Sad day maple,but wait.....
Discussion in 'The Wood Pile' started by J. Dirt, Jan 1, 2021.
  1. J. Dirt
    J. Dirt
    This one is a p65 Poulan pro/pioneer. It was a barn find and I had a friend rebuild it. It got a new bigger carb, 655bp piston and cylinder some boyeson reeds and a dual port muffler.
    Let’s just say without ear plugs on your teeth rattle and your vision gets wavy!
    It cranks!!!
  2. J. Dirt
    J. Dirt
    I did see some grubs in that pile on the stump. Not sure what kind, but that dirt is powdery soft and black.
    Spencer, M2theB, T.Jeff Veal and 4 others like this.
  3. Skier76
    Skier76
    CT and SoVT
    Wow! That's a good sized Maple! Any idea on how old it is?
    It is sad to see a big tree like that come down. However, sounds like it was the right time to do it given the condition it was in. Better to take it down in a controlled manner vs letting nature drop it.
    Spencer, M2theB, T.Jeff Veal and 5 others like this.
  4. Creekin
    Creekin
    Manitoba
    When I read poulan, i immediately thought of a wild thing!
    Those old saws were beasts!!
    Looks like a good score, keep it up!!
  5. amateur cutter
    This one we counted 146 rings in. Looks similar in size. Old family farm & the tree was there in 1890 when the house was built. 20200425_141626.jpg IMG_20200502_091926~21.jpg
  6. buZZsaw BRAD
    Ive thought of that many times when i find compost inside trees. Cant say ive ever found that much.
    M2theB, MikeInMa, T.Jeff Veal and 6 others like this.
  7. J. Dirt
    J. Dirt
    Was just teaching my boys about counting rings.
    When I get down to the stump I’m going to try and make a good clean cut so we can count. I have a feeling it was originally a two or three stem tree.
  8. J. Dirt
    J. Dirt
    Tank and a half of gas in the 266xp (first time out since I built it) and an hour of :fart:around. Three piles of limb wood to show.
    I’m going to push the brush off with the tractor and then get to bucking the good stuff.
    My little 2 year old is a wood fanatic like his dad and even outworks his 6 year old brother!! F1109279-6C7D-43AF-95A7-D4A69BAA479B.jpeg AAF30C38-9240-48C6-92A3-9FCB6B021A81.jpeg FFF8340A-D8AF-41AD-B416-8714C9241B7B.jpeg E6AA3554-EFB9-4579-A7E2-46D52F629BD3.jpeg
  9. J. Dirt
    J. Dirt
    Cleaned up the under 14” stuff with the 2-6-6
    Then fired up the 394! It hasn’t had more than a tank full through it since I built it so it needs some run time. Let’s just say :eek::smoke::thumbs:
    Everything is cut except the bottom log. It’s pretty hollow so shouldn’t be to bad. 4D017A28-BEC7-4D44-9A5F-0B1771D98379.jpeg
  10. amateur cutter
    Looks good, always fun to work with good powered saws. I'm guessing looking at the piles I was overly optimistic on my cord guess?
  11. buZZsaw BRAD
    Nice job! Lotta work in those monster trees. Having the right saws takes away the work factor though!
  12. J. Dirt
    J. Dirt
    I’m guessing 1 1/2-2 full cord? Maybe less because of some soft spots. You can definitely pick out the dead wood staining on a lot of the pieces.
    Something that I was concerned about when I was dropping it was the strength where the two stems met. My suspicion was correct because it fell apart when it hit the ground and the wood that was holding didn’t look very lively!! You can see the jagged broken edge of all that was holding that side together
    The broken edge on the right side was where it met then all of those rounds were what was on that piece. Always amazing the strength of trees even when they are in bad shape. E6923F7B-782C-4411-9803-F864CE8F2598.jpeg
  13. yooperdave
    Um, I don't think its dirt... :whistle:
  14. Canadian border VT
    But it’s real fertile?;)
  15. J. Dirt
    J. Dirt
    Nothing but the best from my trees!!!
    :thumbs:
  16. Chris F
    Chris F
    Micksburg, Ontario
    I've thought of that too but never did.
  17. Horkn
    Reed valves on a chainsaw? Awesome.
    I just kind of presumed they were all piston port engines.
  18. T.Jeff Veal
    Nice, that was a big tree. Great to see the little helpers.
  19. MikeInMa
    Looks like a fun tree to attack. Nice looking wood, where solid.
  20. J. Dirt
    J. Dirt
    She’s all bucked! Almost two gallons of gas and some chains that need a good sharpening now.
    main trunk just below the big leaders 7FFBF427-FF68-4D69-A45B-769BE8D431CE.jpeg
    Let the splitting begin!!
