Savage 64 ammo recommendations?
Discussion in 'The Game Room' started by HDRock, Jun 14, 2016.
  1. HDRock
    I just used what I had in the clip, which was Federal automatch.
    I got another one but I kind of screwed up, he went on his back and stopped moving, I thought he was done, I went over to find a good place to set down my gun and he was gone
    RCBS likes this.
  2. bassJAM
    bassJAM
    Cincinnati, OH
    He may still die. Once, years ago I took a shot at a groundhog at 140 yards with my .22. First shot landed about 20 yards behind him, I lowered my aim point and the 2nd shot landed 20 yards in front of him. The 3rd shot got him, he went limp and I started walking towards him. When I got within 40 yards and he saw me he started crawling back to his hole. Apparently I had just paralyzed his hind legs. By that point I was close enough to accurately hit him in the head, but I always wondered how long a partially paralyzed ground hog would make it in the wild. I doubt very long.
    RCBS and HDRock like this.
  3. lukem
    If you put a shot on him....he won't be long for this world unless you grazed him.
  4. HDRock
    I hit him good but in the hind quarters , was a small one , my guess is, probably dead by now.
    Maybe a mini mag would of done him in
    RCBS likes this.
  5. RCBS
    RCBS
    Over here
    Did you use the cantaloupe?
    It's been a couple years since I got a whistle pig. They have become sneakier, or all moved into the woods here it seems. Only time I see them anymore it's usually in a place where I can't shoot them...like out back of my work in town.
  6. HDRock
    Nope , didn't get any yet . I think there is 3 more
    I tried to use the bipod ,to much movement ,they would take off , had to sneak out n do it freehand.
    Picked up a boresnake yesterday.
    Any one else use em ?
    RCBS likes this.
  7. RCBS
    RCBS
    Over here
    I use the boresnakes. 1 pass is usually sufficient...sometimes 2. I put solvent on the area with the brush, and oil about 6" from the end of the tail. Scrub, wipe & oil all at once. I can run the snake through in the same amount of time it takes me to get sticks and patches ready. I have also recently started using the plastic & stainless dental picks and really like them for picking gunk out of the corners and tight spots. 22lr is a dirty round, and worse with a suppressor mounted.
  8. HDRock
    Why do they call some of these ring mounts, Weaver?
    I got my sweet 22 scope mounted and sighted in, it works as is but I don't like it so much.
    I need to get some different mounts, because the objective end of the scope is so large it is hitting on the iron sights when I tried to move it back farther to get a good view, so I need to mount it higher so that I can slide the scope back further to get a better View.
    Anyway, I'm confused on what will fit on that 3/8 dovetail.
    Looking at these Weaver See-Thru Detachable Rings , because they are available locally
  9. lukem
  10. lukem
  11. HDRock
    These are the ones that I ordered and mounted the scope with
    .22 cal. Medium Sport Rings - 182870, Rings & Mounts at Sportsman's Guide
    Why do they call some of these Weaver what does weaver mean? :confused:
    In the picture it looks like the iron sight is touching the scope but it is not, just real close.
    If I get the scope up higher I can move it back an inch or so and get a better View
  12. RCBS
    RCBS
    Over here
    Weaver is a standard for optics mounting. 3 types I'm aware of, weaver, 5/8 dovetail, and picatinny.
    Good reading here http://www.brownells.com/.aspx/lid=...y_Rails__Weaver_Rails__What_s_The_Difference_
    It looks like you have the dovetail mount? Can't tell from pic. There should be mounting screws for mounting a weaver rail on top? Weaver is going to be more popular with more traditional rifles, where picatinny is more for tacticool stuff on the ARs & such.
    You may need a high mount ring set if you stay with the dovetail. A weaver rail will net you a little more height off the receiver as it sits on top. If your receiver isn't tapped for a rail, there should be a weaver that will fit the dovetail. I'm afraid other than removing the rear sight (which isn't hard at all) or buying new rings or new rings and a rail.
    Having the scope sit where the eye relief is comfortable for you is essential. When I'm mounting optics I put everything on loosely, take my perch on the rifle, then slide the scope forward/backward until the view through is open when I'm in my natural, comfortable position on the rifle. Dont want to compromise your hold on the gun trying to get your eye lined up for the scope. Mount the scope so it lines up with your eye if that makes sense.
  13. HDRock
    Thanks for the input
    Yeah, that's why I have to do something else and fix this, because I have to cram the stock into my shoulder real hard and lean forward to get the proper eye relief and it's very uncomfortable.
    When I was mounting the scope I knew it was not going to work out this way, but I went ahead and secured it down anyway, I wanted to go play with it:D
    I ordered a pair of high see-through rings off Amazon they will be here tomorrow.
    I was thinking about taking the rear sight off but it looks like you have to pry it off or something and wouldn't be able to put it back on, I don't really know how it comes off , probably never use it on this gun anyway, but if I can't get the scope where I want it with the different rings, I will take it off.
    Yeah, it just has the 3/8 dovetail Mount, it isn't drilled and tapped at all. I could have that done if I really want to.
  14. RCBS
    RCBS
    Over here
    Forgot about the see thru rings. They should be a great solution for your issue!
    HDRock likes this.
  15. HDRock
    You have the sweet 22 scope, so do you change the turrets?
    I put on the 40 grain turret, I sighted the gun in at 50 yards loosened the three screws and lined up the 50 yard Mark with the mark on the scope body and tightened the screws back up.
    So what is the procedure if I want to switch to 36 grain turret? the manual that comes with the scope is a joke, doesn't tell you how to change a turret and set it.
    If I simply take one off and, put a different one on and line it up with the 50-yard mark and tighten the Screws, I have changed nothing, scope will still be in the same exact position?
  16. lukem
    I put on the 38 grain because it splits the difference. Even when shooting a 38 I don't think the turrets are all that dead on. Gimmick more than anything.
    Im not sure if you have to rezero if you swap them.
    RCBS likes this.
  17. HDRock
    Thanks, you know I have been thinking that maybe they are just kind of a gimmick, so I probably won't mess with them.
    I really like the adjustable objective though.
  18. HDRock
    Mounted the scope with the new see through rings, got the eye relief set real nice now.
    Rigged up a shooting station using the bipod and a saw horse, chair was to tall, I had to sit on the bucket :)
    It took a lot of rounds but I got it sighted in, 50 yards is as far back as I can get at my place.
    Shooting at the center Target at 50 yards had a couple of Flyers but not bad.
    RCBS likes this.
  19. RCBS
    RCBS
    Over here
    I need to go shoot! Seeing those targets makes me want to punch some holes in paper. It is decided, I shall celebrate and exercise my 2nd Amendment right one day this weekend in support of Our Nation's Independence Day!
    :rootintootin::usa::salute:
    bassJAM and HDRock like this.
  20. HDRock
    I here ya , I'm going to go out to range here soon
    This all makes me want to go buy another gun :rootintootin: machine-gun.gif
    I had to buy a new case cuz the gun won't fit in the one I have for it with that scope on it .
    Those ground hogs batter celebrate their Independence Day, TODAY :D
    RCBS likes this.
