Saw shootout/ MS 440, ported MS 460, MS 461, and Solo 681
Discussion in 'Chainsaws and Power Equipment' started by DexterDay, Nov 23, 2014.
  1. Hedgerow
    Hedgerow
    SW Missouri
    All those saws had plenty of power... Running 36" bars with stihl RSC chain, we were all standing on them to make time..
    I'd run any of those, any day...
  2. Hedgerow
    Hedgerow
    SW Missouri
    But it was very impressive to watch.. and listen to.
    mdavlee likes this.
  3. Carbine
    Carbine
    I see what you did there... Cause I was gonna do the same thing :rofl: :lol:
  4. Mastermind
    Mastermind
    Tennessee
    I had 3 395s there. They were all within a second of each other.
    DexterDay, Kg461 and mdavlee like this.
  5. Hedgerow
    Hedgerow
    SW Missouri
    That was a fun class...
    mdavlee likes this.
  6. Kg461
    Kg461
    Provencal, La.
    I think yall r lying! A ported 461 really won!!!!:D:p
  7. mdavlee
    mdavlee
    I don't think they were even released yet. :faint:
    Kg461 likes this.
  8. Mastermind
    Mastermind
    Tennessee
    Yeah you're right Mike.......they weren't.
    mdavlee likes this.
  9. Kg461
    Kg461
    Provencal, La.
    Randy where do u think the ported 661c will stack up in thoso saws? Will the mtronics limit the saw in the cut?
  10. Mastermind
    Mastermind
    Tennessee
    Time will tell.
    But no.....the M-Tronic will not hold the saw back.
    Kg461 likes this.
  11. Kg461
    Kg461
    Provencal, La.
    So u couldnt tune a regular carb saw to a higher rpm to out cut the mtronics saw with limited coil?
  12. Mastermind
    Mastermind
    Tennessee
    For cant racing......yes.
    Ron660 likes this.
  13. Kg461
    Kg461
    Provencal, La.
    Would it involve carb work and more fuel or will u chance leaning it out?
  14. Mastermind
    Mastermind
    Tennessee
    I'm not picking up what you are putting down sir.
  15. Hedgerow
    Hedgerow
    SW Missouri
    RPMs are king in racing. If you can hit the wood and 15,000 RPMs as opposed to 13,000 RPMs, you have a head start on getting through.
    Even if both saws are tuned to produce maximum power at 12,500 RPM.
    Ron660 and SquareFile like this.
  16. Kg461
    Kg461
    Provencal, La.
    Can a saw setup for woods port without carb work be setup for cant racing without carb work
  17. Kg461
    Kg461
    Provencal, La.
    I guess what im asking is how can an mtronics saw be faster if u can tune a carb saw for higher rpm
  18. Hedgerow
    Hedgerow
    SW Missouri
    Not very many carbureted saws can be tuned properly any higher than the autotune saws allow them to run.
    In the case of a true racer, you would be correct. Carburetors and unlimited coils are still the best option.
    Ron660 and Kg461 like this.
  19. Hedgerow
    Hedgerow
    SW Missouri
    Just turning the screws on a carbureted saw for a higher RPM, will only get a lean condition and the Saw will lose power in the cut from overheating. Unless, of course, it is all set up properly together.
    Kg461 likes this.
  20. Hedgerow
    Hedgerow
    SW Missouri
    I'm probably not explaining this worth a damm am I..
    Kg461 likes this.
