Sawbuck designs
Discussion in 'The Wood Pile' started by sirbuildalot, Feb 10, 2020.
  1. sirbuildalot
    sirbuildalot
    Mass
    There was another thread where someone asked to see my sawbuck. I can find the thread, so I'm starting a sawbuck specific thread.
    Originally I had planned on building an A frame design, and still may some time. For now I made this one from leftover lumber I had last year.
    It will take one 10' long log up to say 10" diameter. Or multiple smaller ones (four or five 3"-4"). I find the sawbuck to really help with:
    A: Way less bending down to pick up cut pieces. With "arms" spaced close enough together, the wood doesn't fall to the ground.
    B: You are not cutting into logs beneath them as you do in a pile.
    C: You can do multiple logs at a time, and even though its small diameter wood, it adds up pretty quickly.
    As I said, this was leftover lumber scraps. If I were to have to buy the materials, this isn't what I'd make. I'd make a heavier duty A frame design with 4x4 PT frame able to handle up to a single 16" x 10' Red Oak and able to withstand being loaded with tractor forks or a grapple. For now this works pretty good.
    Let's see your designs!!!
  2. bushpilot
    bushpilot
    Eastern Washington
  3. yooperdave
    I think Shawn Curry had a thread on sawbucks some time ago while he was active on FHC.
  4. yooperdave
  5. FatBoy85
    FatBoy85
    Washington State
    Nice to give props to Shawn, I see how folks get so busy, they leave this place for awhile but hope to come back on time. That was a nice build and several members here have that sawbuck he built. Hopefully some can chime in who they are.
  6. buZZsaw BRAD
    I had asked about one when i joined FHC a year ago.
    Horsing around
    I never did build one as i dont often have much to buck in my PA as most is done prior to it being brought home.
  7. Backwoods Savage
    Design by one Shawn Curry.
  8. sirbuildalot
    sirbuildalot
    Mass
    This is along the lines of the one I plan to construct some day
    For portable options (if you have a means to move it), this design is pretty cool
  9. Kris_S
    Kris_S
    Thanks so much for this. I need to build one and it’s nice to have everything in one place.
    Screwloose, Felter, Horkn and 5 others like this.
  10. Farmchuck
    Farmchuck
    Nepa
    I’d like a table I could put logs on with my tractor forks to save my back. Do you have an specific ideas?
    Screwloose, Felter, Horkn and 2 others like this.
  11. buZZsaw BRAD
    Someone on here built something like that Farmchuck .
    Log butchering table
  12. Eric VW
    You even posted on that thread FC!
    :D
  13. buZZsaw BRAD
    thanks Eric. :salute: I figured out how to correctly cut/paste and corrected it.
  14. ErikR
    ErikR
    Deep in the woods near Cable, WI
    As far as going cheap, well I've got you all beat! 2 scrap pallets and some old logging chain... Works for me, holds anything I can lift into it, breaks down nice, and I don't feel bad if I nick it with my saw!!
  15. buZZsaw BRAD
    That is ingenious! Simple and effective
  16. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I am planning to build a large saw buck this spring, kinda like the feed table to a firewood processor. I have several steel beams and plan to pour a few piers And build up from there. I want to stage up to ten logs or six large and pull them to me and whack them up. My issue is I want the rounds to fall and collect in one spot where my splitter will be. Once I get some plans and momentum I can share if anyone is interested.
  17. Eric VW
    Does a bear chit in the woods? :whistle:
    :salute:
  18. yooperdave
  19. Farmchuck
    Farmchuck
    Nepa
    I do remember reading this post now. Thanks for the reminder guys.:binoculars:
  20. Farmchuck
    Farmchuck
    Nepa
    Please do!
