Restacking ugghhh
Discussion in 'The Wood Pile' started by capetownkg, Oct 29, 2016.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    QUOTE="scopes, post: 565694, member: 43"]Been there done that.:picard::salute:[/QUOTE]
    Aint we all brother!
    HDRock, Woodsnwoods, Eric VW and 2 others like this.
  2. capetownkg
    capetownkg
    southern, MD
    Where is this post, I need a visual of this
    HDRock, Woodsnwoods and Eric VW like this.
  3. Marshel54
    Marshel54
    I am not that good of stacker and have had to re-stack several times the past years.
    Two of my grandsons came over today and moved at least 3 truck loads up closer to the house, but the stacks wouldn't last. I can't complain since my back feels fine and they got a good bit of the wood up here.
    This year I am trying something different. Probably a good thing if it works. I use to raise cattle so I had many gates and potable panels laying around. I drove T-Posts into the ground and tied the panels to the post. Stacked the wood between them. If the stack falls the panels should catch them. We will see how it works. The only thing I should of done different was to make the stacks 2 wide instead of 3. Well maybe next year or if I make more stacks this year.
  4. Kevin in Ohio
    Kevin in Ohio
    For long term storage I've gone to the inward lean method to avoid double handling. It's takes just a little more time but not near as much as the hassle of a redo.
    Still no fall down after 5 years.
    J1m, Viking80, Decemberist and 13 others like this.
  5. Eric VW
    :binoculars:
    Still a LOT of wood, too:faint:
    :thumbs:
    Chopy, HDRock, capetownkg and 3 others like this.
  6. saskwoodburner
    saskwoodburner
    I shoot for the lean to the inside as well, although sometimes you get a weird situation where the middle/center of the stack wants to blow out. Imagine my surprise the first time I came across this in the wood shed.:eek:
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I use both the lean method and have used the long piece weave for a few years. I do not go 2x on the length, maybe an extra 6 to 10 inches. I can still get that piece into the stove, albeit an an angle. I hate stacking, so I do my best to avoid having them fall over. :dex:
  8. yooperdave
    I think it has happened to everyone, no?
    HDRock, Loon and Eric VW like this.
  9. jatoxico
    jatoxico
    Long Island, NY
    Moved about 1/2 cord into my shed and re-stacked a bunch including a row that went down :hair:. My stuff's always falling over since very little of what I get is straight.
    Chopy, HDRock and Loon like this.
  10. HDRock
    I don't know where a post is.
    Example : You are stacking two rows of 16 inch splits, 12ft long rows, one row in front, one in back , with a 10 inch space between the two rows , stack will be 4ft high , once the stacks are about 2 feet high you get yourself some boards 2x4s . Or whatever, approximately 42" long , when your stack is about 2 feet tall you lay the boards across both Stacks front to back and start stacking on top of them this ties both Stacks together and stabilizes them.
    For a 12-foot stack I put about 4 in.
    You can do that even if you are stacking the rows tight together 3 or 4 rows deep it will tie everything together.
    Does that make sense? :)
    Chopy and Eric VW like this.
  11. redneckdan
    redneckdan
    Northern Minnesota
    Yeah I can't stack for chitt.
    I do the inward lean and the double length tie back method.
    Eric VW likes this.
  12. Eric VW
    Did it recently on several cords some buds/brothers helped me get ahead on..... Except, 20 foot long x 4-5' tall, (x6), 8-10"s apart, used some old fence pickets as the stretchers. Worked great.
    HDRock likes this.
  13. HDRock
    I don't know what that is, splain it, please
  14. Woodwidow
    I am a lousy wood stacker but campinspecter makes it easy for me. He cuts our wood 22"-24" When I stack wood for Mom, it is never over four feet tall and really dry so it doesn't fall over on her.
  15. fox9988
    fox9988
    NW Arkansas 72717
    I've been using 2x2's about 32" long to tie my 16" wide stacks together.
  16. Pallet Pete
    Pallet Pete Moderator
    Ovid
    O the horror! :headbang:
    Cute helper though!
  17. boettg33
    boettg33
    Wakefield, RI
    Wow you must have really angered the baby for the baby to knock over your stacks. Next time you need to be faster with that bottle. I'd hate to see all of your stacks knocked over.
