Saw shootout/ MS 440, ported MS 460, MS 461, and Solo 681
Discussion in 'Chainsaws and Power Equipment' started by DexterDay, Nov 23, 2014.
  1. MasterMech
    o_O
    I've run a stock/mm'd 9010 and it was pretty damm strong. I would find a ported example hard to resist....
    Kg461 and Hedgerow like this.
  2. Kg461
    Kg461
    Provencal, La.
    Im following u.
  3. mdavlee
    mdavlee
    What are you calling carb work?
  4. Kg461
    Kg461
    Provencal, La.
    Beside cant racing if u r cutting for speed in 20" wood will a standard carb offer any benefit over an mtronics saw?.
  5. Kg461
    Kg461
    Provencal, La.
    Venturi, jet, bore polishing? I dont know what all is really involved in carb work?
  6. Hedgerow
    Hedgerow
    SW Missouri
    In most instances, no. The autotune system keeps us saw set properly for all of its conditions. Very few people with a screwdriver can do the same.
    mdavlee, Chvymn99 and Kg461 like this.
  7. Mastermind
    Mastermind
    Tennessee
    I like AT and MT saws. They prevent a lot of tuning headaches for me.
    Chvymn99, Kg461 and Hedgerow like this.
  8. Hedgerow
    Hedgerow
    SW Missouri
    Exactly... Many a good ported saw has been rendered a turd via improper tuning..
    Or worse yet, ruined...
    mdavlee likes this.
  9. Kg461
    Kg461
    Provencal, La.
    Well I think theres alota folks thinking they can just turn the high speed up super high for a few cuts of racing and that means its gonna automatically cut faster
  10. mdavlee
    mdavlee
    That works for a lot of saws. You can have a 372 turning 15.5k out of the wood for racing. No way I'd try to work one at that.
    Hedgerow, Ron660 and Kg461 like this.
  11. Hedgerow
    Hedgerow
    SW Missouri
    Yup.. If you clean up the tune, you can get a little more power.. Then after a few cuts, you'll start to lose it..
    Everything is a trade off...
    Kg461 and mdavlee like this.
  12. Kg461
    Kg461
    Provencal, La.
    Would it make a difference in tuning the saw to a higher rpm in a race for just one cut in a 10" cant or a 25" piece of wood?
  13. Kg461
    Kg461
    Provencal, La.
    Also will the benefit of the higher rpm for cant racing only be beneficial at the start of the cut or all the way through the cut? Seems after the chain enters the wood and the added benefit of the higher rpms would diminish after the saw enters the work load range or is that also different in small wood racing vs bigger wood racing
  14. Kg461
    Kg461
    Provencal, La.
    Also are the saws u guys were using in the video standard woods port or were they modified beyond what most guys get in a normal woods port job? Im just trying to wrap my mind around the differences in a standard carb saw and mtronics saws and benefits of each for racing or working.
  15. mdavlee
    mdavlee
    Which video were you talking about?
    The woods port today is what a lot of the gtg saws were several years ago. Machine work wasn't in a normal woods port back a few years ago.
  16. Kg461
    Kg461
    Provencal, La.
    In the 066/660 competetion video Randy was in Mike. Were all thoso saws normal woods port that say id order from Randy today or do u guys go alil farther into the modifications?
  17. mdavlee
    mdavlee
    Yeah most of those were what you get from Randy, Brad, and Scott.
  18. Kg461
    Kg461
    Provencal, La.
    Most?? Lol!! Thats what im getting at! The ones that won then probably weren't the normal woods port? I mean I know most of us r not gonna got the work that would go into most of thoso top winning saws?
  19. Kg461
    Kg461
    Provencal, La.
    I mean u may port one saw to its potential within limits of the carb will allow until u changed out the carb or drilled the jet?
  20. mdavlee
    mdavlee
    Randy uses the same recipe I believe. I know some probably over ported theirs.
