Saw recommendations need nimble
Discussion in 'Chainsaws and Power Equipment' started by basod, Mar 15, 2021.
  1. basod
    basod
    Mount Cheaha AL
    I have a 441c already - I know not the same as a ported 462, but it’s a good runner only a muffler mod completed by its previous owner cnice_37
    Honestly starting to lean towards a top handle
    Anyone want to chime in on the echo 355?
  2. buZZsaw BRAD
    Not familiar with the Echo saw but own a Stihl 194 and 201CM and very pleased with both saws. Also own a 201CM rear handle and am happy with it as well.
  3. The Wood Wolverine
    I know a who had a couple Husky top handles for sale if you are interested. PA Dan ?
    Dakota Hoarder, Chvymn99 and Horkn like this.
  4. Locust Post
    No experience with the 355 but I own 2 echos now and the most recent last year was a 400. Just gave it a good workout on Sat. and I love that little saw more all the time.
  5. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    I must be missing something. You will be falling pine ? For logging ?
    Even @ 16" dbh that's a lot more of a job than top handle saw are made for. Even a 261 isn't all that big for that job.
    If you already have a 441 I'de say you were in good shape for it.
    Imho . best saw for that job would be an 044 Stihl.
    I've had 4, 026 + 260s.
    They are nice.
    Not overly exciting , but they work. And are dependable . I've never run a 261 so I can't comment on the difference.
    I ran all mine with chisel ground chisel chain.
  6. basod
    basod
    Mount Cheaha AL
    All the main felling and bucking will be with the 441. I’m looking for something better than the ms170 (free) I have for top clean up
  7. buZZsaw BRAD
    Stihl MS194 rear handle. Perfect for limbing and bucking smalls. I have the RH in the MS201 and its great. It replaced my 170. I needed nimble too. I cut in tangles and rougher terrain frequently where a bigger saw is too clumsy/awkward. 14" bar, but can take a 16"
  8. buZZsaw BRAD
  9. Chud
    Chud
    NC
    I’ve used 201 rear handle and top handle and recommended either, but it’s pushing $700 now, unless you can find used.
    I recently used the Echo 2511t with an 8” bar and liked it more than the Stihl 150t.
    The echo is $400 and runs 3/8 pm chain
    Horkn and Cold Trigger Finger like this.
  10. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Haven’t run a echo 355, but my Echo 271t is a very capable saw. Pretty sure the 355 is a bit bigger so it should do what your asking without a problem.
    Running a different brand does take some getting used to. I find the on/off/chock switch is kind of in an odd location and the clutch cover/chain brake combination is wired.
  11. buZZsaw BRAD
    basod i cut these large limbs at a job i did last week with 201 rear handle. 14" bar was able to cut the larger rounds but had 261 for that. Ran a full tank of gas through it. Top handle finished the job. IMG_4557.JPG IMG_4556.JPG
    Let us know what you end up with? :popcorn:
    Horkn and Sandhillbilly like this.
