire log, I pole vault the bigger ones. End over end until it's on the sawbuck than shimmy it until you can cut without it see-sawing on you.
    If it's too big it stays on the ground. Don't know if it saves that much wear on the back, but it sure saves the chain from digging into the dirt.
  16. Chaz
    Chaz
    Southwestern NY
    Welcome aboard LumberJacked
    Nice sawbuck you made.
    I'm sure you'll get a lot of use out of it.
    :saw:
  17. NH mountain man
    NH mountain man
    WMNF N.H.
    Thanks, I'd say that's a pretty darn good start there. Yeah, I think you'll fit right in here.:handshake:
  18. NH mountain man
    NH mountain man
    WMNF N.H.
    I also do it that way, and get them in the truck like that too.
  19. trail twister
    trail twister
    BWS if the OP though the question was out of line HE should have said so.
    I just wanted to know how he saved his back as that log on the buck should have weighed a good bit.
    I like my home built timber Jack is adjustable so I can get some up over knee high.
    :D Al
  20. Spirit of Two Socks
    Spirit of Two Socks
    Huntingdon, PA
    Looks great LumberJacked . Welcome to FHC! Have you had your first fire of the season yet out there in Jersey?
