Ripping out a gas fireplace, putting in a wood stove.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Rangerbait, Jul 18, 2017.
  1. FatBoy85
    FatBoy85
    Washington State
    Well that'll hopefully be a decision rendered soon.
    Well Seasoned likes this.
  2. Rangerbait
    Rangerbait
    Shepherdstown, WV
    My wife actually turned on the heat pump for a few this morning after I left for work...oh, the humanity!
    HDRock, OhioStihl and Well Seasoned like this.
  3. Rangerbait
    Rangerbait
    Shepherdstown, WV
    Chimney day!
    Don't worry, I have a ceiling support box extension on the way, so this is just a dry fit for the time being. I have the inspection scheduled for tomorrow, so I hope the guy will still give me the sticker even though it's a dry fit.
  4. Highbeam
    Highbeam
    I'm a little creeped out about how your whole chimney will be supported by those nailed in 2x4s. Are you going to be putting hangers in there?
  5. Rangerbait
    Rangerbait
    Shepherdstown, WV
    There are straps at the 30 degree elbows that are taking a lot of the strain, but I'll go ahead and throw some hangers in for good measure.
    Highbeam likes this.
  6. Rangerbait
    Rangerbait
    Shepherdstown, WV
    Got the chimney stacked, but ended up about 6" short! I already let the inspector know, and he's fine with seeing the invoices so he knows the missing pieces are on order...I initially had 5 length of 4' pipe in the cart, but somehow I ended up only ordering 4. Bummer.
    Got the other length ordered, as well as the chase cover now that I know exactly where the pipe ended up (dead center)
    savemoney, Highbeam, Thor and 5 others like this.
  7. Rangerbait
    Rangerbait
    Shepherdstown, WV
    Forecast calls for 50% chance of rain tomorrow, so looks like we'll get one last chance to employ the kiddie pool in the alcove. Can't wait to get this project finally put to bed and start having a little time to do something other than hard labor with my idle hours. I knew this would be a big project, and it certainly has not failed to deliver...compounded by the fact that I haven't really plied my carpentry skills in well over a decade, as well as the reality of the toll that aging has taken on my ability to repeatedly ascend/descend 5 bucks of scaffolding without impact, and this has been quite the endeavor. I am very much looking forward to reaping the fruits of my labor this winter as the winds howl across the wide open farmland of the Eastern Panhandle of West Virginia, and as they try to keep me reaching for the thermostat...not this time, power company!
  8. Rangerbait
    Rangerbait
    Shepherdstown, WV
    Update: passed the chimney and framing inspections today, and made a little progress on the sheathing. Once the T-showers started, I made a Home Depot run and grabbed the Roxul that I'll be installing tomorrow.
    My goal for the end of the day is to get the 2nd and 3rd floors insulated, the rest of the sheathing hung and taped, and the rest of the flashing installed...at that point, the chase will be dried in (with the exception of the chase cover, which is on order). I will shift my attention to pouring the hearth pad next, so I can green-light the stone mason.
    Question: the hearth company wants $300 to deliver the stove to my garage...I'm thinking about just having them forklift it into my truck bed, then figuring out how to get it into my garage once it's here...bad idea?
  9. Oldman47
    Oldman47
    Illinois
    Since you are not yet fully enclosed, can you have them deliver it right to your hearth area with their fork lift?
  10. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    To avoid spending $300, I'd have them put it in my truck bed, and at home utilize a sturdy dolly along with some ATV/motorcycle ramps. One person holding the dolly handle from up in the bed, and one person on the ground on each side of the ramp, with hands on the stove corner. Between 3 people, you shouldn't have any problem. Another option could be to rent a u-haul or Penske truck for a few hours, one that has a power lift gate...probably get out for under $100.
  11. MasterMech
    Rent an appliance dolly from U-haul if you need to climb stairs. Lowes and HD rent pickups with liftgates if I remember correctly.
    $300? Are they delivering, and doing the final hookups? That's a bit steep to just set it on your hearth but I'm sure they are counting on a two-man team and a couple hours of their time.
    yooperdave, Well Seasoned and HDRock like this.
  12. brenndatomu
    Good idea...
    Like MM said, as long as I own a pickup there is no way they are getting $300 out of me unless they are hooking it up too.
  13. HDRock
    $300 to the garage :eek: NO
    A trailer would be better than your truck, but you can take out bricks and take the stove apart some to reduce weight .
    A pickup with lift gate is good idea too:)
    My stove weighs 430lbs , I got it out of the trailer and in the house by myself , your King 435 lbs.
  14. Rangerbait
    Rangerbait
    Shepherdstown, WV
    For a price, of course...call me old fashioned, but I absolutely can't bear paying someone for something I can do myself, unless of course the opportunity cost has exceeded my self defined threshold.
  15. HDRock
    Chimney looks great BTW
  16. Rangerbait
    Rangerbait
    Shepherdstown, WV
    Definitely leaning toward this option...I have a couple of neighbors with tractors who might be able to lend a hand.
    Horkn, HDRock, VOLKEVIN and 2 others like this.
  17. HDRock
    :yes:
  18. brenndatomu
    I've seen some pretty creative ways of getting a stove unloaded and installed by oneself. (work smart, not hard)
    One I recall that requires 4 guys (or two real strong ones) involved putting 8'-10' long 2x4s the whole way through the pallet and then using those as the grab handles...the way pallbearers carry a casket (sorry about the poor choice of example...it was the only one I could think of)
  19. Rangerbait
    Rangerbait
    Shepherdstown, WV
    That's just to deliver it to my garage from their shop about 8 miles away...these guys have been trying to soak me every step of the way, which is why I decided to do the pipe install myself. Took me about an hour to line the pipe up, and they quoted me $1,600,
    Including delivery and connection of the stove...that's half the reason why I'm thinking about just picking it up.
  20. HDRock
    Depending on the situation furniture slider pads can work great
    Horkn, Well Seasoned and Rangerbait like this.
