Removing Clear Concrete Sealer
Discussion in 'The DIY Room' started by KilliansRedLeo, Jun 20, 2014.
  1. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    When I built my shop, I sealed the floor with clear driveway sealer the same stuff you use to seal a stamped concrete driveway. My wife has decided that she would like to have a new patio and expanded back yard hardscape. I pulled up all the 1 inch slate that was the patio with the intent of repurposing it as a floor in my shop.
    Well you and I all know mud will not stick to sealed concrete, so I have to figure out a way to get the sealer off the existing floor. Anybody got any ideas short of surface grinding the existing floor?
  2. nate
    nate Banned
    Palmer, AK
    Sandblast
  3. lukem
    Acetone?
  4. bocefus78
    bocefus78
    Indiana
    I have a friend who does epoxy floors. He uses a shot blaster for big areas and a cup grinder w/ diamond wheel for the small areas.
  5. My IS heats my home
    My IS heats my home
    Albany, NH
    I was going the same direction as Chris, a cup grinder with a diamond wheel will scratch it up well enough to adhere a new surface to it.
  6. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Super Glue?:)
    Gary
  7. HDRock
    Wash it down with muriatic acid ,scrub brush on a pole, rinse with water, and squeegee off ,wear rubber cloves and eye protection , and ventilate well while using it
    We used it a lot in ceramic tile , and swim pool building
    http://www.naturalhandyman.com/iip/infxtra/infmur.html
