Refrigerators...
Discussion in 'Everything Else (off topic)' started by Chvymn99, Aug 11, 2021.
  1. Canadian border VT
    My wife agrees but cosmetic changes (tub works doesn’t leak) are secondary to windows that leak.
    Chaz, mat60, wildwest and 5 others like this.
  2. Horkn
    You can always use that tub and tile epoxy to "paint" it a more standard color. That stuff works great, but it's STINKY for a couple of days.
    Chaz, mat60, wildwest and 4 others like this.
  3. brenndatomu
    You had luck with that stuff? We tried that stuff on the aforementioned pink sink...didn't turn out very well at all.
    Chaz, mat60, wildwest and 2 others like this.
  4. Canadian border VT
    I knew about that but it has to come out. Floor needs in bathroom needs replaced. In our humidity toilets sweat. New plywood will be marine grade or equivalent
  5. Horkn
    Yep, works great. I used it to turn 60's yellow tile into white tile in the half bath. It turned out awesome. My friend uses it a lot ( GC) and has only had great experiences with it. He recommended me to use it, and we're stoked at the results.
    Chaz, mat60, wildwest and 3 others like this.
  6. MikeInMa
    We have a single mixing valve that feeds our 2 toilets. I open it up a bit each spring then close it in the fall. Just enough hot water to keep the tank warm enough to keep humidity from condensing.
    Chaz, mat60, Horkn and 6 others like this.
  7. wildwest
    We used that on the surround in the old bathroom I moved into. Yes, stinky. Does it look a lot better, Yes! So far so good but not in use too long yet, and it's not the tub which is already white, just the surround which had yellowed.
    Chaz, mat60, Horkn and 3 others like this.
  8. Chvymn99
    Well, finally the case of getting resolution for my LG Refrig is done... Got the check today... Now time to go shopping and get a working full size fridge back in the house....
    rottiman, eatonpcat, bogieb and 7 others like this.
  9. mat60
    mat60
    ME
    Great you got the check.
    rottiman, bogieb, yooperdave and 3 others like this.
  10. mat60
    mat60
    ME
    Like to hear what you decide to get if you dont mind.
  11. Chvymn99
    Well, I picked up the new fridge this morning. Not what I wanted, but they had them in stock. Plus I can use the extra ice maker that I had never installed in the old GE.
    I’m getting pretty good at moving fridges in and out of the house.... I need to get a bigger front door... theyjust barely fits through the 30” door opening....
  12. yooperdave
    We are looking at a new refrigerator also.
    the thread continues........
    bogieb, Horkn, eatonpcat and 7 others like this.
  13. rottiman
    bogieb, Horkn, eatonpcat and 6 others like this.
  14. mat60
    mat60
    ME
    Congrats. Looks like a nice one. You sure will enjoy having it after the long wait.
    Horkn, eatonpcat, brenndatomu and 5 others like this.
  15. Midwinter
    It's a beaut!
    bogieb, Horkn, brenndatomu and 4 others like this.
  16. eatonpcat
    Finally Brother, Congrats...looks like a nice beer/Boubon cooler!
    bogieb, mat60, yooperdave and 4 others like this.
  17. bogieb
    I'm amazed it fit thru the door at all. Both my houses had exterior doors that were 36" wide just for when I need to replace appliances (well, this house came with that sized doors - but I would have enlarged them if it hadn't).
    mat60, eatonpcat, Eric VW and 2 others like this.
  18. Chvymn99
    Basically had to take off the doors and the bottom hinges for the top doors... Just to reassemble when you get it in the house. Now the LG the bottom drawer slide rail stuck out further so we had to take those two pieces off also to get it through the door.
    mat60, Midwinter, bogieb and 7 others like this.
  19. hovlandhomestead
    hovlandhomestead
    MN
    Here is our contenter for the state ugly fridge contest. It is Hotpoint circa 1980 we got from my parents after a move. It lived for about 9 years out in a corner of my wood lean-to as a bait fridge. It works as well as the day we got it. I am rather attached to it, and it is now in our laundry room where it our beer fridge (I have a very good wife!).
    We just got a new Amana 14 sq ft fridge freezer for our cabin now that we have power. It is really nice and replaces a Consul propane fridge/freezer.
    mat60, rottiman, yooperdave and 7 others like this.
  20. yooperdave
    :handshake:
