saw gurus......my 020T WILL NOT IDLE....
Discussion in 'Chainsaws and Power Equipment' started by Scotty Overkill, Mar 24, 2017.
  1. Scotty Overkill
    I'm assuming the accelerator pump is the little brass fitting on the metering side of the carburator?
  2. cwn877
    cwn877
    Central Pa
    They are expensive little buggers
    Scotty Overkill likes this.
  3. dougand3
    dougand3
    North Alabama
    Maybe you say it differently...but Idle/TAS/LA screw should be OUT to decrease idle. Counterclockwise = lower idle.
  4. Scotty Overkill
    I understand that. I'm saying with the screw turned the WHOLE WAY IN, it will not increase idle at all. I've rebuild dozens and dozens of saws, I tune them on a weekly basis.
    The idle is totally unaffected by the LA (idle) screw. Even with the L screw turned where it needs to be.
    The Wood Wolverine and Horkn like this.
  5. Scotty Overkill
    Yep. And dollar for dollar, I'm still unimpressed with them. They blow through twice as much gas as my Echo CS355T, and while there IS a slight power increase, it's just not enough to justify the cost and upkeep of the saw, IMO. And that's coming from a Stihl guy!!
  6. dougand3
    dougand3
    North Alabama
    Ah, thought we were trying to lower idle.
    I'd agree with above comments...try a new $15 carb. They're $10 if you wait for China ship. I know I lose patience after 1 rebuild and can't dial it in.
    clemsonfor, Scotty Overkill and Horkn like this.
  7. cwn877
    cwn877
    Central Pa
    If my pap hasn't destroyed his little echos I'm pretty sure you won't. I'm not familiar with the accelerator pumps on these carbs but it could let gas though if it's leaking I would think. The last saw I had that wouldn't respond to anything had bad seals.
  8. Screwloose
    Screwloose
    Does it have the internal non removable check valve ? The one that usually looks like a brass orifice ? The one everyone chemically warfare's with carb cleaner ? The one everyone sticks wires into ? The one everyone holds a air nozzle to ? The one......
  9. Screwloose
    Screwloose
    And as far as the quality of echos top handles, they sure make lousy wheel chocks.
  10. TurboDiesel
    o_O
    Yeah that is hard on them...
    clemsonfor, Chvymn99 and Screwloose like this.
  11. Bret Hart
    Bret Hart
    Central NY
    Page 102.
  12. Screwloose
    Screwloose
    Expensive to the owner to..
    And embarrassing.
  13. Scotty Overkill
    So do Husqvarna 372XP's. Don't ask me how I know that.....
  14. AJtree88
    AJtree88
    Yes, you have to remove the throttle shaft and pop the brass fitting out to reach it. There is a little brass piston in there with a rubber o-ring and a spring. The o-ring goes bad and causes an air leak. Throw the spring and rubber print away, reinstall the piston and JB weld it closed. Reassemble.
    That said, most 020T's don't have accelerator pumps, but with that saw being so old, it's probably been monkeyed with many times over the years. So who knows what it has for a carb. Check your bearing play and make sure you don't have a hole in the impulse line and it's connected to the carb housing well. I've had one that ran good on the top end, but wouldn't idle. Impulse line was barely on.
  15. bushpilot
    bushpilot
    Eastern Washington
    My Poulan PP5020AV would not come off of idle, it just went flat when the throttle was opened, and usually died. Sometimes I could get it to rev if I worked it, but then it would die coming off the throttle.
    I disassembled and cleaned the carb (twice), to no avail. Bought a new carb off of eBay, installed it on Wednesday after work, and today it cut like a champ.
    These little carbs are just not worth working on, in most cases. I still try anyway, but usually fail.
