Red maple
Discussion in 'The Wood Pile' started by creek chub, Oct 18, 2016.
  1. creek chub
    creek chub
    Va
    if I CSS live red maple this fall and winter, can I expect to burn it next year?
  2. yooperdave
    Maybe, but the dryer the better, no?
    If you have a moisture meter, use that on it next year.
    I'd wait.
  3. creek chub
    creek chub
    Va
    Sorry I didn't type that too well. I meant to type burn next fall or winter.
  4. Locust Post
    I would say if you cut it pretty soon and get it split and stacked you would be fine, especially if you have a good hot Virginia summer.
  5. Well Seasoned
    X2 dry sunny single stack, I don't see why not......
  6. creek chub
    creek chub
    Va
    Summers are usually hot here. May top cover and see if that helps keep the rain off the wood since this past summer seemed unusually wet.
  7. Horkn
    Maple seasons pretty quickly. I don't see why it wouldn't be ready for next fall off split and stacked now.
    I'm a firm believer in using a moisture meter. It will tell you everything you need to know.
  8. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Stack it kinda loose and get the air and sun to it.......maybe. How big are the splits?
  9. creek chub
    creek chub
    Va
    Here is a pic of one stack
  10. EnglishBob
    EnglishBob
    Upstate NY
    Nice stack - small splits - should dry if it has sun and wind. Use MM to check.
    bob
  11. creek chub
    creek chub
    Va
    I have two more stacks just like it. By my count, I only need to scrounge 4-5 more trailer loads of wood for this coming winter. After that, I'm gonna focus on CSS red maples for the rest of the winter and try to get on that 3 year plan.
  12. papadave
    I've done it, but it burns a little nicer when I get it put up in the spring, then use it about 18 months later.
    As suggested, get a MM, then resplit a few random pieces next spring and check them.
  13. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Pretty small stuff, confirm with a mm, but guessing you will be fine.
  14. papadave
    Good point. That stuff seems fairly skinny, so it should dry pretty well and quicker than the stuff I split. As I was stacking in the shed, I kept asking myself why I split most of them so big.
    I think I was planning to use 'em for overnight fires or something.
  15. bogydave
    +5
    It'll burn fine with 12 months seasoning.
    Perfect job stacking: Off the ground, singel row, loose stacked , in the open, good air circulation !!!
    Top cover if you can.
    Stove type ?
    Catalytic's like real dry stuff.
  16. Ashwatcher
    Ashwatcher
    West By God Viginia
    You'll be fine-increase that distance off the ground moving forward to at least 12", face it south with no shade---it will be @10-12% by next burning season-I guarantee it...
  17. Ashwatcher
    Ashwatcher
    West By God Viginia
    AIR, from the bottom up, is key...single row is important too but if you leave 8-12" in between double rows=just fine too!
  18. bogydave
    +1
    Air circulation is key !
  19. NH mountain man
    NH mountain man
    WMNF N.H.
    You'll be ok to burn that next year, I've done it many years with Red Maple 14 to 15 months drying. Looking at your pics it looks great, small splits, good air flow= good to go!!!:coldfire:
  20. creek chub
    creek chub
    Va
    I have a regency 3100 insert
