Roll Call: Who's Cleaned Their Chimney?
Discussion in 'The Wood Pile' started by Jack Straw, Sep 15, 2015.
  1. Mag Craft
    Mag Craft
    South East Wyoming
    Cleaned mine about 3 weeks ago and filled the garage with wood 2 days ago.
    Ready to go.
    HDRock, gboutdoors and Jack Straw like this.
  2. Erik B
    Erik B
    Western Wisconsin
    Gotta get to cleaning the chimney sometime in the next couple of weeks.
  3. WoodovenAT
    WoodovenAT
    New Jersey
    Great!! Thanks
    Jack Straw likes this.
  4. gboutdoors
    gboutdoors
    S.E. Massachusetts
    Not yet waiting for cooler weather. Cleaned it at the end of season the first few years. Now leave it till fall so as to be sure no birds have taken up residence over the summer. Will get to it in the next few weeks.
    HDRock and Jack Straw like this.
  5. DaveGunter
    DaveGunter
    Swept it back in May and then got interrupted and never vacuumed out the clean out:picard: I just remembered it last weekend. I have no cap, a spring and summer's worth of rain down the chimney mixed with the sweepings is nasty :confused:
    HDRock likes this.
  6. Nixon
    Nixon
    West Sunbury,Pa .
    Did my inspection in the spring . So ,We're good to go fo 2015 .
  7. bassJAM
    bassJAM
    Cincinnati, OH
    I've been putting it off until it cools down, so probably within the next few weekends. For me, the chimney is pretty easy. It's the 6' of horizontal tube I have to disconnect, take outside and clean, and then put back together. That seems to take forever to get lined up and "airtight" again. I woke up Monday to a 48° temp outside, and had a quick panic attack that I haven't brought a supply of wood in the garage yet either. Of course, I normally let the heat pump run until the daytime temps drop to around the upper 40's.
    HDRock, snide and Jack Straw like this.
  8. KaptJaq
    KaptJaq
    Long Island, NY
    I sweep right after burning season. We live fairly close to the water so dampness is always a problem here. Any creosote or dust in the flue seems to attract moisture so I get it out as soon as possible. It is not as much of a problem for the wood stove as it is for the coal stove. Coal, no matter how clean it is, has some sulfur. The sulfur in the dust combines with the moisture to create sulfuric acid. That acid can rot pin holes through stainless pipes over the summer. (Ask me how I know...)
    To clean the insert I just have to remove the first secondary burn tube, then the baffle. Close the door, sweep (6" poly brush), then sweep up the dust. Usually get about 2 cups of black powder from the 22' pipe and about a cup of crunchy stuff from the top screen. I burn about 3.5 to 4 cords a season.
    After I sweep up the majority of the dust I vacuum then put something in the stove to absorb the dampness for the off season.
    KaptJaq
    HDRock, papadave and Jack Straw like this.
  9. ailanthus
    ailanthus
    Shenandoah Valley, VA
    Did mine last weekend. About 2 quart of black fluff.
  10. CTYank
    CTYank
    CT Panhandle
    Scrubbed things out in spring. Had to pull the indoors pipe to clean it. Maybe a couple quarts of fluffy debris. The pipe will get another "hit" before it goes back in place sometime soon. Close to 6' indoor single-wall boosts efficiency, long as you don't overdo things.
    Low MC wood mandatory.
  11. papadave
    Did ours earlier this year, but I'll do it again before we start burning full time.
    I no longer clean the flue several times/year since installing the NC30. It burns a lot cleaner than the old stove, and I thought I learned to burn that one pretty cleanly.
  12. jetjr
    jetjr
    Pa/Md line
    Got it all done today. Liner cleaned, stove cleaned, painted the new screws for the pipe, brick replaced and cut another piece for the baffle.
    HDRock and papadave like this.
  13. Backwoods Savage
    Not sure if we'll clean this fall or wait until next spring. We don't have to clean very often here. Dry wood and clean burning stoves make life easier.
  14. Tsquini
    Tsquini
    Cleaned my last weekend. I always end up lathering up a few points with stove cement.
  15. thewoodlands
    thewoodlands
    Just finished cleaning the wood stove chimney, about the same. Tomorrow will be the Pellet Stove chimney.
    I think Sunday we'll push some wood in just 4 the heck of it.
  16. Gark
    Gark
    SW Michigan
    Waiting after summer to brush the flue seems to work better. The warm months of no use lets the little bit of clingy creosote dry & turn crispy IMHO.
    Swept the flue a week ago and got a pint of half brown, half black powder.
    HDRock, Eric VW and Jack Straw like this.
  17. red oak
    red oak
    I clean mine in the summer, fall gets too busy around here. Mine is straight and takes all of 5 minutes. Also in the summer I clean the stovepipe, replace any cracked firebrick, inspect the stove, etc. Stove and chimney both ready to go here, but probably won't have to for another 3-4 weeks.
    HDRock, Eric VW, Gark and 1 other person like this.
  18. milleo
    milleo
    Maine
    Cleaned mine the other day and put the other three foot of pipe back on as I ran it this past winter three feet short....o_O...But added a pipe damper to slow draft down this year....Hopefully I will have the absolute perfect set up this year....The Jotul F3CB sure breaths easy....:smoke:
  19. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Agreed. I miss how easy it was to run.
    milleo likes this.
  20. prell 73
    prell 73
    ia
    Cleaned mine last sat
    HDRock, Mag Craft and Jack Straw like this.
